P plate training ...not
Discussion in 'Australian Motorcycles' started by alxr, Feb 5, 2007.
  1. alxr
    Nev.. Guest
    I didn't say I didn't get it.
    Here are a few blank lines where you can explain how it figures out an
    hourly fuel flow rate without taking the time and the flowrate of fuel
    into account.
    The monkey powers the lights?
    Just because it doesn't, doesn't mean that it can't. Now you're just
    making shit up. And it is repeatable, to the extent that every time I
    start the car and let it idle, it gives the same result, give or take a
    poofteenth. I'm happy to accept that environmental changes would
    influence the result, so it's probably unlikely to get identical results
    under differing conditions.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 8, 2007
  2. alxr
    Nev.. Guest
    So for all intents and purposes, the amount of additional fuel consumed
    when the headlights are turned on is immeasurable, so this "lights on =
    more fuel" business exists in theory only.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 8, 2007
  3. alxr
    Hammo Guest
    When you pop over, feel free to show me that is what I have....
    Hammo
    I'll provide the magicians hat!
    Hammo, Feb 8, 2007
  4. alxr
    CrazyCam Guest
    Nev.. wrote:
    Well, in theory, theory and practice ought to be the same, but, in
    practice, they aren't.
    regards,
    CrazyCam
    CrazyCam, Feb 8, 2007
  5. alxr
    CrazyCam Guest
    GB wrote:
    This is, of course, a trick question.
    Everyone knows that a fridge is simply a heat pump, gathering heat from
    inside, and moving it outside, but... with the fridge door open, the wee
    light will be on, thus heating up the insides of the room.
    regards,
    CrazyCam
    N.B. the fridge will not use more petrol because the light is on, except
    if it is a petrol fired fridge.
  6. alxr
    Theo Bekkers Guest
    I have. Rented a Budget Ford Fiesta in England to get from Manchester to
    Heathrow to catch the plane home. At 5 in the morning on the M1 (I think)
    engine died. Coasted to an emergency phone. Can't call budget from them.
    Looked under the bonnet, took top off distributor. No contact there, as in
    missing altogether. Got the RAC out. Some genius had adjusted the points by
    bending the moving arm, and it had snapped off. He had another set in his
    van. Made it to the airport on time. Budget refused to give me any discount
    as I 'had not given them the opportunity to fix the problem'. They did
    reimburse me the 3 quid I had to pay the RAC man for the points.
    Fuckers!
    Theo
    Theo Bekkers, Feb 8, 2007
  7. alxr
    Theo Bekkers Guest
    Guzzi went to brushless, permanent magnet alternator with the Cali 1100 in
    1994. Used the Ducati branded regulator. After two of those I replaced mine
    with an aftermarket Japanese one. Never had another problem. (Obviously it
    wasn't from Honda).
    Theo
  8. alxr
    Dale Porter Guest
    It's all about you, isn't it?
    Dale Porter, Feb 8, 2007
  9. alxr
    Theo Bekkers Guest
    Buy a Mercedes. The doors lock when you reach 15 km/h to 'improve the
    structural strength of the vehicle'. Some magical thing unlocks them after
    you crash, apparently.
    Theo
  10. It's not the torque that matters, it's the power. If your headlights
    draw an extra 120W then the motor needs to put out an extra 120W - if
    you factor in inefficiencyin the alternator (which is unlikey to be any
    better that 80%) its going to be more like 150W. Add in the running
    lights and you might get as high as an extra 200W needed from the engine.
    That's not going to make much of a dent on Nev's 5.7L V8, but it's over
    10% of the total max output of a Deux Chevaux.
    Most cars will come somewhere in between - I'm not surprised Nev doesn't
    notice the extra power consumed by his headlights, in a much smaller
    engined car it'd be more obvious, on a tiny engined and/or extremely
    efficient car (a Prius maybe) I'm sure it'd show up.
    Nope, as I explained upthread, any modern car (unlike, I suspect, the
    2cv) has an active rotor and can adjust it's output (and hence input) to
    match the current electrical power requirements .
    Yup, you're right there. It's true that lights require power, but it's
    not _much_ power...
    big
    Iain Chalmers, Feb 8, 2007
  11. alxr
    sharkey Guest
    Excellent, and I'll bring the oscilloscope!
