Rope scribbled: To be honest I don't even know if its being used at all. Got to investigate and find out exactly what is being used, and what its being used for, whats in those bits. Then I'll know I can chuck away or turn off half the stuff thats running. From what I can determine so far the only problems migrating things over are possibly the SQL, the various MS Outlook functionality (only used by one person so shouldn't be a problem), and advertising all the printers, file shares, etc, that Active Directory does (or should do, but doesn't cause its not working) There's something seriously wrong somewhere though, because just about everyone looses connection from one subnet to the other, and the DNS servers on one, and the gateway on another. Happened to me today, the machine thats supposed to do the routing just stopped routing until I rebooted my machine. The routing table of that machine looks wierd too. And looking at both the network cards IP setup, only one of them has a default gateway setup... <from memory> subnets 192.168.0/24 192.168.1/24 internet gateway 192.168.0.152 router machine eth0 : 192.168.0.151 and eth1 : 192.168.1.1 eth0 : IP and netmask are correct, gateway set to 192.168.0.152 eth0 : IP and netmask are correct, gateway blank? Shouldn't this be 192.168.0.152? Looking at the routing table (part of cause this is from memory):- IP g/w 0.0.0.0 192.168.0.152 127.0.0.0 127.0.0.1 127.0.0.1 127.0.0.1 192.168.0.0 192.168.0.151 192.168.0.151 127.0.0.1 192.168.1.0 192.168.1.1 192.168.1.1 127.0.0.1 Which looks fine to me apart from the loopback IP having a g/w of itself? And it doesn't seem to have a Default Gateway setup? Oh, and also Net BIOS is not being advertised from one subnet to the other, which is a complete bloody PITA as all the machines on 192.168.1/24 have to have their lmhosts file edited so they can see the DNS server (on 192.168.0/24)
dwb scribbled: Err, no. I know linux, MS server is a pain with all its GUI bits since over 75% of them seem to be extraneous! And the win 2k admin pack doesn't work on an XP box, and the XP admin kit partially doesn't work administaring a Win 2k server. And I couldn't find remote desktop on the servers to set that up (yes I know its a rather daft idea but I'm lazy!)
ginge scribbled: If I can migrate everything else over to a *nix box and leave one Win2k box running just the SQL server and nothing else I'll be happy with that.
Krusty scribbled: SPEC? SPEC? There's sweet FA documentation/design for anything here!!! The first thing I did was trawl through 100 odd classes and identified 20 of them that do nothing and can be deleted. And about another 5 that can be replaced by standard MFC.
Steve Parry scribbled: Oooh, ta, if I ever finish early enough to get to PC World I'll try to find a copy.
I'll repeat my question. Have you confirmed this would be in the best interest of your employer? Your knowledge of Linux is irrelevant to this question. Getting a new PC and some more licences is very cheap compared to you fucking off after 6 months leaving a "customised" Linux system that no one understands.
So 6pm'ish in the Paternoster? I've never been there so is it likely I will find you, or is this a cunning plan? SimonK appears to have pulled a sickie or something so dunno if he's turning up.
"at the bar". Well, at a table between the bar and the doors[1] - I'll keep an eye out; email me to whatever @ sticky.co.uk if you want my mobile no. (I don't think you have my current no.) The Paternoster itself is very easy to find - it's a couple of doors West along Newgate Street from St.Pauls tube station. You're based just up the road near Chancery Lane or Holborn tubes, right? Obviously a piece of piss to get the tube to St.Pauls, but FYI, I can walk from here to the Sainsbury's at Holborn in 12 minutes - it can take longer on the tube at rush hour, if you have to wait for a few trains to pass before one's empty enough to get on.
good point, well made. "whizzing" is relative - it's still quicker to walk at certain times of the day. Are you coming, or what, BTW?
It's not actually - I've got 'normal' legs and a short body. Hence why I have (and fit on) a gay motorcycle. (post editing not required TYVM). I wouldn't catch a bus anyway.
funnily enough, I saw the Kwack equivalent the other day, in orange - looks a lot nicer than the v-Strom; amazing what a nicer colour can do...
Probably. I'm feeling a bit shit, and working at home today, but these Day Nurse/Night Nurse pills seem to be doing the trick. When are you leaving the paternoster?
The likelyhood of someone understanding Samba setups is fairly good - especially if you recruit the replacement with the appropriate skills. Not so much 'customised' as 'using standard packages'. Phil
1. Set up DNS properly. It sounds like it isn't. I assume that it is running on the one of the AD server and is defined as an Active-Directory Integrated zone. Anything else will give you big problems. 2. Switch off any trace of netbios. 3. Use DHCP (Windows DHCP server is fine) 4. Set up WINS server on the server. 5. Point the WINS address advertised by the DHCP server to the WINS server. 6. Switch all the workstations over to DHCP - ones that need fixed IP addresses can have static reservations. 7. Set DHCP to update your AD DNS automatically. Phil.
