P plate training ...not
Discussion in 'Australian Motorcycles' started by alxr, Feb 5, 2007.
  1. alxr
    jlittler Guest
    errm in line with the definition of a poofteenth, you've unfortunately
    been sucked in by a common misconception
    http://en.wikipedia.org/wiki/Deux_Chevaux
    The 2CV had 2 *TAX HP* - the bottom of the range 375cc twin produced
    about 9HP (ie BHP/DIN).
    Both England and France had tax HP ratings around this period - they
    were basically statutory calculations and led to some odd engine
    designs to minimise tax in England (long stroke small bore were
    cheaper than short stroke motors of the same capacity)
    http://en.wikipedia.org/wiki/Tax_horsepower
    JL
    jlittler, Feb 9, 2007
  2. I wonder... I'm sure you know more about how well it's calibrated then
    me, but I suspect it's probably got enough resolution to see 1% changes
    in the flow rate even if the numbers it displays aren't all that
    relevant - I _think_ the fuel injection system would be representing a
    real world flow rate increase of 1% when the display changes from 10.0
    to 10.1 at a constant speed, even it it's not actually flowing 10L/hour
    (or whatever) at the time...
    big
    Iain Chalmers, Feb 9, 2007
  3. Fair enough, so maybe it's only 3 and a bit percent - my point still
    stands (and if it was anyone other than disingenous-hammo arguing wiooth
    me I'd consider apologising...)
    big
  4. alxr
    atec Guest
    The way I understand it that statement is wrong , mechanical input
    required to generate electrical energy bears relationships to each
    other, more electrical energy required means more drive is required to
    overcome the resistance to turning .A change in turning momentum is
    proportional to energy required.
    atec, Feb 9, 2007
  5. alxr
    jlittler Guest
    Point ! Point well made.
    JL
  6. alxr
    jlittler Guest
    And your statement is indeed correct - there's a difference between
    the mechanical input and the mechanical load. Pure semantics of
    course. mechanical load (as torque) plus electrical load(as torque)
    equals mechanical input required(as torque). The mechanical load is a
    constant (ceteris paribus), the electrical load changes with, well,
    the electrical load <grin> (1). To be more accurate the torque/turning
    force that you have to provide to generate a current equal to the
    current being drawn is increased as the current required increases(2)
    JL
    (1) there obviously being more than one meaning of the word load in
    this context - one being current drawn, the other being turning force
    required
    (2) still not sure I'm explaining that particularly well
  7. alxr
    Theo Bekkers Guest
    I think he's saying that if you turn an alternator with no load and with
    full load, no extra power input is required. That must be why our back-up
    gen-set gets louder when we put the air-con load on it. 3.9 litre John Deere
    with a 3 phase 44kw alternator.
    Anybody want to tell me it doesn't use more fuel when we load it up to 40
    kw?
    Try holding one of these permanent magnet alternators in your hand and spin
    the rotor with your other hand. Easy isn't it? Now twist the output wires
    together and give it another spin. That would be max load. What do you mean
    it stops dead? It surely doesn't require more turning force?
    Simple brakes for an induction motor is to short the terminals together.
    This is wired into a lot of machinery. Stops very quickly. An induction
    motor is the same design as your perm magnet alternator.
    Theo
    Theo Bekkers, Feb 9, 2007
  8. alxr
    Theo Bekkers Guest
    What kind of a bus is that?
    Those of us that agreed with you understood it.
    Theo
  9. alxr
    Theo Bekkers Guest
    Isn't petrol just very old solar power?
    Theo
  10. alxr
    Theo Bekkers Guest
    Well, as they do work as switch mode power supplies, it is not a total loss
    system and when you turn on the headlights you will use more, albeit only a
    tiny bit more, power from the engine, requiring more fuel.
    Theo
  11. alxr
    MrMoped Guest
    True, as a general rule the red ones are faster and this has been a concern
    to (most) motorcycle manufacturers worldwide.
