OT :Landrover Discovery
Discussion in 'UK Motorcycles' started by Steve, Nov 17, 2009.
  1. Steve
    Steve Guest
    I'm in the market for a cheap (<£2k) Land Rover and Discovery's seem
    plentiful in this price bracket , much more so than 90's or 110's.
    Whats wrong with them?
    Steve
    Steve, Nov 17, 2009
  2. Steve
    Older models have got a pretty horrendous reputation for reliability.
    Krusty, Nov 17, 2009
  3. Steve
    Nige Guest
    Steve
    Lots can go wrong. Diesels are where it's at, but they are slow.
    Engine wise.
    Head haskets can go
    Turbos can go
    Water pumps can let go
    Timing belts need doing
    Sumps leak
    Bodywork
    They can rust very badly
    Inner wings
    door bottoms
    rear seat belt anchor point, just inside car
    Boot floor rust through
    Electrolytic corrosion on paint
    Mechanicals
    Swivels can go tits up
    Gearboxs can clunk on drive take up, new box outout shaft req
    dampers can be shot
    steering damper
    To be fair, there's loads of them & they are more reliable than you
    think. Look for an ex-japanese one & the rust wont be as bad.
    300tdi is better than you think & all the above bits are quite cheap if
    you are handy with a spanner. The rear boot floor can be terminal due to
    cost getting it done unless you can weld.
    Nige, Nov 17, 2009
  4. Steve
    Nige Guest
    Also, the 90n & 110 suffer many of the same problems. Main reaosn is
    they look a bit dated. I would another tomorrow, but i maintain my own.
    Nige
    Nige, Nov 17, 2009
  5. Steve
    Says the man who drives a BMW.
    ogden, Nov 17, 2009
  6. Steve
    Jeweller Guest
    My neighbour has rebuilt his (don't know the model) XXX XXXL registered
    Land Rover from new chassis up. I was very impressed.
    R100RT
    Aprilia Pegaso 650 IE "The Flying Mythos"
    Formerly: James Captain, A10, C15, B25, Dnepr M16 solo, R80/7, R100RT
    (green!)
    www.davidhowardjeweller.co.uk
    Jeweller, Nov 17, 2009
  7. Steve
    I nearly posted the same as ogden, but then realised *I* wasn't sure
    what my point was!
    CT, Nov 17, 2009
  8. Steve
    Steve Guest
    Cheers Nige
    Steve, Nov 17, 2009
  9. Steve
    Nige Guest
    Oh the old ones are shit to drive on road, but at that age most will be
    getting to use off road, where they are ace.
    The new D4 I had for a few weeks a while ago, was bloody amazing.
    Nige, Nov 17, 2009
  10. Like nothing else...
    The viscous coupling to the rear diff can be troublesome, and if it goes
    and is left, it can take other bits with it due to transmission wind-up.
    They're pretty capable though. I did one of those 4WD activity day
    things in one, and it was pretty good.
    Chris Bartram, Nov 17, 2009
  11. Steve
    They're named after two Pet Shop Boys albums.
    platypus, Nov 17, 2009
  12. Steve
    Eiron Guest
    Viscous Coupling? Are you talking about the Freelander?
    Eiron, Nov 17, 2009
  13. Bollocks. Yes, Sorry. It was the mention of head gaskets tht got me on
    those lines.
  14. Steve
    Nige Guest
    Some do have couplings though.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Nov 17, 2009
  15. Steve
    zymurgy Guest
    I'd be the first to stick up for Landrover, but the Fucking Freelander
    did its head gasket today. It's just clicked over 71K miles, having
    gone around the country 3 times on various interview junkets recently,
    so it did quite well. They usually go at 60K ish.
    Paul.
    zymurgy, Nov 17, 2009
  16. Steve
    Paul - xxx Guest
    What Nige says ... BUT ...
    If you can wield a spanner (hammer) and have some knowledge (Angle
    grinder and welder) and can do your own servicing and stuff then they
    are pretty easy to maintain, run extremely well, are a lot of fun and
    surprisingly cost-effective.
    They're extremely good mile-eaters/ I find it has a very comfortable
    driving position and I feel better/fresher after a long drive than I
    ever did in my Mondeo/Laguna/Vectra rep-mobiles ...
    90's and 110's hold their values better, but suffer exactly the same
    problems, indeed they're the same engines other than ancillaries, and
    chassis apart from length. Disco's rust a bit .. but if you can weld
    then they're pretty easy to work on and repair.
    Regular filter/oil changes do lots of good, not driving them stupidly
    helps longevity, parts are easy to get hold fo, cheap and easy to fit,
    mostly.
    Great vehicles, IMHO ... ;)
    Paul - xxx, Nov 17, 2009
  17. Steve
    Ever owned a Rover?
    Pip Luscher, Nov 17, 2009
  18. Steve
    Are you after a Land Rover because it's a Land Rover or after a rugged
    4x4?
    There are Fourtraks in that price bracket. Worrying for me 'cos I paid
    nearly 7K for mine a few years ago. At that time dealers were all
    asking 6K for ones that had obviously been used as farm vehicles.
    They're rather truck-like to drive and ground clearance is slightly
    compromised by the gearbox support member but generally have a good
    reputation and will pull up to 3.5t braked. I don't know if this is
    model-specific though.
  19. Steve
    Simes Guest
    The benefit of the Land Rover stuff is that it's so cheap to fix. OK -
    stuff goes wrong, but that's true of most older vehicles.
    www.paddocks.co.uk (and there is John Craddock too - but I don't like
    him) will keep any old LR kit on the road for pennies. I did discs and
    pads all round on my P38 not long back for 60 quid.
    Simes, Nov 18, 2009
  20. Steve
    It does look like LR spares are cheap: in some cases about a third of
    those for the Fourtrak, but so far in about 21K miles of ownership
    (its now done about 92K) I've had to replace a couple of CV gaiters
    and an exhaust back section. I did have the timing belt replaced just
    after I bought the car because there was no record of it having being
    done and the radiator is now corroding - I might replace it this
    winter as a precaution. Bodywork is fine - a few stone chips that are
    rusting and there are recessed bolts in the roof that also rust.
    Underneath is solid. Alloys are pretty rough but that makes them
    slightly less desirable to thieves.
    When I bought the Fourtrak, I really wanted a Land Rover but couldn't
    justify it: the tales of unreliability; the prices (at the time) even
    for high mileage examples; the fuel consumption; it all added up.
    It isn't a luxurious vehicle and is very unrewarding to drive over 70,
    but I've driven it solo to the Alps twice now without discomfort.
    Pip Luscher, Nov 18, 2009
