[QUOTE="Hammo"] No. Thanks for trying to bluff that one. Remember the discussion re: torque......[/QUOTE] I'd given up on the torque discussion since you were clearly not going to admit that you don't understand how a typical automotive alternator _can_ present different input torque loads at the same rpm thanks to the existence of it's rotor windings and the variable current the regulator can run through them. It's easy enough to understand - more current = stronger magnet -> stronger magnet = more force -> force going round in circle = torque. I'm astounded you're continuing to play stupid enough to not understand that. But it doesn't matter - I'm arguing this one purely on energy in vs energy out using some publicly available estimates of efficiency and some assumptions about the errors in them. You're a chemist right? You know about energy and energy conversion and stuff? You know, _real_ energy, measured in joules? That "can't destroy it can only convert it from one form to another" kind of energy? Probably way better than I do. Dispute my numbers or point out the errors in my methodology. Or man up like Sharkey did and admit you're wrong. Or don't. Whatever.[QUOTE] GS mentioned speed as a way to suggest that the figures were in agreeance. Perhaps you missed that? Perhaps you missed the 12 v vs 24 v comment as well?[/QUOTE] So you're suggesting that 1000 12V watts are somehow different from 1000 24V watts are you? Or that 1000W at 800rpm is a different amount of power to 1000W at 5000rpm? That's some good stuff you've been smoking since you left uni if that's what you believe these days... [QUOTE] Yeah, I mean, lets *not* consider efficiency..... Obfuscation ahoy!![/QUOTE] Hammo? Put down the crack pipe and open the window, dude! Or, on the slight possibility that you think that statement made any sense at all... First define your terms. Explain to me exactly how you intend to measure the efficiency with which a 60W light globe consumes 60W? Or are you somehow suggesting that my wikipedia-ed up efficiency estimates for the engine and alternator efficiencies and my estimates of the errors likely to be associated with them are somehow "obfuscating" the issue? Or are you on crack? [QUOTE] As I said, when I get home. I'm still 400 odd kays and coupla days from that.[/QUOTE] You'll excuse me for being sceptical that you'll actually post any calculations that show us how wrong you are... (with your current posting style, I'm pretty sure you won't actually be capable of doing any calculations...)[QUOTE] BTW, I looked at your numbers again, as well as your assumptions, can you tell me why you are getting the same consumption figure regardless of speed, regardless of engine rpm?[/QUOTE] Yep, 'cause the energy consumed by the headlights is independant of the engine rpm and road speed - at least to a first (+-40%) approximation. See above. Go get your 1st year physics textbooks back from the hockshop and read the first couple of chapters again... big
