OT I swear they know. (dead car blog)
Discussion in 'UK Motorcycles' started by cat, Aug 19, 2009.
  1. cat
    cat Guest
    My car died, the week before the MOT is due.
    Looks like a packed in alternator. It's not charging.
    It ran for a time with the electrics fading away and finally coughed.
    No warning lights for anything at any time.
    Considering that it's not actually starting at the moment from a lack of
    electric, is there anything else I can check before chucking my hard
    earned at a new bit and some tools to fit it? I'm working my way through
    the HBOL.
    cat, Aug 19, 2009
  2. cat
    There are various Lucas service centres dotted around the country. If
    you take your alternator in & flutter your eyelashes, they'll test it
    for you, & may even bung some new brushes in if that's all it needs.
    If it's totally dead, you should be able to get an exchange one from a
    motor factors.
    Probably worth charging the battery first though to see how healthy
    that is, & sticking a multimeter across it to see if the alternator's
    doing anything.
    Krusty, Aug 19, 2009
  3. cat
    First thing to check is - does it have an alternator warning light? If
    so, has the bulb blown? If it has, replace the bulb and see if it
    charges - a lot of alternators need the current via the bulb to self
    excite, the pervs.
    Timo Geusch, Aug 19, 2009
  4. cat
    cat Guest
    But it says I have to take out the steering wheel to get in there!!
    It doesn't have an 'alternator' warning light but a char... oh wait.
    This is simple. The warning light is there on switch on, so the bulb
    must work.
    Can an optimate charge a car battery?
    I've given up trying to get the alternator out for now, it's just too
    bloody hot.
    cat, Aug 19, 2009
  5. cat
    Jim Guest
    Same thing happened to my old Audi - it did flash up some interesting
    logos before it finally died though.
    Yes, it'll take a while though. The car should run for a while on a
    fully charged battery if you keep the heater and the radio and the
    lights etc off.
    First thing is to charge the battery. Then get hold of a voltmeter,
    measure the voltage across the battery when stopped (should be about 12
    to 12.5) and when running (should be 13.5 or better).
    There's a few other things it could be than a dead alternator.
    Jim, Aug 19, 2009
  6. cat
    cat Guest
    The battery *currently* reads 11V but doesn't have enough guts to start
    the car.
    When it was jumped at the roadside it was sitting at about 8V with the
    engine running.
    When I'm feeling less like I've got heat stroke I'll haul the battery
    out and get it on the optimate and let it sit overnight.
    cat, Aug 19, 2009
  7. cat
    cat Guest
    The hbol for this tank is full of the word 'brushes'.
    Admittedly it says for the 97 model that I'm playing with accessing the
    brushes requires full disassembly of the alternator housing so it
    suggests getting a new unit, but they're still in there.
    cat, Aug 19, 2009
  8. cat
    Yes, brushes.
  9. cat
    Yes, but it'll take a while - as in "days".
    Unfortunately it sounds like the alternator is the culprit...
  10. cat
    zymurgy Guest
    Better to borrow (more eyebrow fluttering) a proper car battery
    charger and put it on that, than try to drip fed it with an optimate.
    One of the neighbours will have one ...
    Me, i've got about 4. Anyone want an Absaar or a Halfords battery
    charger ?
    Cheers,
    Paul.
    zymurgy, Aug 19, 2009
  11. cat
    I've got one in SW18 that's available to borrow.
    ogden, Aug 19, 2009
  12. Of course. Unless it's a brushless alternator.
    Brushes are dead common on automotive alternators, being a cheap and
    simple way of supplying field current to the rotor. Brushless permanent
    magnet alternators are more of a bike thing and brushless self-exciting
    alternators are most commonly found on mains gensets.
    Grimly Curmudgeon, Aug 19, 2009
  13. cat
    crn Guest
    First check the fan belt, slack or missing fan belts are the most common
    cause of charging failure.
    Does the ignition light come on ?.
    The alternator gets its field current via the ignition light bulb, so
    a dud bulb will stop it charging.
    Also check the brushes - a replacement set of brushes is a helluva lot
    cheaper than a new alternator.
    crn, Aug 19, 2009
  14. cat
    cat Guest
    Thanks to all for the comments.
    I've ordered a 'tested' second user part, I'm happy with the
    cost/perceived value ratio and the risk. I'll have a look at the old one
    when it's cool enough to breathe out there and see if it's a possible
    referb for spares.
    If this all goes tits up, with a full charge in the battery and a dead
    alternator, is there any reason for an MOTist to A notice, B fail it?
    I suppose it depends how long they take to check the beam angles :p
    This is the car with a failed 5th gear, I'm not going to spend any
    serious money keeping it running.
    Job interview in the morning... maybe, just maybe I'll be able to buy
    something unruined.
    cat, Aug 19, 2009
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    Error 0x0016 - MAX_CASCADE_COUNT exceeded: Please contact your Usenet
    adminstrator.
    go and talk to the Catholics.
    Wicked Uncle Nigel, Aug 19, 2009
  16. cat
    Heh.
  17. cat
    Beav Guest
    Watt the **** are you on about?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 21, 2009
  18. cat
    zymurgy Guest
    Heh, eyebrow fluttering, who is she, Roger Moore ?
    Good trick if you can do it.
    Paul.
    zymurgy, Aug 25, 2009