    Having a fast red light at the rear of the motorcycle was a huge concern in
    the early days of motorcycling as it was soon realised that having a fast
    light (red) at the rear and a not-so-fast light at the front led to the rear
    of the motorcycle trying to overtake the front at every opportuity - this
    was deemed to be "not rider friendly".
    To counteract the power of the red light, a very mild or low wattage light
    was fitted to the rear whilst a stronger/higher wattage light was fitted to
    the front. This has worked very well.
    The ratio between front and rear light is very sensitive. A typical setup of
    60/55 watt high/low beam front light to 5 watt tail light works well in most
    situations but the addition of a 20 watt brake light has added an element of
    danger by making the motorcycle unstable. If you require proof of tis, try
    the following:
    - ride along (at any speed) with the mind in neutral and then apply the
    front brake as hard as you possibly can and do not ease off under any
    circumstances. The rear of the motorcycle will rise and continue rising
    until the red, rear light has overtaken the front. Some will try and
    attribute this phenomenon to the action of the brakes but that is not 100%
    correct. Squeezing the front brake as hard as you can imparts maximum energy
    to the faster red light. A similar effect can be achieved by applying
    maximum force to the rear brake.
    So yes the red lights are the fastest but they can be tamed with some
    (un)sound engineering practices so as not to detract from the motorcycling
    experience.
    MrMoped, Feb 9, 2007
  12. I wasn't going to shove my oar in again but that's such a good
    translation I can't resist it. Of course you have to spin the
    electricity generating thing faster if you want more electricity,
    nobody's arguing that you don't. What I was saying was that the
    increased electrical load does not cause engine RPM to drop, because it
    can't.
    Simple test: drive a test vehicle (use Nev's) to a stadium with lights
    and connect lights to a light circuit on the test vehicle (don't ask me
    how, there seem to be a gadmillion electrical geniuses in here, you lot
    figure it out). Step 2: turn on lights. If I'm wrong the test vehicle
    will stall. If I'm right the lights won't come on but the test vehicle
    will run normally.
    Andrew McKenna, Feb 9, 2007
  13. alxr
    atec Guest
    I will never agree to that ( I stick to what I know and have been taught)
    load is load , as in work to be done /required so whether explained as
    turning force or current drawn they bear a direct relationship of watts
    and where's consumed
    No you didn't , I suspect it's some bullshite machination dreamed up
    to split hairs buy a drunken masturbaterpoofta ( tell me if I am wrong)
    sounds a little like the wider tyre wont stick as well crap /
    atec, Feb 9, 2007
  14. alxr
    Toosmoky Guest
    No need. Our generators at work drop revs and sound as if they're under
    load instantly when we turn on spotlights connected to them. There's no
    doubt they'd be using more fuel.
    Of course, whether that's a "waste" of petrol depends on your point of view.
    I'm Toosmoky and that's my two bob's worth.
    Toosmoky, Feb 9, 2007
  15. alxr
    atec Guest
    In fact if you take an ungoverned motor driving a genny it will in that
    circumstance slow in revs due to load increase which is why a governing
    unit is used to maintain speed , now do you agree ?
    atec, Feb 9, 2007
  16. alxr
    One of the less talked-about "passions"........
    Knobdoodle, Feb 9, 2007
  17. alxr
    Now that you mention it; I think I read that the Qld electric and
    diesel-electric trains use this system for brakes.
    The added advantage is that without turning there's no back-EMF so they're
    essentially anti-lock.
  18. alxr
    Nev.. Guest
    My figures were measured at the bowser, rather than relying on the trip
    computer, which invariably shows worse fuel consumption than reality.
    The odometer and speedo in the car are near enough to accurate, plus or
    minus 1kph or 1% or so.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 9, 2007
  19. alxr
    My old mach111 certainly used to conform to this principle!
  20. alxr
    Quantify "measured".
