OT zip drive question
Discussion in 'UK Motorcycles' started by eatmorepies, May 1, 2005.
  1. eatmorepies
    eatmorepies Guest
    I have an Iomega 100Mb zip drive I want to use on my new computer ; OS = XP
    home. I plugged the drive into LPT1 and the computer can't see it.
    I tried 'add new hardware' in control panel, still no zip drive. (The drive
    works on the old machine).
    Alas no floppy drive on the new machine to try the installation disc in. I
    did try the extenal floppy from the laptop but that too plugs into LPT1 and
    cannot be seen.
    John
  2. is the lpt1 enabled, other than that run a diagnostic , majorgeeks.com have
    shed loads of programmes you can download to do this .
    you may even have a disk with the machine
    steve robinson, May 1, 2005
  3. eatmorepies
    Catman Guest
    https://iomega-eu-en.custhelp.com/c...HZsMj0xNyZwX2NhdF9sdmwxPTUwJnBfcGFnZT0x&p_li=
    If that link doesn't work:
    www.iomega.com
    Slect Europe
    Support and drivers
    100M ZIP Parallel
    XP
    3rd line up from the earch box at the bottom
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 155 TS
    www.cuore-sportivo.co.uk
    Catman, May 1, 2005
  4. eatmorepies
    tallbloke Guest
    Bin it and buy a compact flash reader for a fiver, and some cf cards of
    around 128mb capacity for about the same. Plug into usb port, voila,
    instant removable drive recognised by windows.
    tallbloke, May 1, 2005
  5. eatmorepies
    I got a half gig usb mp3 player that can be used for transporting files
    for an early birthday present. Not expensive, you can find them on ebay
    for about 35 quid all in.
    Muck, May 1, 2005
  6. eatmorepies
    JB Guest
    JB
    JB, May 1, 2005
  7. eatmorepies
    Cab Guest
    Cab, May 1, 2005
  8. eatmorepies
    tallbloke Guest
    muck@_TEETH_rulex.net (Muck) wrote in muck@_TEETH_rulex.net:
    I got one wiv an fm radio in too...
    So much easier than toting a clunky old zip drive around, and of course, you
    run into the 'no floppy drive to install the drivers' problem wherever you
    go.
  9. eatmorepies
    tallbloke Guest
    ****, thats cheap flash ram.
  10. eatmorepies
    I forgot, this one has a radio in it too. It's bigger, faster and than
    my IBM 340meg MicroDive equipped Zaurus for listening to music on.
    Muck, May 1, 2005
  11. eatmorepies
    eatmorepies Guest
  12. eatmorepies
    eatmorepies Guest
    Sorry JB, I didn't tell the whole story to save bandwidth. I put my Zipdisk
    on eBay to get rid of it. It went for £2.31 plus realistic postage. Not
    worth the effort of walking to the post office really. On the bright side -
    I will have a space on my shelf.
    I wanted to check (a) it was still working (b) that I had removed my Wife's
    backup files; although no one in their right mind would want to read
    thousands of lesson plans/schemes etc.
    Thus I needed to have quick look at the disks.
    Given the tiny sum it went for I am now wishing I had simply binned it.
    John
  13. eatmorepies
    tallbloke Guest
    WTF?
  14. eatmorepies
    raden Guest
    Best to go out and buy yourself a memory stick
    What mode is LPT1 set to in the BIOS ?
    raden, May 2, 2005
  15. eatmorepies
    gomez Guest
    Do *not* use the driver on the supplied floppy with XP. The W2K
    driver you can dowload should work just fine (does for mine).
    gomez, May 3, 2005
  16. Who are cunts of the first, order should you ever have any problems
    with tat they sell.
    Boots Blakeley, May 5, 2005
