OT [photo] Fuzzy rocks
Discussion in 'UK Motorcycles' started by Paul Carmichael, Aug 25, 2010.
  1. Paul Carmichael, Aug 25, 2010
  2. Paul Carmichael
    wessie, Aug 25, 2010
  3. wessie escribió:
    3/43?
  4. Paul Carmichael
    photo no 3 in the set of 43, now 44.
  5. wessie escribió:
    I assume you're taking the piss, but just in case, I think it was around
    about 36º57'18.16" N 4º32'36.11" W.
  6. Paul Carmichael
    Unusually for me, no. I like the look of the road & scenery. May be a
    tad warm for my preference though.
  7. wessie escribió:
    Sorry - was being a bit thick. It became 44 within minutes of posting the
    link, so didn't see the thingy wibble. The last one added was completely
    black, so I whacked up the white. Haven't touched the rest, apart from
    scaling and jpegging.
  8. Paul Carmichael
    Thomas Guest
    There's a great little road not far from there: A-7000, between
    Colmenar and Malaga. There are a couple of loops where it goes under
    itself as it winds down the mountain.
    Thomas, Aug 25, 2010
  9. Thomas escribió:
    Some serious hairpin bends. A friend was following me on his Divvy and went
    off-road. My bike's surprisingly good in tight bends as long as I keep the
    power on.
  10. Paul Carmichael
    Ofnuts Guest
    <blanket type="wet">
    The pictures are in focus, but at f/8 and 18mm, you've got pretty much
    infinite DOF so everything is in focus and it would be very hard to have
    anything blurry in such conditions.
    But although the pictures are properly focused, they are far from sharp,
    even at 1500x1000. There are two possible causes:
    You are using the lens at its minimum length so it's not at its best
    (even if using f/8 helps). Zoom with you feet and avoid going below 20mm.
    The scaling (to 1500x1000) always makes the picture softer. One should
    always give a small shot of sharpening (aka "unsharp mask") after
    scaling to restore some of the original sharpness. For instance, on an
    extract of your DPP_0013: http://cjoint.com/?izvPJD78Ts
    I would have also added a pinch of contrast. DSLRs are very "neutral" by
    default, if you don't post-process your images you can use slightly
    aggressive settings for contrast/saturation, otherwise, it's better keep
    contrast/saturation low and increase them in post-processing.
    </blanket>
    Don't worry, you'll eventually get "the eye".
    Ofnuts, Aug 25, 2010
  11. Paul Carmichael
    Found them on Google Maps - looks like fun.
    There's a similar loop on the Gerlos Pass in Austria. You go under a bridge
    and then climb through a 360 degree loop to go over the bridge.
  12. Paul Carmichael
    Nice.
    I posted a few photos of El Torcal a year or two back and ISTR you
    commenting about them being better than any of yours.
    I think those have just overtaken mine!
    I loved that place - cold as **** though in March. I must go back one
    day.
    CT, Aug 26, 2010
  13. Paul Carmichael
    Ofnuts Guest
    Yes, indeed a matter of taste, and I overdid it a bit for the example.
    Also, working from the original would have been better.
    Ofnuts, Aug 26, 2010
  14. CT escribió:
    I love the place. It's about 45 minutes from here. If you go when there's no
    tourists, it's magical.
    Paul Carmichael, Aug 26, 2010
  15. Vass escribió:
    Do you know who you're talking to?
  16. Borg escribió:
    My fuzzy rocks were in RAW format. What I don't understand is why a jpeg
    created by the camera is so different from a RAW jpegged by me.
  17. Paul Carmichael
    Ofnuts Guest
    No, I use DPP (but I don't do much RAW anyway). My run-of-the-mill photo
    twiddling is done with Gimp, working on neutral camera-produced JPEGs.
    Ofnuts, Aug 27, 2010
  18. Paul Carmichael
    Ofnuts Guest
    If you use Canon's DPP to produce JPEG from your CR2, it will use your
    camera settings by default.
  19. Grimly Curmudgeon escribió:
    I'm thinking of specializing in porn photos. Actually, I'm not really. I got
    a new wide monitor, and my existing wallpaper doesn't work at that
    resolution (http://paulc.es/tmp/album-sleeves.jpg), so I set about browsing
    the web for a nice wide hires piccie. But are there a lot of hires flesh
    piccies about for free or what? I mean it's mostly pornographic, but there's
    actually a lot of nice stuff as well. I didn't find anything that my wife
    would consider appropriate though (even though she was fine with that other
    one), so I used a picture of her with some dolphins instead.
    Paul Carmichael, Aug 27, 2010
  20. Paul Carmichael
    Thomas Guest
    Kinky.
    Thomas, Aug 27, 2010
