OT . Copy software
Discussion in 'UK Motorcycles' started by Jones, Oct 24, 2006.
  1. Jones
    Jones Guest
    I need to copy (not backup) my harddrive to another. Best software
    (running WXPPro)pse??
    TIA
    Jones, Oct 24, 2006
  2. Jones
    gazzafield Guest
    Norton Ghost.
    gazzafield, Oct 24, 2006
  3. Jones
    Steve Parry Guest
    seconded
    Steve Parry, Oct 24, 2006
  4. Jones
    prawn Guest
    Interesting. Our infratstrcture monkeys use it and swear by it too. I
    can't look beyond the fact that every other piece of Notrun branded
    software is a steaming great pile of poo. They had to get something
    right, I suppose.
    prawn, Oct 24, 2006
  5. Jones
    Susan Guest
    Ghost = PowerQuest Drive Image.
    Symantec purchased the current version (or previous, whatever) of Ghost from
    PowerQuest
    Susan, Oct 24, 2006
  6. Jones
    prawn Guest
    Ahh. All is clear. How many version upgrades before the bugs creep in,
    I wonder.
    prawn, Oct 24, 2006
  7. Jones
    Dan White Guest
    Based on their previous record, one.
    Dan White, Oct 24, 2006
  8. In uk.rec.motorcycles, Jones belched forth and ejected the following:
    Serial cable and Nero.
    Whinging Courier, Oct 24, 2006
  9. Jones
    catman Guest
    No one else seems to have pointed out that you can't actually *copy* a
    drive while XP is running. Norton Ghost is very good though, as long as
    you have a bootable CD, but the new (to me) version is a bit 'odd' IMHO.
    It's targeted very much at backups and restores. To do a disc to disc
    image (which is what I suspect you want) you need to dig into one of the
    more obscure bits (legacy IIRC)
    Another way to do it is the dd command under a live Linux distro (like
    Knoppix) Has the added advantage of being legally free.
    www.cuore-sportivo.co.uk
    catman, Oct 24, 2006
  10. Jones
    PDannyD Guest
    On Tuesday 24 October 2006 13:27, Jones []
    Your harddrive manufacturer might have some software available to do just
    that.
    PDannyD, Oct 24, 2006
  11. Jones
    Mike Barnard Guest
    I use Acronis True Image 9. Rumor has it that this can be had for
    free illegally.
    Mike Barnard, Oct 24, 2006
  12. Jones
    Cab Guest
    Exactly my feelings. But the other posts below this, clear things up
    for me.
    Cab, Oct 24, 2006
  13. Hmm, that's interesting. How does this sort of thing handle different
    disk sizes? I set up a system with an old 8 GB Seagate IDE drive for
    Windows and a 250 GB (or so) SATA drive for Linux. I now find the 8 GB
    drive to be too slow and noisy, so I bought a 160 GB drive to replace it.
    If I put the 160 GB on the IDE as slave, can I transfer the data from the 8 GB
    to it such that I can then make the 160 master and boot from it, etc.? I'm
    looking at just re-installing the whole kit-and-caboodle.
    Dr Ivan D. Reid, Oct 25, 2006
  14. Bit generous, that. Nought point one will probably see it bloated and
    be-bugged beyond recognition.
    Soylent Green, Oct 25, 2006
  15. It should do - as long as the destination drive is bigger..
    Have a look at this:
    http://www.rajeevnet.com/hacks_hints/os_clone/os_cloning.html
    Phil
    Phil Launchbury, Oct 25, 2006
  16. Jones
    prawn Guest
    prawn, Oct 25, 2006
  17. Jones
    catman Guest
    Norton would be better for that. dd (IIRC) will do a bit for bit copy
    from your old 8G to your spanky new 160G leaving you with a fine
    bootable disc with an 8G partition hiding in the corner. Ghost OTOH
    will 'expand' your 8G partition to fill the 160G drive. Then set it as
    master and away you go.
    catman, Oct 25, 2006
  18. And then you can use one of the many fine linux rescue CDs to expand
    the size..
    It doesn't know anything about linux filesystem formats - so it can't
    (for example) resize an 8G ext2/ext3 partition in the same way that it
    can for Windows format filesystems (Fat32/ntfs)
    Phil
  19. Jones
    catman Guest
    Ahh, now that I've never done. I wasn't aware that there were reliable
    tools that could re-size NTFS partitions without data loss
    That I can understand. I was assuming that it was an NTFS FS, in which
    of course I may be mistaken.
  20. There are - Partition Magic does it quite happily as do a lot of the
    free linux rescue CDs. Those also have the advantage that they are a)
    free and b) can handle linux filesystems (ext2/3, ReiserFS, XFS et.al.)
    Phil
