P plate training ...not
Discussion in 'Australian Motorcycles' started by alxr, Feb 5, 2007.
  1. alxr
    sharkey Guest
    Hooked up to the injector drive, yeah, you could get a pretty accurate
    _relative_ measure of fuel consumption, maybe +/- 1% if you really
    worked at it. It's not quite the right tool for the job, but it's
    close.
    Hammo wanted to establish that bike regulators are no longer shunt
    regulators like old Truimph "zeners".
    Actually, I think I can establish that more easily with a half-decent
    thermometer: if the regulator is switch-mode, its heatsink temperature
    should go _UP_ slightly under headlight load, whereas if it's shunt,
    its heatsink temperature should go _DOWN_ under headlight load.
    Doing this experiment is left as an exercise to the reader.
    ------sharks
    sharkey, Feb 13, 2007
  2. alxr
    jlittler Guest
    Nice spin, if you'd like to connect the quote in context with the
    meaning, you'd extrapolate that as me saying "in a domestic situation
    noone could be arsed doing that test"
    Which is pretty much what I would say :)
    JL
    (to paraphrase someone in this thread - "you buy a 5.7L V8 you don't
    give a shit about fuel consumption accuracy plus or minus a litre or
    2)
    jlittler, Feb 13, 2007
  3. alxr
    jlittler Guest
    <raised eyebrow> Who said you needed a fuel flow measurement to
    improve fuel economy/efficiency ?
    JL
    (I've said repeatedly you can't make assumptions about a multitude of
    things, calculate a fuel flow and then claim you know it's
    particularly accurate though)
  4. alxr
    Hammo Guest
    I still argue thimbles, though no body cares, I'd go for an order of
    magnitude lower. I cannot differentiate between the fuel use with lights on
    vs lights off. Air-conditioning is an all together different matter.
    Hammo (I'll post my calcs when I get back home, probably after I post the
    belated pics of roadside furniture to Theo).
    Hammo, Feb 13, 2007
  5. alxr
    Hammo Guest
    Heh, you working for Slick50? That is the quality of their comparos too!
    You see. You have spun yourself!
    I'd say buy an X L V8 if you were inclined to towing loads where vehicle
    mass and torque were concerns. Fuel consumption and it's measure would not
    be a focus.
    Hammo
    Hammo, Feb 13, 2007
  6. alxr
    Hammo Guest
    Cold beers at the Wig and Penn..... Bye.
    Hammo
    Hammo, Feb 13, 2007
  7. alxr
    Hammo Guest
    You've really done it now, Sharkey, Now you'll have to be on my side!
    Hammo
    "We've got videos to talk about, haven't we, Mike?"
    Hammo, Feb 13, 2007
  8. alxr
    Hammo Guest
    Thank you, Mr Echo. Your support is much appreciated.
    Hammo
    Hammo, Feb 13, 2007
  9. OUT!
    15 - love to Hammo.
    big (Yeah, I fell for one of his sucker lines upthread too...)
    Iain Chalmers, Feb 13, 2007
  10. alxr
    Theo Bekkers Guest
    So because you can't differentiate the fuel use there is none?
    A lounge suite in a layby?
    Theo
    Theo Bekkers, Feb 13, 2007
  11. alxr
    Hammo Guest
    On observation, that is currently true. However.......When I finish a PM
    shift and drive the 3 and bit hours home in the dark (headlights on) the
    fuel consumption has been equivalent if not better than during the day
    (headlights off).
    I change into top and then don't down change again until 3 kays from home
    where I need to negotiate a sharp turn.
    I've been looking to put a cruise control in so that human error can be
    minimised wrt throttle input.
    No, that discussion about lamps, sign posts and road markers. They are all
    roadside furniture. I even went along to be involved with the taskforce
    that investigated and reported via the inquiry into road deaths in rural
    Victoria.
    I took some pics as I couldn't get hold of the photohgraphs I wanted to show
    you (i.e. Theo).
    Hammo
    Hammo, Feb 13, 2007
  12. alxr
    jlittler Guest
    Ahh I always knew you were a politician not a scientist - Howard
    really should employ you, I've never know such capability to ignore
    intent and pretend to hear something different to what was said.
    So I ask again WHO SAID you needed a fuel flow measurement to
    Knock that straw man down you set up Hammo.
    JL
  13. I'll be interested to see them. I'm still reasonably sure about my
    numbers, with the proviso that I'm basing them on a bunch of
    unsupported wikipedia values...
    The forst wikipedis value is for the energy content of petrol at ~32MJ/L:
    http://en.wikipedia.org/wiki/Gasoline#Energy_content
    Joules are easily expressed in Watt hours, so Watt hours can be
    expressed in L of petrol.
