P plate training ...not
Discussion in 'Australian Motorcycles' started by alxr, Feb 5, 2007.
  1. alxr
    Why quantify? It's either none or not-none.
    So far not-none is winning hands down!
    Knobdoodle, Feb 7, 2007
  2. alxr
    Hammo Guest
    Yep.
    So far there are those of us that have bikes that this is true of. There
    are those of us that have cars that this true of.
    Just need the amount of fuel being "wasted" to compare. Hope you have a
    small thimble to collect it in!
    Hammo
    Hammo, Feb 7, 2007
  3. alxr
    Hammo Guest
    Why? Why?
    If you can't quantify you may as well claim that it'll give you arse cancer!
    Hammo
    Hammo, Feb 7, 2007
  4. alxr
    Nev.. Guest
    A mic in the car which is tuned to listen for "FAAAAAAAAAAAAAAAAAAAAAAARK"
    Nev..
    '04 CBR1100XX
    Nev.., Feb 7, 2007
  5. alxr
    Does the amount make the fact any less a fact?
  6. alxr
    Moike Guest
    Hamish, I believe that the original statement was made not to disparage
    daytime headlight use because it was a serious waste of fuel, but to
    point out that such use was so ineffective that even the infinitesmally
    tiny amount of fuel consumed was more significant.
    HAND
    Moike
    Moike, Feb 7, 2007
  7. alxr
    OK; daytime headlights on will increase your risk of arse-cancer[1]
    BIG[2] arse cancer!
  8. It was a feature on the GS450 too. And for good measure, to make sure
    you didn't produce too much more electricity, it'd make sure your stator
    got fried too.
    Cheers
    PeterC [aka MildThing]
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    http://eladesom.com.au/ulysses/
    # 37181
    Peter Cremasco, Feb 7, 2007
  9. I think he's "taking the piss", Clem.
    Cheers
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    # 37181
  10. alxr
    Nev.. Guest
    Ok so I tested it myself.
    5.7 Lt EFI Holden in diagnostics mode.
    All Lights off idle speed ~803
    All Lights on idle speed ~803
    All lights off fuel rate 2.68L/hr
    All lights on fuel rate 2.68L/hr
    Yet to be convinced Nev..
    '04 CBR1100XX
    Nev.., Feb 7, 2007
  11. It may turn over at a constant rate, but it will need more force to make
    it turn over if it is producing electricity - or, in the case of an a/c,
    running the compressor.
    Cheers
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    # 37181
  12. alxr
    Nev.. Guest
    OK, so Clem has pointed out that this lights on = extra fuel business
    won't apply to my bike. You have pointed out that it won't apply to my
    car. Now you're trying to convince me using examples involving my
    bicycle...
    Nev..
    '04 CBR1100XX
    Nev.., Feb 7, 2007
  13. alxr
    No no; he said that the lights=drop-in-revs isn't happening in your car
    because the computer compensating by using MORE fuel (same as Michelle's car
    does but apparently more seamlessly).
  14. alxr
    Nev.. Guest
    But the diagnostics indicate that it's not using more fuel... or if it
    is, it's less than 1 decilitre per hour per 800 rpm, which is probably
    as close to negligible as it is possible to measure because even driving
    over a small bump on the road makes a much more significant change to
    the consumption rate.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 7, 2007
  15. alxr
    Wow; I wish I had "diagnostics" so I could defy logic too......
  16. alxr
    Hammo Guest
    ....yeah, but...
    The torque required to turn the pulley for the alternator is going to be,
    what? Bugger all. On the road at cruising speed (as in rpm) is higher,
    torque remains the same value. You'd probably be losing more fuel in
    resistance due to tyre pressure!
    Hammo
    PS I just tried it in my car and it used no fuel for the 10 minute I had
    the lights on!
    Hammo, Feb 7, 2007
  17. alxr
    Hammo Guest
    There are some things in this world that no-man should ever have...
    Hammo
    Hammo, Feb 7, 2007
  18. alxr
    atec Guest
    Bicycle is a good example , it becomes harder to peddle when more lights
    are added , more energy is required ( fuel) and there is the answer
    atec, Feb 7, 2007
  19. alxr
    Nev.. Guest
    hey don't blame me.. I just press this button here.. and that button
    there.. turn that thing there... and it all comes up on the dash...
    After reading your previous post I remembered my car had digital tacho
    and instantaneous fuel consumption available and I went out to the car
    expecting to be convinced you were right..
    Nev..
    '04 CBR1100XX
    Nev.., Feb 7, 2007
  20. alxr
    Nev.. Guest
    So the two vehicles in my garage with alternators are not good examples
    of how an alternator increases fuel consumption, but the only one
    without an alternator is a good example...
    Nev..
    '04 CBR1100XX
    Nev.., Feb 7, 2007
