OT compressor question
Discussion in 'UK Motorcycles' started by eatmorepies, Dec 10, 2009.
  1. eatmorepies
    eatmorepies Guest
    I have a Wolf compressor. 2.5 hp, 25 litre, direct drive - cheap and
    cheerful. The book says "check and top up the oil". What oil do you put in
    it? The manufacturer help line does not work and I think Wolf have gone out
    of business.
    Incidentally. This one was sent by Aldi to replace the Powercraft one I
    bought last Feb - that on no longer auto offs at the correct pressure but
    heads off into the red. Fair play to Aldi they said "can't send you a
    Powercraft, will a Wolf of the same spec do you?" As my use is changing my
    motorbike tyres, a bit of light sandblasting and blowing water off
    motorcycl;es after washing them - the spec is fine. The origional came with
    a 3 year warranty so Aldi will keep me in compressors until Feb 2012; and
    I've been able to keep the old one. Where might I look to see if I can
    adjust the pressure sensing switch?
    John
  2. eatmorepies
    Doki Guest
    Powercraft = Wolf. Wolf supplied the original compressors to Aldi, and it's
    one of the things that helped them to go bust. The enormous orders 2 or 3
    times a year played havoc with their cashflow. Compressor oil is available
    at quite a few places online, and I suspect it's the same stuff for almost
    every piston compressor on the market.
    They are replacable, but I've never found one at a decent price.
    Doki, Dec 10, 2009
  3. eatmorepies
    Malc Guest
    Malc, Dec 10, 2009
  4. eatmorepies
    fishman Guest
    Yeah pretty much every company with cashflow issues succumbed this way
    to the credit crunch. They'd have probably continued to be a
    profitable company if it wasn't for that.
    Cashflow is king!
    fishman, Dec 10, 2009
  5. eatmorepies
    wessie, Dec 10, 2009
  6. eatmorepies
    TOG@Toil Guest
    Oops. Feel guilty now.
    TOG@Toil, Dec 10, 2009
  7. Engine oil. Any old 10/40 or so will do.
    Don't piss around, get a new switch.
    Grimly Curmudgeon, Dec 10, 2009
  8. eatmorepies wrote :
    There is adjustment under the red plastic cover, but there should also
    be a safety valve with similar to a key ring next to it. That should
    release any surplus pressure if the switch fails closed.
    If the valve isn't releasing and the pressure switch not opening, are
    you sure it isn't the pressure gauge simply telling lies?
    Harry Bloomfield, Dec 10, 2009
  9. eatmorepies
    Steve Guest
    There should be a plastic switch enclosure, with a metal base, and a
    pipe nipple that screws directly into the tank. The adjuster screws are
    usually under the plastic cover. You can buy spare ones from a pneumatic
    parts supplier with the advantage it will come with an instruction
    sheet. It doesn't need to be an exact match as long as the connection
    and pressure range are the same.
    However, you REALLY need to know what you are doing as it will kill you
    and anyone else in the vicinity if the tank blows up.
    If the gauge is going into the red, I'd be really worried that the
    safety valve is not functioning.
    Steve
    Steve, Dec 10, 2009
  10. eatmorepies
    Beav Guest
    "What's that up there Son?" ..
    "It's a bottle of oil Dad" ..
    "Be a chap and get it in the fucking compressor before it fucks up then"
    Those compressors are amost generic these days.
    I'd check under that plastic upside down box at one end.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 10, 2009
  11. eatmorepies
    zymurgy Guest
    zymurgy, Dec 10, 2009
