P plate training ...not
Discussion in 'Australian Motorcycles' started by alxr, Feb 5, 2007.
  1. alxr
    Nev.. Guest
    I pity the yanks who don't get irony. Isn't it delicious :)
    GB's comment above posted @ 09/02/07 12:08
    GB's comments below posted @ 09/02/07 12:27
    http://groups.google.com/group/aus.motorcycles/msg/fed79a10fae34514
    (but be quick.. his post will expire from the google archive in 6 days)
    Nev..
    '04 CBR1100XX
    Nev.., Feb 10, 2007
  2. alxr
    Nev.. Guest
    I think you're drawing conclusions based on false assumptions.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 10, 2007
  3. alxr
    Hammo Guest
    Oh dear, do you also need a whhooossshhh to go with the Cpt Ob? All
    measurement is going to inaccurate and is therefore an estimate. See below
    re: Analytical measurement, ISO, NATA etc.....
    Have you forgotten all that horrible stuff in labs where I'd generate a
    number and also error bars showing the "tolerance" of that answer?
    Did you miss Nev's point (or Theo's, or someone's) that the readout was 4
    significant figures, which had had the potential to either show that 1)
    there is no effect, or 2) it is so small more significant numbers were
    required?
    You can see things no-one else can, hmmmm.
    ....and what do they smell like?
    Hammo
    Hammo, Feb 10, 2007
  4. alxr
    Ahh; so I've said some conditions are measured but that the fuel is not
    measured and you wanna' pretend that means I said "the fuel is measured" do
    you?
    Good luck with that.
    Knobdoodle, Feb 10, 2007
  5. alxr
    Yep; that's pretty much how automatic systems go.
    If X isn't under pre-defined range for X, increase X by Y and then check
    again. If X is over; decrease by Z.
    Repeat several times per second as necessary.
  6. alxr
    Ahh ... it's a quote.
    Dammit [makes an exaggerated "foiled" motion]; I shoulda' known it was too
    easy!
  7. alxr
    Come off the grass Hammo; Blind Freddie's seeing-eye-dog's fleas can see
    you're trying diversion after obfuscation!
    That's why we keep repeating the obvious and logical with every reply.
    Standard Operation Procedure.
  8. Sing along with me now (al la Summer Holiday)
    "Hammo's playing Devil's Advocate
    Trying to get bites from one or two
    He'll keep going 'til you lose your rag with it,
    Pedantic bantering keeps him sane
    There's nothing you can do"
    K
    H - clear your email so I can message you off the newsgroup
    Kathryn Vickers, Feb 10, 2007
  9. FFS Clem, the amount of energy you're putting into pretending to be
    stupider than you are would power your entire house for a week!
    I chose the most primitive electrical system example I could think of,
    an old-fashioned dynamo driven by the rotating wheel of a push-bike. I
    figured most aus.moto posters would know what that was.
    At any point in time that dynamo delivers a precise amount of electrical
    current which is determined by the rotation speed of its shaft, which is
    in turn controlled by the rotation speed of the bicycle wheel. Spin the
    bicycle wheel faster, you get more current; don't spin the bicycle wheel
    at all and you don't get any. (If I was arguing with Hammo I'd have to
    explain which bicycle wheel was being used and what was the tyre
    pressure, and whether the dynamo had static or moving magnets, but I
    don't have to do that with you, do I?)
    With the cyclist pedalling at maximum speed, engage the dynamo. The bike
    slows down because the human pedalling has to overcome both the inertia
    of the rotor in the dynamo (this is actually negligible) and the
    resistance of the magnets to being dragged through an EMF. At this new
    maximum speed, the dynamo produces, I dunno, say 2W of power. Presently
    all this electricity is doing is going round and round, so let's add a
    1W light.
    This magical light has no mass (so we don't have to get into arguments
    about it's contribution to inertial resistance on the bike) but it
    demands 1W of power, so since the dynamo is providing 2W it's using
    half. How much physical resistance have we added to the system? Nothing
    whatsoever, so the cyclist isn't required to do extra work (but see 'The
    World According To Clem' below). Let's add another one.
    Now we're using the total generating capacity of the dynamo, all 2W. How
    much harder is it for the cyclist to push along with the lights on? No
    harder than when they are turned off. It isn't the lights that increase
    his effort, it's the dynamo itself. Let's add 20 more lights.
    In the world according to Clem, the dark energy flowing out of these
    extra 20 lights travels down the wires to the dynamo and supersizes the
    magnets, causing the dynamo to seize, the front wheel of the cycle to
    stop and the cyclist to fall off.
    In the world according to Andrew, the extra 20 lights simply never light
    up (or, if they are wired up in parallel, all the lights go out).
    In theory the dynamo can be spun up to velocities that will deliver more
    than 22W. In reality no cyclist can pedal anything like that fast.
    Now tell me again which bit of my earlier post you found hard to
    understand. If it was the bit where I asserted that in order to get more
    electrical power out of a dynamo you had to spin it faster (as it
    appeared from your comments), I can't help you.
    Andrew McKenna, Feb 10, 2007
  10. alxr
    Hammo Guest
    Obfuscation, that is a long bow to draw. ...and it is standard operating
    procedure.