    1 Watt Second = 1 joule
    1 Watt Hour = 3600 Watt Seconds = 3600 joules.
    120 Watt hours = 432,000 joules (120*3600)
    So if everything was 100% efficient that'd be .0135L (432,000/32,000,000)
    But wikipedia says alternators have an efficiency "between 50 and 62%"
    http://en.wikipedia.org/wiki/Alternator#Automotive_alternators
    So lets use 55% and increase our fuel requirements by 1/0.55 to 0.0245L.
    Now we make one more trip to wikipedia to find out how efficient the
    internal combustion engine is, and they tell us "It is generally
    accepted that most gasoline fueled internal combustion engines, even
    when aided with turbochargers and stock efficiency aids, have a
    mechanical efficiency of about 20%."
    http://en.wikipedia.org/wiki/Internal_combustion#Engine_Efficiency
    So we need to multiply our fuel requirements by another factor of 5 to
    get 0.12L of fuel used for each hour of generating 120W of electrical
    power using an automotive alternator driven by an internal combustion
    engine. I'm guessing my errors are around +-40% (20% in the alternator
    efficiency figure and another 20 in engine efficiency one).
    Lets do a sanity check on that. Honda make little generators which are
    actually dc alternators with inverters (click the "Inverter" link in the
    left column of the webpage below for details). The 1000W model,
    http://www.hondapowerequipment.com/ModelDetail.asp?ModelName=eu1000i has
    got a 0.6gal/2.27L tank and they claim that it'll run for 3.8 hours @
    rated load and 8.3 hours at 1/4 load" so they're saying 0.6L per hour
    for 1000W or 0.27L/hour for 250 Watts - that last figure looks pretty
    damed close to my calculation of 0.12L/hour for 120W... (the full load
    figure is clearly running somewhat more efficiently though, but still
    within my stated error range)
    I reckon you must have pretty big thimbles...
    big
  14. You've also accounted for different air temperatures and densities (both
    in terms of the engine combustion process and the aerodynamic effect)?
    You've averaged the observations over trips from home in the dark and
    light as well as to home in the dark and light (to remove any elevation
    changes)? If you've done this then presumably you've checked the tire
    pressures and wheel alignment regularly during the test procedure? And
    kept the air-con off so differing compressor cycle times due to
    different outside air temperatures wouldn't affect the results? Is there
    a typical prevailing wind speed and direction in the area of the trip,
    and is it the same for both day and night trips?
    My numbers suggest you're looking for something like a half or one
    percent increase in fuel consumption at highway speeds in a car that
    averages around 15L/100km. I think _lots_ of other things will have
    effects that overshadow it, but I honestly believe if you _were_ careful
    enough in your measurements you'd see a real-world cost of ~0.35L over
    your 3-ish hour trip if you do it with headlights on. My experience is
    that I never get repeatability to anything better than about 10 or 20%
    in my fuel useage even when I think I'm doing exactly the same trips, so
    I'd only expect it to show up "in observation" through application of
    some effective statistical methods over many many trips...
    big
  15. alxr
    jlittler Guest
    Rooobish !! I'm appealing to a higher court.
    Theo - there's nothing higher than an ivory tower, what say you ?!
    JL
  16. alxr
    jlittler Guest
    Maaaaateeee ! Have I got a deal for you - buy a case and I'll throw in
    a set of steak knives !
    Around around the mulberry bush, like a tickly bear(1)....
    XLV 8, hey, is that the new Honda replacement for the transalp ?
    800cc's ?
    JL
    (1) Bloody hell I'm turning into a parent, scary.
  17. alxr
    Moike Guest
    er... John... you *do* realise you've let yourself get sucked into one
    of Hammo's 'arguments', don't you?
    Moike
    Moike, Feb 13, 2007
  18. alxr
    Nev.. Guest
    How do you know ?
    Nev..
    '04 CBR1100XX
    Nev.., Feb 13, 2007
  19. alxr
    Nev.. Guest
    "Every"? I never learned that in Yr 8 Science. I think you need a more
    accurate device for measuring Year 8 Science students. :)
    Nev..
    '04 CBR1100XX
    Nev.., Feb 13, 2007
  20. alxr
    Nev.. Guest
    No no no. Having an accurate measurement device for buses does not
    automatically make any other measurements automatically flawed. You
    have once again made an unsubstantiated allegation and pretended that
    it's true. You have yet to establish that the car measuring device is
    less sensitive or accurate, other than by merely saying that it is.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 13, 2007
