OT Help - I can't kill me mouse - or keyboard.
Discussion in 'UK Motorcycles' started by ^..^ Lone Wolf, Feb 29, 2004.
  1. Wotcha.
    Knowing how 'you lot' seem to have answers for most problems, how's this one
    for size ?
    I've just re-installed Windows ME on this here machine - easy enough, even
    for myself seeing as it has a recovery disc.
    Now the fun starts. When I hit >> start >> shut down, the computer does
    indeed shut down, same as it's always done, but it doesn't fully shut down.
    The 'num lock' LED on the keyboard is still illuminated, and the LED in the
    mouse is still active.
    I've done the usual 'read the help' files bit, and even had a nose around
    on a few websites but to no avail. Anyone got any suggestions ( other than
    the bloody obvious ).
  2. why would you do this?
    Doesnotcompute, Feb 29, 2004
  3. ^..^ Lone Wolf
    Big Dave Guest
    I built a new pc for myself using an abit motherboard. numlock and mouse
    stay on too. Its a quirk I believe. I have installed 98se / me / xp and it
    makes no difference.
    dave
    Big Dave, Feb 29, 2004
  4. ^..^ Lone Wolf
    Dr Zoidberg Guest
    I think I've found the problem.
    IIRC there was a patch for this sort of behaviour.
    Windowsupdate.com is your friend.
    Or windows 2000
    Alex
    YZF 600
    "I laugh in the face of danger"
    "Then I hide until it goes away"
    www.drzoidberg.co.uk
    Dr Zoidberg, Feb 29, 2004
  5. ^..^ Lone Wolf
    Catman Guest
    Mine has always done that with the mouse. Most mobos don't acutally shut
    down these days you see
    www.cuore-sportivo.co.uk
    Catman, Feb 29, 2004
  6. ^..^ Lone Wolf
    chris Guest
    With the abit motherboards, this is a feature in the bios which allows you
    to power up the pc by just using any key on the keyboard or by moving the
    mouse.
    Even when I disabled it in the bios the numlock light went out but the light
    on the optical mouse stayed on.
    Just ended up living with it. Using a USB mouse and keyboard would get rid
    of the problem (of the lights).
    chris
    chris, Feb 29, 2004
  7. ^..^ Lone Wolf
    I just stuck a blob of blu tack ove the lights. :)
    Muck, Feb 29, 2004
  8. I had an incomplete shutdown problem on my previous system from time to
    time. Farting around in the BIOS mostly cured it; try seeing what power
    saving settings you have. Basically I turned everything to 'off', ie
    none, and 'instant power off'. It would still do it occasionally,
    though.
    Ugdating the BIOS cured that problem and introduced another - had to
    manually set the processor speed on every bootup for the faster chip.
    Fortunately that machine was never switched off.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Feb 29, 2004
  9. ^..^ Lone Wolf
    Previously on usenet, Grimly Curmudgeon said...
    I had similar with my old machine. I found that kicking the side of the
    box or whacking it hard when it played up was best. It never cured the
    problem but I felt better about it.
    Lozzo : The anti-Timo
    ZZR1100D, GPZ500S, CB250RS x3
    BOTAFOT#57/70a, BOTAFOF#57, MIB#22, TCP#7,
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, BONY#9.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Artificial intelligence is no match for natural stupidity.
    Lozzo, Feb 29, 2004
  10. ^..^ Lone Wolf
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Mate of mine used to tell the following (almost certainly apocryphal)
    story...
    Seems he was working in a ground-to-air missile radar system that would
    occasionally lock up due to a sticking relay. A sharp clout on the
    appropriate spot on the case would solve the problem. They changed the
    relay to no avail, they messed about with everything they could think of
    with no improvement. Eventually they just decided that the "clout the
    box" solution worked fine and would become SOP.
    Then a new officer shows up and decides that clouting Her Majesty's
    radar is Not Good Enough, Something Must Be Done.
    My mate installed a large red "RESET" button that, when pressed, would
    solve the problem. Officer happy, peace restored.
    The button? It was connected to a large solenoid that, when energised,
    would clout the box in just the right place...
    Nigel Eaton, Feb 29, 2004
  11. Wotcha.
    Strange thing is - it used to power down fully, but now doesn't.
    Computers - you've gotta love 'em ;-)
    ^..^ Lone Wolf, Mar 1, 2004
  12. Wotcha
    Been there, as they say - couldn't find anything specific.
    Cheers all the same.
  13. Wotcha.
    That's the bit that's puzzling me - mine always used to shut down fully -
    I'm just curious as to what's changed and causing it to play "silly
    buggers".
  14. Wotcha.
    Had a nose in the BIOS - tried setting things that seemed related to "off".
    Hmm - if it wasn't for the noise of the fan, I would probably leave this
    thing on all the time.
  15. My father-in-law tells a similar story from when he was on Thor in
    Lincolnshire in the late 50s. The INS on the missile has a couple of scopes
    for getting fixes prior to launch: one that looked at a distant mark
    somewhere on the edge of the airfield, and one that picked up a datum off
    the gantry itself. Both had little doors to cover them in flight, but the
    gantry scope's door didn't have an automatic closer. So it was my FiL's
    job, as a tech sgt, to nip out with a broom handle, as the countdown was
    getting into the vinegar strokes, and knock it shut. And this is completely
    non-apocryphal.
    Platypus - (unreal)
    VN800 Drifter, R80RT, Z200
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    pseudoplatypus, Mar 1, 2004
  16. Should be able to get quite fans, do a search for silent fans
    Boots Blakeley, Mar 1, 2004
