OT. Ping the cricketisti
Discussion in 'UK Motorcycles' started by Malc, Nov 29, 2010.
  1. Malc
    Malc Guest
    Why do teams declare? Do they have to give the opposition a chance to
    win? It strikes me as being a risky policy so can someone enlighten
    me?
    Malc, Nov 29, 2010
  2. Malc
    Gyp Guest
    It's to give the other team the chance to lose.
    If you get to the end of the time without all the innings being played
    then it's a draw.
    Gyp, Nov 29, 2010
  3. Malc
    prawn Guest
    Wikipedia sums the nuances of declaring, nicely.
    <http://en.wikipedia.org/wiki/Declaration_and_forfeiture#Declaration>
    There are times when declaring early is desirable but not in test match
    situations.
    prawn, Nov 29, 2010
  4. Malc
    They declare when they're in a potential winning position. Or at least
    a non-losing position.
    Assuming this post is triggered by the situation in the first test,
    England had 3 hours in which to bowl Australia out. It was possible,
    if not probable, and then they would have won the match. Continuing to
    bat could only ever result in a draw.
    CT, Nov 29, 2010
  5. Malc
    Roughly speaking,
    First innings: team A bats, ends when team B bowls A out
    Second innings: team B bats, ends when team A bowls B out
    Third innings: team A bats, ends when team B bowls A out or A declares.
    If team A fails to get as many runs in total as B did in the second
    innings, B wins by an innings.
    Fourth innings: team B bats, ends when team A bowls B out or they run
    out of time. If team B gets more runs in total than A, then B wins by x
    wickets. If team A bowls B out before that happens, then A wins by x
    runs. If neither happens, it's a draw. Team A has to allow enough time
    to be able to bowl B out, which is why they declare - if the third
    innings lasts til the end of the match (because B can't bowl A out) then
    the best either side can hope for is a draw. And they want to win.
    Or, last night, team A knows it's going to be a draw but declares to rub
    in the fact that B can't possibly get enough runs to catch up whatever
    they do. Ho ho ho.
    ogden, Nov 29, 2010
  6. Malc
    Malc Guest
    OK Ta. I understand enough now.
    Malc, Nov 29, 2010
  7. Malc
    snip>
    We could have declared earlier and given them some encouragement to go
    for it but we only need draws to retain the Ashes so **** giving them
    even a sniff of a chance.
    The convicts must be seriously demoralised after bowling for nearly 2
    days and only getting one wicket and to make matters worse it wasn't
    even one of their full time bowlers who took that wicket.
    Andy Bonwick, Nov 29, 2010
  8. Malc
    Salad Dodger Guest
    In the olden days, teams used to have to contirve ways of getting "all
    out" in an attempt to get time to force a result. the ability to
    declare the innings closed removed this peculiarity.
    Also, the declaration gives a side the option of placing *all* of the
    blame on the captain when they get beaten, rather than the normal 99%.
    Salad Dodger, Nov 29, 2010
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    Except, of course, when Pakistan are playing.
    Wicked Uncle Nigel, Nov 30, 2010
