These stepper motors don't really like getting hot do they? When I first got this of WUN I accidentally left the motor driver box turned on overnight (WUN had given me strict instructions to never leave it on if the PC wasn't driving it). Next morning entered the garage to the delightful smell of burnt electrickery stuff. Damn. Controller box had burned out its mains transformer. Both of em (kind of a Heath Robinson affair). Sorted by ripping out all the AC power supply and powering it off my 35A 13.8V PSU. That appeared to fix it. In preperation for knocking up the new bracket for the 10R I've just stripped the whole mill down and rebuilt it (dishwashers rock for cleaning all the crap of stuff :-). Then stripped the smaller bits down and rebuilt them. Stepper motors still sticking when cold. Stripped the motors down. Bugger. Seems that when I left the control box on it heated the motors up to such an extent the "paint" used to hold the laminations together on the rotor had sort of turned slightly less than solid and oozed down just enough to sit proud of the rotor and cause it to slightly jam when cold. Sorted with a light dusting of sandpaper. The control box is of ancient design though, I'm tempted to replace it with 3 new stepper motor controllers that use micro steps and a chopper drive. Using the current control box the motors get too hot to hold after about an hours use, will using new design controllers reduce the heat? (thankfully the software lets you pause the program so I can let them cool down as needed)
