P plate training ...not
Discussion in 'Australian Motorcycles' started by alxr, Feb 5, 2007.
  1. alxr
    Toosmoky Guest
    Aren't options one and two the same?...
    Toosmoky, Feb 16, 2007
  2. alxr
    Hammo Guest
    Plonk
    Hammo, Feb 16, 2007
  3. alxr
    Hammo Guest
    It was benign to begin with as per the "special magic hat". Then when it
    wasn't a "my dad take me to (insert Merkin restaurant), he's better than
    yours..."
    That is a different spin. Cheers
    H
    Hammo, Feb 16, 2007
  4. alxr
    Hammo Guest
    So, you think I was trying to elicit guilt? Am I missing something? I
    don't follow the logic.
    Hammo
    Hammo, Feb 16, 2007
  5. alxr
    Dale Porter Guest
    I'll assume you were actually meaning to reply to Clem there.
    Dale Porter, Feb 16, 2007
  6. alxr
    Hammo Guest
    I don't follow the logic and this should have been kept offline. I find the
    insinuations despicable.
    Hammo
    Hammo, Feb 16, 2007
  7. alxr
    Well I'm not feeling PARTICULARLY tantalised but without a circuit there is
    no current (only potential).
    No current in the stator means that there's no electromagnetism so nothing
    is opposing the spinning of your fixed magnets.
    Allow current to flow by providing a circuit (from the negatively-charged
    side of the stator-coil to the positive side) and there can be
    electromagnetism and thus repulsion. The "shorter" the circuit (i.e
    brighter bulb) and the more the current and the more the resistance.
    The problem is that the voltage is, as you point out, still dependent on the
    revolutions so you're still gonna' have a dim headlight if you're pedalling
    slowly.
    Enter the electromagnetic rotor and the regulator which sends a certain
    amount of voltage to the rotor-coil (it's a fixed resistance so the only way
    you can vary the current is by varying the voltage).
    Now if you want a brighter headlight at low revolutions you whack a big
    voltage onto the rotor, hey presto; more magnetism and more current in the
    stator and in the headlight but heaps harder to pedal (because the output
    energy is still coming from your legs; you're just changing the "gearing")
    The flip side is that the regulator can back it right off when you're
    spinning at high revolutions so you don't blow your bulb.
    The MCG situation is like fitting the brightest bulb you can find (or
    virtually a short circuit).
    Now the alternator current in the stator is at it's absolute maximum and
    magnetic repulsion at it's strongest so it hardest to turn.
    Whether or not it can actually light the lights though depends on the
    resistance of the circuit (and the thickness of the wires)... as well as
    your aforementioned revolutions.
    A 55W 12V headlight has a 2.6 ohm filament (it actually changes as it heats
    up but that's not important at this stage) so an alternator needs to feed it
    4.6 amps to light it.
    The stator coils themselves have some internal resistance (say .26 ohm) so
    the alternator has to generate 13.2V (or more) because at 4.6 amps it's
    unavoidably wasting 1.2V on ITSELF (Total circuit resistance is 2.6 + .26
    ohms so the 13.2 gets shared 2.6/.26ohm = 12/1.2V)
    No big deal so far; but plug in the MCG and your "headlight" resistance
    drops to .01 ohm. (or whatever would be required to run 20,000Watts of
    theoretical lights a theoretical 12V super alternator).
    Now your total circuit resistance is .27 ohms, the circuit current is
    52.8amps and the 13.2V gets carved up 2.6/.01 = 12.7/.5.
    Now you're only supplying half a volt to the MCG (at 53amps) so your lights
    are only 1/24th as bright as they're supposed to be and the other 12.7 volts
    (at 53amps) is creating heat and magnetic-repulsion in your alternator.
    You're doing a hell of a lot of work but you're not really achieving
    anything. (Much like I'm doing with this post!)
    Knobdoodle, Feb 16, 2007
  8. alxr
    Dale Porter Guest
    Yep I understand that. It's just that you replied to my post and comment, and as far as I can see I'm not insinuating anything of
    the kind. I don't feel guilty and I don't feel I was being led to feel so.
  9. alxr
    "And you're being hurtful when I was only trying to help....."
  10. alxr
    Naah; just drinking plonk wouldn't explain it!
  11. alxr
    Hmmm... You've got a point
  12. Not at all, Professor, you're doing fine. TFTH.
    Andrew McKenna, Feb 17, 2007
  13. alxr
    Dale Porter Guest
    Or maybe you know me. ;-)
    Dale Porter, Feb 17, 2007
  14. alxr
    sharkey Guest
    The _voltage_ is determined by the rate the magnets are spinning at.
    The _current_ is what causes the torque effect.
    The _power_ is voltage * current. When you're drawing no power, no
    current is flowing, so there's no back-torque.
    -----sharks
    sharkey, Feb 18, 2007
  15. alxr
    Dale Porter Guest
    But this NG is full of people that torque back.
    Dale Porter, Feb 18, 2007
  16. alxr
    Theo Bekkers Guest
    No, you don't. You prefer to go off at tangents.
    Theo
    Theo Bekkers, Feb 18, 2007
  17. alxr
    Theo Bekkers Guest
    Sounds like you're trying to elicit guilt Hamish.
    Theo
  18. alxr
    Arrgh gawd I'm gonna' look like a total sychophant here but;
    [hearty applause]
    Pure gold!
    Knobdoodle, Feb 19, 2007
  19. alxr
    I'm on the INside.
  20. Peter Cremasco, Feb 19, 2007
