OT Win95 connection to Win2008 server
Discussion in 'UK Motorcycles' started by Alan Crowder, Jul 23, 2010.
  1. Alan Crowder
    Alan Crowder Guest
    I have a nice new Win2008R2 server in our domain, unfortunatly i also
    have some old Win95 boxes which need to connect to this, thankfully
    they are on a seperate vlan and away from internet access.
    I can ping the server ok, i can connect win98 boxes ok but not win95.
    Anybody have an idea???
    Alan
  2. Alan Crowder
    Windows 95?
    The OS that went end-of-support almost a decade ago?
    I think you're trying to solve the wrong problem.
    ogden, Jul 23, 2010
  3. Alan Crowder
    Alan Crowder Guest
    I know i am, but to replace the piece of equipment which it runs is
    best part of a quarter of a million squids, so were making do while it
    works fine until it goes pop, hence my requirement to connect to this
    server so the bods can save there data to it.
    Alan
  4. Alan Crowder
    Chris Dugan Guest
    ISTR there being an AD client for Win 9x on the Windows 2003 server CD
    but I don't have one to be able to check. That may get you partly working
    but M$ could also have turned on encrypted Netbios (I think) by default
    in Server 2008 (and is the only option i.e. you can't disable it) which
    may really bugger you up as by my dim recollection I don't think you can
    enable that on with Win9X clients.
    I would have thought that Netbios also needs to be installed/enabled (on
    the server) as does WINS (on the DC) for the Win 9X clients to be able to
    find the server. Rather than installing WINS (I don't think it is
    available for server 2008) you should be ok with just specifying the
    server within the lmhosts file (In the Windows folder) but I can't
    remember the syntax... something like:
    192.168.1.1 server PRE DOM:domain.local
    Aha, see this for some details about it:
    http://support.microsoft.com/kb/180094
    After all the faffing about it may be simpler to configure an FTP site on
    the Server2008 box and configure the Win 95 clients to dump their data
    there and have them using local rather than domain accounts. That way you
    only need IP connectivity & DNS name resolution working for whatever FTP
    client you are going to use and that will be working or you'd have a load
    of errors and problems getting XP/Vista & Win7 clients to talk to the
    server.
    Chris Dugan, Jul 23, 2010
  5. Alan Crowder
    Jim Guest
    That would be my approach as well - stick to a simply protocol and
    forget about windows shares. An alternative would be to run a nightly
    rsync batch job if FTP is too fiddly.
    Jim, Jul 23, 2010
  6. Alan Crowder
    zymurgy Guest
    JHFC. I've not even booted mine up for a good 6 years or so.
    I occasionally put W98SE on a really quick processor for a laugh, but
    mostly I only need such venerable OS's to run programs that have tight
    coupling with the underlying hardware [1]
    Paul.
    [1] e.g. to run very old games that won't virtualise or emulate.
    zymurgy, Jul 23, 2010
  7. Alan Crowder
    ginge Guest
    Googled guess.
    Disable Raw SMBs on the server by editing it's Registry as follows:
    1. Run Registry Editor (REGEDT32.EXE).
    2. From the HKEY_LOCAL_MACHINE subtree, go to the following key:
    \SYSTEM\CurrentControlSet\Services\LanmanServer\Parameters
    3. From the Edit menu choose Add Value.
    4. Add the following:
    Value Name: EnableRaw Data Type: REG_DWORD Data: 0
    ginge, Jul 23, 2010
  8. Alan Crowder
    Catman Guest
    And this is where you are going wrong....
    www.cuore-sportivo.co.uk
    Catman, Jul 23, 2010
  9. Alan Crowder
    zymurgy Guest
    "I had a dream ..."
    Paul
    zymurgy, Jul 24, 2010
  10. Alan Crowder
    Gavin Guest
    When you first built the server at first logon, (the bit where you are
    made to change the admin password) it tells you that the current
    iteration of SMB wont work with older clients, and then tells you wat
    to do about it.
    I see others have found the right link to fix.
    Gavin.
    Moto Guzzi California Aquila Nera
    GSXR600K1
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.stoof.co.uk
    Gavin, Jul 24, 2010
  11. I think you need to turn off server-side SMB signing.
    http://support.microsoft.com/kb/916846
    Chris Bartram, Jul 25, 2010
