OT Laptop won't power up.
Discussion in 'UK Motorcycles' started by sweller, Jan 30, 2008.
  1. sweller
    A month ago I left my work laptop's power adaptor on a train (it was
    under a newspaper and as I had the plug bit thought I had the whole
    thing).
    I have now finally got hold of a replacement (they sent the wrong one
    initialy) and have plugged into the very dead laptop and it remains dead
    (it's a Toshiba Satellite Pro). Is this normal, do I have to wait x
    hours before it'll fire up?
    In other news I now have the Guzzi back - it hasn't mysteriously fixed
    itself and still won't fire. Not sure if this is good or bad.
  2. sweller
    dog Guest
    this
    http://norman.walsh.name/2008/01/26/agony
    is educational
    dog, Jan 30, 2008
  3. sweller
    Mark Olson Guest
    Obvious question- do the LEDs on the front of the laptop light up
    when you plug in the PSU? Did you plug the previous (wrong) PSU
    into the laptop? Wrong polarity or voltage could have fried the
    lappy.
    Mark Olson, Jan 30, 2008
  4. sweller
    The power lead I have is somebody else's 'spare' one and has successfully
    operated my machine in the past - he has the same laptop. We share
    office space and it saves us both lugging leads about so I can't see it
    being a power lead problem.
    Backups aren't a problem either as I'm pretty good on that and have the
    data I need. It's just my spare laptop has a knackered screen and is a
    pain to use.
  5. sweller
    darsy, Jan 30, 2008
  6. sweller
    Yes, I have a battery charge light on. No, I didn't plug wrong lead in
    as it had a much smaller connector and wouldn't even fit.
  7. sweller
    Dr Zoidberg Guest
    Remove the battery from the laptop and see if it will boot with just the PSU
    connected.
    I've seen a faulty battery that prevented it powering up before.
    Dr Zoidberg, Jan 30, 2008
  8. sweller
    FIXED IT!
    I'd taken the battery out to see if it was the same as my spare laptops
    when it died (it wasn't) and I hadn't put one of the catches back in the
    locked position.
  9. sweller
    another dumb question - have you tried holding down the power button
    for a reasonably long time, say 10-15 seconds?
    darsy, Jan 30, 2008
  10. sweller
    dog Guest
    i had a laptop a while back with a power connector that looked identical
    to norm's.
    dog, Jan 30, 2008
  11. sweller
    Buzby Guest
    sweller wibbled:
    have you looked at the kill switch on the Guzzi yet ?
    Buzby, Jan 30, 2008
  12. sweller
    It doesn't have one.
  13. sweller
    ST Guest
    I have a spare PSU one for a satellite pro A60 - Liteon model
    PA-1900-05, came with laptop. If it transpires your one is borked let
    me know. Email me (email in headers is valid) if interested. Would
    sell you the old satellite pro but it is fairly well fucked now (USB
    does not work, does not install a new OS (not even ubuntu) although
    hard drive that was in it was OK. screen hinges borked. PSU connector
    on back wobbly. Battery gives approx 1 min life, if you are lucky) -
    do not even want to put it on ebay. Still looks fairly mint though!
    I think my laptop did the playing dead thing and it eventually
    started.
    ST, Jan 30, 2008
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, sweller
    <nods>
    Honda GL1000K2 (Fallen apart) Suzuki TS250 "The Africa Single"
    Norton 850 Commando Kawasaki GTR1400
    Wicked Uncle Nigel, Jan 30, 2008
  15. About how to **** up putting drives into a horrible wooden enclosure by
    an idiot, sure.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Jan 31, 2008
  16. Do you mean the battery is dead and won't charge up or the laptop is
    dead too?
    If it's only the battery, then it's probably fucked, I'm afraid. A lot
    of laptop batteries just die if they're left lying too long or left on
    constant charge.
    As for the laptop itself, it certainly should work off the mains
    adapter, but are you sure it's not a duff connector at the back of the
    laptop?
    GS850x2 XS650 SE6a
