P plate training ...not
Discussion in 'Australian Motorcycles' started by alxr, Feb 5, 2007.
  1. alxr
    Toosmoky Guest
    Nice one, centurion. I'm wondering if there's actually a case to be made
    that any fuel consumption increase/decrease is not even detectable in
    some engines.
    Given the large number of variables, it may be that the variance between
    any measurement of fuel used in one test compared to another may not be
    reproducible. In some engines.
    Toosmoky, Feb 14, 2007
  2. alxr
    Theo Bekkers Guest
    I'm not. Hammo plays stupid so well, sometimes I think it's not an act.
    No, no, no. Electicity from the alternator is free power, apparently. I
    wonder if I can run my house off it?
    Efficiency is the whole point, isn't it. Use 1 Kw, use no extra fuel to
    produce it. How much more efficient to you want. I don't understand why
    Western Power keeps sending me electricity bills.
    The light globe has a very accurately measured vacuum orifice, when the
    switch is turned on a 60W globe sucks 60 watts of electrickery from the
    wires. When all the vacuum runs out, the globe stops working and you need to
    buy a new one. A good globe should last 2000 hours, meaning it initially
    contains 120Kw of vacuum. If you buy one of those cheap globes from K-Mart,
    you get gypped on the vacuum, this is why they don't last so long.
    Theo
    Theo Bekkers, Feb 14, 2007
  3. alxr
    Toosmoky Guest
    There's the Australian-made Barbarian now. Like a Boss Hoss, only better
    built.
    I'd love one of those with the alloy Chev donk.
    I remember when I was younger you'd pay twenty grand U.S. for a bare
    alloy Chev block from Keith Black. Now you get 'em in family cars off
    the showroom floor...
  4. alxr
    Theo Bekkers Guest
    That sounds like a come-on. I'm going to tell Vickers.
    Theo
  5. alxr
    sharkey Guest
    Yes, and, your point was? Big's calculations seem pretty sensible to me
    as back-of-the-envelope estimates go. They agree near enough with G-S's
    experiment, and if G-S repeated his measurements a few times back and
    forth then it's not such a bad experiment. "The lights use energy, and
    that energy has to come from the fuel" seems pretty justifiable,
    thermodynamically speaking.
    There's the issue of shunt regulation, still, and for a shunt regulated
    vehicle having the lights on or off won't make any difference. I'm
    still looking into this, I know there are modern switch-mode regulators
    for bikes (the EnDuraLast generator kit used one) but I don't know when
    or whether they were widely adopted.
    The XLV regulator, which seems to be a pretty typical eighties Honda
    design, is actually kind of a "switch-shunt" regulator, in that it seems
    to shunt the phases with SCRs. This would cause 90% of the voltage
    drop (and thus the waste heat) to be across the generator coils rather
    than the SCR junction. This heat would be taken away by the engine oil.
    The EnDuraLast one I mention is "switch-series", and when I get the XLV
    running again I'll try some experiments and maybe replace the regulator
    with a better one.
    Anyone got one of the infamous VFR regulators handy if I can work out a
    simple test to tell the difference?
    Humour me. I'm feeling very stupid today, and I can't work out whether
    you think you have a point or you're just trolling on.
    -----sharks
    sharkey, Feb 14, 2007
  6. alxr
    Theo Bekkers Guest
    You don't appear to understand the term 'idle' in realtion to buses. Buses,
    and diesel trucks, have an 'idle' adjust under the dashboard.
    Do any of those systems generate power without using any fuel?
    Theo
  7. alxr
    sharkey Guest
    Yeah mate, just to look at the pulse widths: you can't tell a hell of a
    lot (especially given the +/-10% or so tolerance of the injectors) but
    it should give you a nice relative figure. Rather than using a manual
    CRO it'd be better to feed all the signals into labview or similar and
    sum the pulsewidths from each cylinder over time.
    I'll try not to post sensible bits too often so as not to confuse you!
    -----sharks
  8. alxr
    Theo Bekkers Guest
    Our friend Hambone thinks he is playing Devil's Advocate, but doesn't appear
    to have grasped the point that a Devil's Advocate argues the opposite
    viewpoint. Hambone thinks it means talking about something totally unrelated
    to the original debate.
    Theo
  9. alxr
    Theo Bekkers Guest
    There's a couple in WA. Well, less one. Some guy managed to kill himself on
    one, but surely that was expected?
    Theo
  10. alxr
    sharkey Guest
    Different music on the radio, too!
    Professor G-S's experiment is actually pretty controlled, by comparison.
    -----sharks
  11. alxr
    Theo Bekkers Guest
    MacQuarie Concise Dicctionary
    agreeance/uh'greeuhns/
    noun agreement.Usage: This word has recently come into occasional use in
    place of agreement in phrases such as in agreeance with and with your
    agreeance. It actually dates back to the 16th century.
    Theo
  12. Hamish, you're full of shit.
    big
    Iain Chalmers, Feb 15, 2007
  13. Yeah, he's in one of his moods...
    Can someone post up a new thread if anything interesting turns up in
    this one (particularly if Hammo actuallly does any calculations that are
    actually relevant to how much fuel headlights use)?
    big
  14. alxr
    Nev.. Guest
    How does it go? "Look at the silly monkey."
    So lets see the score.. before.. G-S and Clem were right.. and GB was
    wrong. Now apparently GB and G-S are right, and Clem, (Who did the
    experiment on EFI vehicles and found that the revs DID drop, completely
    contraditing your latest assertion) is wrong... so that would make
    Hammo right, and he agreed with me to some extent, so I must be right.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 15, 2007
  15. alxr
    Nev.. Guest
    I can't find 'dammit' in my Pocket Oxford. Who'd you learn that from...
    Robin Gray?
    Nev..
    '04 CBR1100XX
    Nev.., Feb 15, 2007
  16. alxr
    jlittler Guest
    ;-P to you and Theo both !
    JL
    damn it Janet.
    jlittler, Feb 15, 2007
  17. alxr
    Just covering all the possibilities Nev; no matter how unlikely!
    Knobdoodle, Feb 15, 2007
  18. alxr
    [scrunches up brow]
    What on earth are you Hamsturbating about now?!!?
    When the engine is idling and you switch on the lights the RPM drops.
    On the older car car it stays down and on the other it then returns to the
    original idle speed.
  19. alxr
    Perhaps.
    Low-wattage lights, dodgy regulators, slipping fan-belts and low-power
    alternators would also contribute to it being hard or impractical to
    measure.
    Doesn't change the principle though.
  20. alxr
    Actually it's the bloke who's trying to score points by doing silly
    selective quoting who's looking like the goose at the moment Nev!
