OT : Wireless access points / routers
Discussion in 'UK Motorcycles' started by frag, Jan 15, 2008.
  1. frag
    frag Guest
    Thanks to a power cut, Sod and Belkins firmware upgrades being crap I
    now have one half dead Sky BB wireless router and a completely dead
    Belkin wireless access point.
    The Sky box works fine as a router, but the wireless side works for a
    few hours, then get a cold and then dies.
    So, even if I could find the receipt for the Belkin (lifetime
    guarantee), its a bit crap anyway, so whats a damn good reliable
    a) Wireless Access Point?
    and
    b) ADSL2+ router + wireless AP?
    For now I'm back to using the trusty Efficient Networks ADSL router,
    but it hasn't got UPnP which I like.
    I do like Draytek stuff but they ain't cheap.
    frag, Jan 15, 2008
  2. I've been happy with my whatever Eddie recommended for a similar period
    of time. Very much a case of it doing what it says on the box without
    any faffing around to make it that way.
    steve auvache, Jan 15, 2008
  3. frag
    Eatmorepies Guest
    I just fitted a Netgear DG834G. Bought from Amazon for £40 delivered
    (slowly). I don't know if it's got UPnP because I don't know what that is.
    What I do know that it installed very easily, it very easy to configure and
    the other two machines in the house found it's wireless signal easily.
    John
    Eatmorepies, Jan 16, 2008
  4. frag
    That's what the Sky-supplied one is, only hacked a bit for the
    technically un-savvy. Frag may be wary of replacing like with like but
    mine's been fine and Netgear seem to have a good reputation.
    I wouldn't touch Belkin with a barge-pole.
    CT, Jan 16, 2008
  5. The manual for my DG834GT mentions UPnP but doesn't say anything
    about configuring it. fwag might want to look at this article:
    http://www.channelregister.co.uk/2008/01/15/home_router_insecurity/
    I'm now using an Orange Livebox, so I can't check the Netgear directly (it
    will probably end up with Mum in Oz). I turned off UPnP on the Livebox last
    night as I don't think I need it...
    Not after they used to hijack your http requests to show you ads
    for their services...
    Dr Ivan D. Reid, Jan 16, 2008
  6. frag
    *ding*
    CT, Jan 16, 2008
  7. frag
    frag Guest
    Thats whay Sky supply, and what has died after 18 months.
    I saw that the day after I posted, heh.
    I use NoScript on all machines anyway so its not a problem.
    Thats what I thought until it died.
    One right PITA thing I also need is the ability to limit the ADSL line
    speed. Or a decent ADSL modem that doesn't connect at the highest
    (unreliable) rate it can, as the Netgear/Sky one did until I flashed it
    with some firmware that let me control its speed.
    frag, Jan 16, 2008
  8. frag
    boots Guest
    I've always turned off UPnP, not because of any great foresight but
    because I prefer to choose which ports are open.
    boots, Jan 16, 2008
  9. frag
    I moved from a house with cable to one with ADSL only. I bought an SMC ADSL
    modem/router with one ethernet and one USB port. I've connected that to the
    Linksys wifi router I used with the cable broadband.
    I'm very happy with this setup. The Linksys box has worked continuously for
    over 4 years without a hitch. It seems to be happy talking to any make of
    wireless adapter. The SMC box has been going strong for 2 years.
    wessie, Jan 17, 2008
  10. frag
    Switters Guest
    Thread hijack.
    Do all wireless routers support NAT so multiple machines can share the
    same internet connection?
    Switters, Jan 17, 2008
  11. frag
    frag Guest
    CT banged the rocks together and said:
    Thanks to someones suggestion that Netgear used some of those 1999
    dodgy capacitors, I pulled the router to bits and sure enough there was
    a bulging cap in there. Replaced in 5 mins and its been fine so far.
    frag, Jan 17, 2008
