OT FOAK Kids Maths Homework - AAaaaarrrrgh
Discussion in 'UK Motorcycles' started by Mash, May 15, 2005.
  1. Mash
    Mash Guest
    There is no answer, the question is bogus.
    Mash, May 15, 2005
  2. Mash
    Steph Guest
    Emma's struggling with her homework - she's not the only one! If anyone
    can help we'd appreciate it.
    Here goes - although I don't know if the diagram will work ok.
    Tricky Triangles
    Use each of the digits 0 to 9. Put one in each circle.
    0 1 2 3 4 5 6 7 8 9
    a) The sum of the numbers at the vertices of each shaded triangle must be
    13.
    o
    /x\
    o - o
    /x\ /x\
    o - o - o
    /x\ /x\ /x\
    o - o - o - o
    b) Make the numbers at the corners of each shaded triangle total 14.
    Emma is quite happy to do the work herself, but neither she or I can work
    out what the difference is between the "sum of the vertices" and the "sum
    of the corners".
    I've googled, but I'm still none the wiser.
    Cheers
    Steph, May 15, 2005
  3. Mash
    Ben Guest
    The vertices are the corners.
    Ben, May 15, 2005
  4. Mash
    Hooligan Guest
    Steph did scribe:
    No difference at all: just someone being sloppy with their use of
    language to confuse you.
    Mind you, that is one hell of a problem to solve.
    John (jsp)
    SV 650
    Black it is
    And Naked
    Hooligan, May 15, 2005
  5. Mash
    buxtonmick Guest
    The vertices and the corners are one and the same thing, so is there
    something missing? It appears that you are being asked to obtain two
    different results for the same problem.
    Cheers, Mick.
    buxtonmick, May 15, 2005
  6. Mash
    Slider Guest
    [snip]
    That's the problem, well done!
    Slider, May 15, 2005
  7. Mash
    Hooligan Guest
    buxtonmick did scribe:
    That's correct: two different solutions to the same puzzle. Why is
    that a problem?
    John (jsp)
    SV 650
    Black it is
    And Naked
  8. Mash
    Eiron Guest
    13:
    9
    0 4
    7 6 3
    1 5 2 8
    14:
    8
    4 2
    7 3 9
    1 6 5 0
    Eiron, May 15, 2005
  9. Mash
    Steph Guest
    I think I've got a bit further although I'm not convinced...
    The dictionary says:
    ver·tex ( P ) Pronunciation Key (vûrtks)
    n. pl. ver·ti·ces (-t-sz) also ver·tex·es
    The highest point; the apex or summit: the vertex of a mountain.
    Anatomy.
    The highest point of the skull.
    The top of the head.
    Astronomy.
    The highest point reached in the apparent motion of a celestial body.
    Mathematics.
    The point at which the sides of an angle intersect.
    The point on a triangle or pyramid opposite to and farthest away from its
    base.
    A point on a polyhedron common to three or more sides.
    Therefore I think they mean the top of each triangle added together
    should = 13. Only thing is there's 6 vertices, and I can't get less than
    15 as an answer for the sum of the vertices 0 + 1 + 2 + 3 + 4 + 5
    As for making the corners add up to 14, do they mean all 3 corners? or
    the 2 corners that aren't the vertex?
    I don't remember my homework being this difficult when I was 10.
    Steph, May 15, 2005
  10. Mash
    Steph Guest
    Because they've only drawn one table for her to fill in, not two -
    implying that the 2 questions are part of one final answer.
    I've just put another post up with a dictionary definition saying that
    the vertices are the tops of the triangles, but I can't work it out that
    way either.
    Steph, May 15, 2005
  11. Mash
    Steph Guest
    Nice, but I'm not convinced that that's what they're asking for as
    they've only given her 1 chart to fill in, not 2 :eek:(
    This really is a bastard of a question
    Steph, May 15, 2005
  12. Mash
    Hooligan Guest
    Steph did scribe:
    I would just go along wiht the original idea that they are just not
    being careful with thier words.
    John (jsp)
    SV 650
    Black it is
    And Naked
