OT question about sound
Discussion in 'UK Motorcycles' started by Alan Crowder, Nov 29, 2010.
  1. Alan Crowder
    Alan Crowder Guest
    My knowledge of audio is almost nil so bear with me, I have a Virgin
    media TV box which gives me my Sky stuff, it has one HDMI output which
    goes up to the TV and works well, is there an Amp I can purhase which
    will take the HDMI output and give me sound into some speakers and then
    transfer the picture back up to the TV or am i screwed only having one
    HDMI output?
    It has ethernet and USB on the back as well, but thats all.
    Ta
    Alan
  2. Alan Crowder
    Catman Guest
    Yes. Just about any HDMI surround sound amp.
    I *would* go as far as to say *any* HDMI amp but I expect there's one
    *somewhere* that won't do it.
    No
    www.cuore-sportivo.co.uk
    Catman, Nov 29, 2010
  3. Alan Crowder
    Gyp Guest
    The answer's yes (eg
    http://www.richersounds.com/product/av-receivers/sony/strdh500/sony-strdh500),
    but there might be a simpler way.
    What audio outputs does the TV have? you might be able to run a digital
    out from the TV to an amp, so you don't have to use the amp as a
    switching centre (and you can use an older - non HDMI - amp)
    Gyp, Nov 29, 2010
  4. Alan Crowder
    Alan Crowder Guest
    No idea, I shall crawl behind it tonight and have a look, i do remember
    its a 42" LG something or other purchased two years ago.
    Thanks
    Alan
  5. Alan Crowder
    Alan Crowder Guest
    Further to this, i do not have any audio out's on the rear of the TV,
    just inputs, I do have 2 x scart, plus an optical out, can this optical
    out deliver the sound to an Amp and then to speakers ok?
    Alan
    Alan Crowder, Nov 30, 2010
  6. Alan Crowder
    Gyp Guest
    Sounds [1] like you do have a digital audio out in the form of an
    optical TOSlink connector, so any old AV amp should be fine.
    However, if I were you, I'd ignore my comments yesterday about searching
    out a non-hdmi amp as the new hdmi-switching amps are nice and cheap
    already (as per Champ's link).
    I'd still recommend simply connecting up the amp to the telly via the
    optical though as it can save a lot of fannying about. I have an old
    Sony TA-VA777ES battleship of an amp with but a single digital input in
    use and it works fine [2]
    [1] did you see what I did there?
    [2] strictly, this is a lie. The amp works beautifully, but I have 2
    digital inputs going in, a coax from the bluray and an optical from the
    sky box; neither from the telly, but the principle's the same.
    Gyp, Nov 30, 2010
  7. Alan Crowder
    Alan Crowder Guest
    I did, i am awake.
    Thanks for this, I shall search Richer sounds for an Amp which has a
    optical input, plus a suitable cable i guess.
    Alan
  8. Alan Crowder
    Gyp Guest
    Even the cheapest Sony amp at Richer Sounds has 3 HDMI inputs, 2 optical
    and 1 coax so you should be OK.
    I'd suggest sourcing your cables somewhere other than Richer though as
    20-30 quid for an optical cable is taking the piss. A search for
    "toslink cable" on ebay will turn up a number of alternatives for under
    a fiver delivered.
    Gyp, Nov 30, 2010
  9. Alan Crowder
    Alan Crowder Guest
    Now thats "sound" advice, I shall indeed take a look at ebay for these,
    and Richer for the Amp.
    Ta muchly.
    Alan
  10. Alan Crowder
    Alan Crowder Guest
    I cant find a Sony amp at Richer Sounds which has an optical input, any
    idea's?
    Alan
  11. Alan Crowder
    Gyp Guest
    I suggest you look harder. I can't find a Sony amp at Richer sounds
    which doesn't have an optical input!
