Paging BGN
Discussion in 'UK Motorcycles' started by Work in progress, Apr 29, 2007.
  1. If you're still awake check your spam filters for mail. It has UKRM
    (and other stuff) in the subject line. Ta.
  2. Work in progress
    BGN Guest
    I've replied to you already.
    www.poferries.com
    Do have a word with Mr. TOG. I'm sure you can squeeze into one of the
    single rooms or failing that you can share my room.
    BGN, Apr 30, 2007
  3. Nothing here.
    The Older Gentleman, Apr 30, 2007
  4. try my work email
    first name.surname at informa dot com
  5. Work in progress
    TOG Guest
    ****. I actually parsed that as Paging TOG, read BGN's reply, and
    assumed the WIP was asking if there's space on the French Run.
    There isn't. There really, really isn't, unless someone drops out.
    TOG, Apr 30, 2007
  6. I was asking about ferries, I knew the hotel was full, but the next
    one along isn't. It all depends on work, weather and will.
    I was going to say 'if they do I'll have their bed', then realised I
    could end up sharing with a snorer.
    Work in progress, Apr 30, 2007
  7. Work in progress
    It's OK - I have a single room and I doubt Dodger's Linda will drop out
    without him, iyswim.
    Anyone else wan't to join the Heroic Snorer's Club?
    CT, Apr 30, 2007
  8. Work in progress
    Monz Guest
    *WAVES*
    Also in single room :eek:)
    Monz, Apr 30, 2007
  9. Work in progress
    I should have known, you being a "larger gentleman", an' all.
    CT, Apr 30, 2007
  10. Work in progress
    Moi aussi, though that doesn't always help, I've had people in the next
    room (or even the one after that) complain in the past.
    ogden, Apr 30, 2007
  11. How thin are the walls? Will I need earplugs or should I nail the bed to
    the floor to stop it shuddering across the floor?
    Whinging Courier, Apr 30, 2007
  12. Work in progress
    Monz Guest
    I suggest sir sorts himself out with one of the UKRM rubinesque females [1]
    to weight the bed down... QED
    [1] Yeah... I know
    Monz, Apr 30, 2007