    -----sharks
    sharkey, Feb 8, 2007
  12. alxr
    Hammo Guest
    Oh,boo hoo, did you want to wear the pretty hat too? You'll have to nice to
    Sharkey, he is the guest!
    Hammo
    Hammo, Feb 8, 2007
  13. Without arguing the authority of wikipedia...
    http://en.wikipedia.org/wiki/Alternator#Automotive_alternators says
    automotive alternators achieve between 50 and 60% efficiency.
    http://en.wikipedia.org/wiki/Megajoule says 3.6MJ=1kWh, so 1kWh~=0.28MJ
    or 1Wh=0.00028MJ
    http://en.wikipedia.org/wiki/Internal_combustion#Engine_Efficiency says
    piston engines get ~ 20% efficiency
    http://en.wikipedia.org/wiki/Gasoline#Energy_content says you get
    ~32MJ/l from petrol.
    So, 120W headlights will need 120/0.50 =~ 240W of input power to the
    alternator.
    To run them for an hour will require 240*0.00028 =~ 0.067 MJ.
    At 20% efficiency the engine will consume 0.067/0.20 =~ 0.34MJ
    Which is (near enough) 100mL of petrol.
    If you're driving along at 100kmh, you should expect to consume an extra
    0.1L of fuel an hour, which is an extra 0.1L/100km (or around and extra
    1.5mpg). If you're only averaging 50kmh, you'll still consume 0.1L/h to
    drive the headlights, but you'll be driving them for twice as long which
    will bump your fuel economy up by 0.2L/100km.
    (I think I got all my orders of magnitude right there)
    It's a more than a thimbleful, but small enough to disappear into the
    noise for most people I suspect... My little bike gets around
    4.75L/100km so I _might_ notice a 0.1L increase, but it's only got 60W
    of headlight. I suspect Nev's lucky to get less than 20L/100km out of
    his car, and he'd be unlikely to notice a 0.1L/100km increase - it'd
    almost certainly be overshadowed by head/tail winds, traffic delays,
    imperceptible inclines, etc...
    bored-at-work-big
  14. What?
    Oh, I see...
    Carry on...
    big (no-arse-cancer)
  15. See my other post - wikipedia and the back-of-the-envelop suggests 1
    decilitre per hour is pretty close to what your 120W headlights
    require...
    Can I get you to do another experiment? I'm wondering if 800rpm is too
    slow for the alternator to be developing all the required output, and
    what you're seeing is the headlights drawing the battery charge down
    rather then being powered by the engine. I'd be interested to know if
    you see any fuel flow difference in the diagnostics if you hold the
    engine at a slightly higher speed when you switch the lights on and off
    - maybe up at 2500 or 3000 rpm?
    curious-big
  16. alxr
    Dale Porter Guest
    And that's the best you could come up with?
  17. alxr
    Hammo Guest
    Oh yes?
    I'd like to see your calculations! Please consider diameter of the pulleys
    of both crank and alternator, torque required and current and volatge flow,
    also for switched and non-switched systems.
    10 per cent?
    One is a measurement of the conversion from mechanical to electrical with
    the outcome being power, and the conversion from electrical to mechanical
    would be power dependant. AFAIK, Torque is the proper term when describing
    this rotational force.
    If it is so small you cannot measure it, how can be called a waste? Also as
    there are more than one type of alternator/dynamo/magic box it is the joy of
    discussion and the pointing out that there are circumstances that "waste of
    fuel for no purposes" becomes a good laugh.
    Hammo
    [1] ..some bits of this you've missed from other posts that may be useful
    re: assumptions and the like. See above.
    Hammo, Feb 8, 2007
  18. alxr
    Hammo Guest
    Oh...... You really are being sooky. It'd be like kicking a puppy.
    Hammo
    Hammo, Feb 8, 2007
  19. alxr
    Hammo Guest
    That'd be great.
    Plans still the same?
    How strong is your arm/shoulder now?
    Hammo
    Hammo, Feb 8, 2007
  20. alxr
    Boxer Guest
    My 5.7 litre HSV gets an average of about 16.5L/100km in the city and
    10.0L/100km on the highway.
    Boxer
    Boxer, Feb 8, 2007