    SONY STRDH500
    Coaxial Inputs 1
    Optical Inputs 2
    Hdmi 3 in/1 out
    SONY STRDH510
    Coaxial Inputs 1
    Optical Inputs 2
    Hdmi 3 in/1 out
    SONY STRDH800
    Coaxial Inputs 1
    Optical Inputs 3
    Hdmi 4 in/1 out
    SONY STRDH1000
    Coaxial Inputs 1
    Optical Inputs 3
    Hdmi 4 in/1 out
    SONY STRDH810
    Coaxial Inputs 1
    Optical Inputs 3
    Hdmi 4 in/1 out
    SONY STRDA3500ES
    Coaxial Inputs 1
    Optical Inputs 4
    Hdmi 4 in/1 out
    Gyp, Nov 30, 2010
  12. Alan Crowder
    Eiron Guest
    Probably a good idea to check that they have adjustable lipsynch delay
    in case Alan wants to connect things up properly.
    I expect they all do these days if they have HDMI.
    Eiron, Nov 30, 2010
  13. Alan Crowder
    Gyp Guest
    Might also be worth considering...
    http://www.sony.co.uk/product/hch-systems-with-blu-ray-disc/bdv-e370/tab/technicalspecs
    Combined bluray/av-amp/speakers/sub with optical-in, internet video (for
    iplayer etc) DNLA (for streaming content from your PC). It's even ready
    for 3D. Even gets What HiFi's best bluray system under £500 in this
    year's awards (if you're impressed by that sort of thing)
    £270 at Richer after the current Sony cash back
    http://www.richersounds.com/product/1-box-home-cinema-systems/sony/bdve370/sony-bdve370
    As long as your telly has more than one HDMI socket you're sorted. Best
    get on your hands and knees again.
    Gyp, Nov 30, 2010
  14. Alan Crowder
    Alan Crowder Guest
    Now i am confused, (it does not take much) so if this Sony Amp which I
    can now see has both HDMI inputs and outputs can I connect the Virgin
    Media box into the Amp, then from the Amp up to the TV with no problem?
    Alan
  15. Alan Crowder
    Alan Crowder Guest
    Only has one HDMI input, cheap LG crap.
    Alan
  16. Alan Crowder
    Gyp Guest
    You can do just that should you wish. HDMI to the amp, then HDMI to the
    telly.
    However, depending on whether the amp allows the signal to pass through
    when it's turned off, you might have to have the amp on all the time you
    are watching the telly.
    Then if you get a second HDMI source, such as a bluray, or a PC, or an
    xbox, or a PS3 or.. or... you will need to have the amp on and use that
    to select the input that you want on the telly, whether you want
    amplified sound of not
    If you wire up the other way, all the sources going in to the telly then
    one output from the telly to the amp, you only need to have the amp on
    when you want amplified sound, and it will always be amplifying whatever
    the telly's showing
    Gyp, Nov 30, 2010
  17. Alan Crowder
    Gyp Guest
    Looks like you're back to an HDMI-switching AV amp then.
    Though until you've got more than one HDMI source, I'd still be tempted
    to connect virgin to telly then telly to amp
    Gyp, Nov 30, 2010
  18. Alan Crowder
    Alan Crowder Guest
    Now that's a post I can understand, thanks, I shall indeed connect it
    to the tellybox and then back to the Amp and turn it on when i want it.
    Off to Richer sounds at the weekend then.
    Thanks
    Alan
  19. Alan Crowder
    Gyp Guest
    I'll agree up to a point.
    For years we used the AV amp all the time, but rewired it for simplicity
    (mainly as the pre-hdmi composite-video switching didn't pass the aspect
    ratio information so T was fed up of my moaning at her for having
    everyone either fatter or thinner than they should have been).
    Now the AV amp is at the end of the chain, we find we tend to use it
    only when we're watching films or music or Top Gear, but rarely for the
    news or Eastenders etc
    And as the telly's on for about 80 hours a week, it costs me about a
    tenner a month just to use the AV amp all the time.
    Gyp, Nov 30, 2010
  20. Alan Crowder
    Eiron Guest
    You have to subtract the cost of the gas that the central heating
    doesn't use
    when the AV amp is helping to heat the house.
    And I think you are overestimating the power consumption of your amp.
    Eiron, Nov 30, 2010
