OT : Paging the Engineers
Discussion in 'UK Motorcycles' started by Steve, May 18, 2010.
  1. Steve
    Steve Guest
    Where can I get a small sheet of engine turned aluminium or stainless?
    Google is failing me.....
    Steve
    Steve, May 18, 2010
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Steve
    Make one. It's not that hard.
    Wicked Uncle Nigel, May 18, 2010
  3. Steve
    Steve Guest
    It had crossed my mind - scotchbrite on a slow speed drill?
    Steve, May 18, 2010
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Steve
  5. Steve
    Pretty smart, except: why did he cut the shape out first? I'd have
    marked it roughly, burnished it first, then marked it accurately and
    cut it out.
    Pip Luscher, May 18, 2010
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip Luscher
    I have no clue, the interesting part (FSVO...) was the burnishing tool.
  7. Steve
    <snigger>
    He said 'front bottom'.
    Krusty, May 18, 2010
  8. Steve
    If I knew what engine turned was I might be able to help.
    Maybe I've failed as an engineer?
    Andy Bonwick, May 18, 2010
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Krusty
    <G> Yeah, I noticed that too.
  10. Steve
    I knew. Comes from watching the Antiques Roadshow as it was a way that
    Industrial Revolution silversmiths showed off.
    wessie, May 18, 2010
  11. Steve
    Steve Guest
    Steve, May 18, 2010
  12. Think Lindbergh's Spirit of St Louis.
    Jeremy Robinson, May 18, 2010
  13. Steve
    petrolcan Guest
    I only discovered that phrase about seven years ago.
    I think its very stupid.
    petrolcan, May 18, 2010
  14. Steve
    Beav Guest
    I thought it was going to get interesting when he said "First I marked the
    front bottom".
    Sadly.....
    Beav, May 19, 2010
  15. Steve
    M.Badger Guest
    A piece of softwood dowel with a cross cut in the end and fine grade valve
    grinding paste as the abrasive works quite well too.
    M.Badger, May 19, 2010
