[QUOTE] Eh? It's measured, but it can't measure?[/QUOTE] No, it's calculated based on what actually is "measured" (or more accurately specified by the efi). The efi opens the injector for a period according to what it's lookup table tells it is the right amount given the parameters it has sensors measuring. It ASSUMES the fuel pressure (and hence fuel flow) is correct (unless there has been some new fangled advances in EFI I'm not aware of). I know of no cars that measure actual fuel flow, they usually calculate your fuel consumption based on the amount of time they've opened the injectors, and the number of KM's travelled. Those two parameters are based on a number of implicit assumptions: - the fuel pressure is correct - there are no blockages restricting fuel flow - the size of your tyres are as specified and hence the number of K's calculated is correct etc etc it's a reasonably accurate estimate and more than good enough for the purposes for which it is used. That doesn't mean the actual fuel flow is measured. JL
