OT : Boilers
Discussion in 'UK Motorcycles' started by fragmented, Nov 28, 2008.
  1. Oh, arrr.
    Grimly Curmudgeon, Nov 30, 2008
  2. fragmented
    geoff Guest
    Sounds like they begrudging did what they were contracturally obliged to
    do ... but only after you started creating waves
    Now, if you were a little old woman who didn't want to make a fuss ...
    geoff, Nov 30, 2008
  3. I don't hear it any more.
    Gawd bless tinnitus, I say.
  4. fragmented
    There's another *slight* possibility (though the symptoms aren't quite
    the same): do you have mixer taps? My old house had a problem where
    the cold mains pressure was so much higher than the hot pressure
    (actually in the tap mixer) that if the cold tap was turned on too
    high, cold water would get pushed back up the hot pipe into the hot
    water tank.
    Pip Luscher, Nov 30, 2008
  5. That happens when all the imported made-in-France /Italy mixers get
    fitted to UK homes with tank systems. Those mixers are designed for
    equal pressure feeds, usually mains pressure.
    The traditional British mixer didn't mix at all until the water was
    actually exiting the spout, so could cope with widely differing
    pressures.
    Grimly Curmudgeon, Dec 2, 2008
  6. I've had them (BG) here for some years. They upgraded the system here
    with a condensing boiler. They've maintained it without complaint for
    5+ years now despite having to replace the main hot water tank with a
    leak and it taking them a day to replace.
    They come when I ask and do the work they agree to.
    I can't fault them... yet!
    Steve Fitzgerald, Dec 18, 2008
Similar Threads
Loading...
