P plate training ...not
Discussion in 'Australian Motorcycles' started by alxr, Feb 5, 2007.
  1. alxr
    Hammo Guest
    Joe Public should be keeping the scene clear of further accidents and
    keeping themselves and others out of D-> danger. Then contacting people
    with the skills to undertake a rescue if they don't know what they are
    doing.
    There is no need for others to get hurt.
    Do you think you would? Do you think you have to?
    Hammo
    Hammo, Feb 7, 2007
    #81
  2. alxr
    Boxer Guest
    My Commodore also rings for the Ambulance after an airbag deployment.
    Boxer
    Boxer, Feb 7, 2007
    #82
  3. In aus.motorcycles on 6 Feb 2007 14:54:36 -0800
    Sounds good to me.
    Silly to hide it in a thread about cars though.....
    Zebee
    Zebee Johnstone, Feb 7, 2007
    #83
  4. ???
    Inner west? Do tell...
    big (My local is the Golden Barley now...)
    Iain Chalmers, Feb 7, 2007
    #84
  5. Well you have got a rather large nose...
    big
    #85
  6. alxr
    CrazyCam Guest
    Nev.. wrote:
    Oh! OK, I didn't know that...sounds fairly reasonable. Thanks.
    regards,
    CrazyCam
    CrazyCam, Feb 7, 2007
    #86
  7. alxr
    CrazyCam Guest
    I do remember someone telling me that the top-of-the-line BMs had some
    kind of driver acknowledgment code, which, if it didn't get it after
    air-bags deployed, it would call 000.
    Does "the battery leads sever themselves with a pyrotechnic charge"
    sound scarey to anyone else?
    regards,
    CrazyCam
    #87
  8. alxr
    CrazyCam Guest
    Also agreed.
    "Would" or "have to" what?
    Hate standing by helplessly....yup, I think I would, but wouldn't have
    to. I could, perhaps, try to rationalise doing nothing much to help with
    thoughts like:"Car drivers deserve it."
    Stand by helplessly...dunno, depends so much on the circumstances.
    I think I have to at least stand by, by law.
    Or, are you asking if I would still try and take people out of a
    potentially lethal situation? In which case, I'd like to think that I
    would.
    regards,
    CrazyCam
    #88
  9. alxr
    Eh?
    It'll show that there's more load and that equivalent throttle settings
    result in lower revs.
    Therefore you would draw the conclusion that a higher throttle setting would
    be required to maintain the same revs and thus more fuel would be used in
    any comparable situation.
    What's the logic behind your "blows .. argument out of the water"?
    Knobdoodle, Feb 7, 2007
    #89
  10. alxr
    Nev.. Guest
    and at lower revs the engine would surely consume less fuel, not more :)
    Nev..
    '04 CBR1100XX
    Nev.., Feb 7, 2007
    #90
  11. alxr
    Nev.. Guest
    Can they really drop the windows in 0.04 sec?
    Nev..
    '04 CBR1100XX
    Nev.., Feb 7, 2007
    #91
  12. alxr
    Dale Porter Guest
    Only at idle without touching the throttle settings. But of course if you actually wish to drive the car, you will need to provide
    more fuel than normal to acheive the same motivation results as you did before putting more load on the system and engine.
    Dale Porter, Feb 7, 2007
    #92
  13. alxr
    Dale Porter Guest
    Think of it another way. Say you're on a health kick (YR!) and you're peddling away on an excercise bike. You have it set at a
    fairly low friction setting and are just peddling slowly. To peddle faster you apply more energy through your legs. However,
    increase the load via the friction setting and you need to use more energy to maintain the same speed.
    #93
  14. alxr
    Hammo Guest
    Er, no.
    The statement was that lights waste fuel.
    I have yet to see that it does.
    Hammo
    (...blinded by the obvious?)
    Hammo, Feb 7, 2007
    #94
  15. alxr
    Hammo Guest
    Either/or. Do you feel that you *would* help, or that you *have to* help if
    it was lethal to you?
    Interesting justification.
    Really? I can't understand why, unless, it was you (as in the driver) that
    caused the accident, then failure to stop would be an issue.
    Because, you believe it to be a "legal" requirement?
    Kind regards
    Hammo
    Hammo, Feb 7, 2007
    #95
  16. Your alternator doesn't have a feedback that regulates how much
    electrickery is produced - and therefore how much work the alternator is
    doing?
    Cheers
    PeterC [aka MildThing]
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    http://eladesom.com.au/ulysses/
    # 37181
    Peter Cremasco, Feb 7, 2007
    #96
  17. alxr
    Toosmoky Guest
    I have no reason to doubt it. They're not just dropped by gravity alone
    although I forget just how it all happens now. There was a lot to take
    in and I must admit I was somewhat amazed at the thinking that's gone
    into them. A lot of current cars have such features. One that I forgot
    about is an automatic fuel cutoff.
    One other feature that impressed me was that if the car senses that
    you're braking hard, it will apply additional force to the brakes to
    stop you in the shortest possible distance.
    Toosmoky, Feb 7, 2007
    #97
  18. alxr
    No; because I adjusted the idle back up so they both matched!
    (You must've snipped out that bit when you snipped out the bits about
    "comparable situation")
    Clem
    PS; I just tested the three vehicles with tachos (The Brumby and TU250 are
    tacholess)
    Gnat's car; 1991 EFI 1.5L 4cyl
    revs dropped by about 50rpm when lights on.
    Michelle's car; 2004 EFI 1.5L 4cyl
    revs dropped by a fair amount but then immediately climbed back to where
    they were (tacho had no real calibration but it felt like a bigger drop than
    gNat's car so I'd guess about 100rpm.)
    1987 K75 EFI 3cyl
    no noticeable change. The bike was cold and wouldn't idle real well to
    begin with so I don't say that was a totally definitive test though.
    #98
  19. alxr
    Where'd you get that statement?
    I thought he said that "headlights in daylight do nothing except waste
    fuel".
    If the lights are serving a purpose then the fuel isn't being wasted.
    #99
  20. alxr
    They do; every 40,000km the regulator automatically tells you that your
    alternator has been producing too much output.
    It's a Honda feature!
