I have a little problem with the hot water system. The hot bath tap runs slowly then peters out. The system s 20 years old, and is a normal gas boiler and indirect hot water cylinder arrangement fed from a cold water header tank in the loft. Hove is a very hard water area. The water is hot - until it stops running that is - the problem seems to be the header tank doesn't go down, actually it does but very slowly. I have operated the bleed nipple on the tall pipe next to the motorised valve - water comes out. There are two feeds off the header tank, both go down into the airing cupboard; I assume one does the hot water cylinder and the other the cold taps and toilet cistern. It doesn't go down particularly fast when the toilet is flushed but the cold tap seems to run ok. What is the possible cause? solution? Probable cost - DIY or with a plumber? Would it pay me to get Gyp to fix it so I could claim on the insurance for a completely new house?