    You can repeat something till you are blue in the face and it won't change
    it. If by logical and obvious, you mean "it works for you" then I am happy
    that you have achieved your goal.
    I don't agree and therefore I'm going to point out what I consider to be
    logical [though not necessarily obvious]. For example are you aware of the
    grades of analytical glassware that is used to measure liquids? For you it
    is a moot point as you take the stance of lights on in the day is waste of
    fuel, where as I don't (depending on the DRL). There is no waste as I want
    it on and it does it's job well. Yes, it uses fuel, no it's not a waste.
    Crystal?
    Hammo
    Hammo, Feb 10, 2007
  11. alxr
    Hammo Guest
    Yes, and if I wanted and answer that was based on speculation......
    This is called speculation, or assumption. Do you know that that is the
    case with the fuel measurement? I can see and appreciate that the point is
    valid, though, I don't tend to go with the the popularist vote in order to
    be ice box, man.
    Also, I was referring to significant figures, not decimals. See lab work
    (above and as you pointed out unneeded complexity, surely that'd be a
    given?).
    No, you claimed it was nought more than a red herring. Your
    wording/phrasing implied that you believed it to be a "scent-thrower".
    It was an attempt to discredit the standards by which things are measured
    and therefore calculated and "standardised". Pretty important.
    I was not going to commit any acts of criminalality. I was asking if you
    were having olfactory hallucinations with the visual ones.
    Hammo
    PS Did you consider the lubricity of diesel vs ULP in measurements?
    Hammo, Feb 10, 2007
  12. alxr
    Hammo Guest
    Oi, **** off newbie!
    Hammo
    ....whilst you're at it, are the wires insulated?
    Hammo, Feb 10, 2007
  13. alxr
    Nev.. Guest
    OK so I went out to my car, on a different day, in different weather
    conditions and the above measurements all replicated.. surprising since
    some people have been so adamant that the system which measured them
    wasn't accurate, reliable or repeatable.. but anyway..
    Fuel flow increases from 2.68L/hr to about 3.2L/hr
    stays the same after a momentary flicker no more than ±20RPM
    Turning the lights on and off with the aircon turned on made no
    difference to the fuel flow rate or the engine RPM.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 10, 2007
  14. alxr
    jlittler Guest
    ATEC or Andrew ? Or are they the same beast ? I've not noticed the
    Andrew character before. Or are you being really subtle and meaning
    yourself :)
    The interesting part was Andrew's statement that you were pissing on
    was actually (pedantically) correct. I think he proved himself
    clueless in the later post (I lost interest) but he actually threw in
    an interesting (extremely minor) - it just seemed like a good
    opportunity to engage in pointless esoteric argument as we do so well
    here !
    JL
    jlittler, Feb 10, 2007
  15. alxr
    Dale Porter Guest
    Is she ever! I grew up with a father who plays devil's advocate at every opportunity, and is far better at it (and far less obvious
    about it) than Hammo.
    Dale Porter, Feb 10, 2007
  16. alxr
    Ain't no surprises there Katho; so long as you wrestle the greasy pig and
    don't let it run anywhere but the course-du-jour there's no problems.
  17. alxr
    jlittler Guest
    While patently true, there's a difference between obstinately arguing
    an inaccurate, irrelevant or indefensible point and being a devil's
    advocate that Hammo always seems to miss
    JL
  18. alxr
    JL Guest
    No argument, but there's load and then there's load. The mechanical load
    created by the metallic bits being persuaded to whirl in circles is a
    constant. AFAIK, the EMF created load (which requires mechanical effort
    on the input part of the device ie the pulley, for you slow boofheads
    who are missing the point) is proportional to the amount of electrical
    current load.
    The fact that I've had to repeat this thrice pretty much reminds me why
    I classify you with toosmoky as someone who's pointless to have a
    discussion with (hell, actually, even *he* got it, so where that leaves
    you on the comprehension scale is somewhere around the average orangutan
    I guess)
    DUH ! I said that, in fact if you think about this bit, and the bit
    you're half agreeing with below, you'll see you're contradicting
    Oh jesus fucking christ, i know what "machinations" means, trying
    googling up what "latter" means. I was referring to your made up word
    "masturbaterpoofta"
    JL
    JL, Feb 10, 2007
  19. alxr
    Magnetism and Electromagnetic Force works for me Hammo.
    I'm happy and I'm sure that it's happy that you're happy about it too!
    I can't see no diversion or obfuscation here Cheif Inspector!
    And of course this isn't what we were talking about and it also was covered
    about 30 posts ago when I said "If the lights are serving a purpose then the
    fuel isn't being wasted".
    No; chrystal would be a waste.
  20. alxr
    JL Guest
    Because a human told it what to do, if these parameters are measured
    (which don't include measuring fuel flow), then do x.
    Uhuh, it sticks it's metaphorical finger in the air and makes it's best
    guess, based on the things it does know. It's usually a pretty fair
    estimate to, same as when I walk outside, wave my arms around a bit and
    say "I think it's about 22, 24 degrees celsius this morning"
    In my experience, yes, yes very definitely.
    JL
    (it's always impressive to put 16L into a 15L tank I think)
    JL, Feb 10, 2007
