Paging: BMW "K" FOAKs
Discussion in 'UK Motorcycles' started by Brownz \(Mobile\), Feb 25, 2008.
  1. Servicing .... no probs (ish).
    New battery, fitted without a problem, ABS woes cured.
    Engine Oil & Filter, Gearbox Oil, Final Drive Oil, all changed.
    New short Hagon rear shocker fitted with minimal skin loss.
    Air filter .... hmmmm.
    Knee Panels - off, Middle fairing sections - off (after a little of
    persuasion with a couple of well rusted screws).
    Break right hand mirror pod (feck).
    Pop off airbox intake tube and tube that goes to what I guess is a plenum
    chamber, Pop spring clips off lid, lose one clip down back of gearbox.
    Retrieve clip with pike fishing forceps - result !
    Fecking airbox lid still won't budge.
    Find wires disappearing into airbox lid, so seat up, ECU out, tool tray out.
    Grope around hopefully for 10 mins trying to find wires that go into airbox.
    Gave up - went in for a brew.
    So, how the **** does the tank come off ?
    Or is their a quick and easy way of changing the air filter without all this
    malarkey.
  2. Brownz \(Mobile\)
    Steve Parry Guest
    In
    No need to remove the tank for the airbox. ISTR that there's 3 clips holding
    the top of the airbox to the bottom. They get a bit "sticky" if they've not
    been moved for a while which sounds like your problem.
    From what I recall on my KRS it was just a matter of popping the clips and
    giving the top half a mild thump with the palm of the hand to release it
    then wriggle the filter out.
    http://www.ibmwr.org/ktech.shtml
    http://www.ibmwr.org/ktech/air-filter-change.shtml
    hth?
    Steve Parry
    07 K1200GT SE
    95 BMW F650
    87 Yamaha FS1
    Sukida SK90PY
    91 Kawasaki AR50
    07 VW Passat SE Estate for comfort
    www.gwynfryn.co.uk
    Steve Parry, Feb 25, 2008
  3. Brownz \(Mobile\)
    Do you have to grease the splines on a K?
    A little lube, a lot of rubbing.
    platypus, Feb 25, 2008
  4. Yup, I'll be doing that at the weekend.
    Seeing as the final drive and gearbox are both sealed units I can do the
    servicing bits step by step.
    Pervert. :p
    (Are you (a) on the later ferry, and (b) taking the sidecarp over on the
    French Run ?)
  5. Looks like I was close - but couldn't see the clips holding the rear of the
    tank.
    Will have another bash tomorrow.
  6. Brownz \(Mobile\)
    Steve Parry Guest
    In
    Yes but it's not that bad a job
    Steve Parry
    07 K1200GT SE
    95 BMW F650
    87 Yamaha FS1
    Sukida SK90PY
    91 Kawasaki AR50
    www.gwynfryn.co.uk
  7. Brownz \(Mobile\)
    Steve Parry Guest
    In
    PS to remove the tank from a K100RS
    remove the left hand fairing inner (2 screws at top, 1 under fairing)
    at front left of tank are the fuel pipes unscrew the clamps, and slide them
    down the pipes, then slide the pipes off the tank, they can be tough to move
    because they've been clamped on for a while :)
    remove right sidepanel under which is the fuel tank power feed, disconnect
    it.
    on later k's (which ISTR yours is) there are two clips that hold the tank in
    two rubbers at the rear of the tank. (On early ones theres a plate with a 10
    mm bolt.). Remove the two clips and lift the tank up and off.
    Steve Parry
    07 K1200GT SE
    95 BMW F650
    87 Yamaha FS1
    Sukida SK90PY
    91 Kawasaki AR50
    www.gwynfryn.co.uk
  8. Brownz \(Mobile\)
    Steve Parry Guest
    In
    Don't forget the fuel filter inside the tank ...
    Steve Parry
    07 K1200GT SE
    95 BMW F650
    87 Yamaha FS1
    Sukida SK90PY
    91 Kawasaki AR50
    www.gwynfryn.co.uk
  9. Brownz \(Mobile\)
    I appear to be on the early one, if I can make it in time. I see you've
    been tucked up with the Northerners, slow cunts and Ogden. The outfit will
    remain in its cupboard, as Madame refuses to have anything to do with it.
  10. Brownz \(Mobile\)
    I'm supposedly on the later one. I'm staying in Dover-ish the night before.
    Other parties are staying at the same hotel, or live in the vicinity.
    Depending on my levels of sobriety and sexual magnetism I may make the
    early ferry...
    wessie, Feb 25, 2008
  11. Brownz \(Mobile\)
    You probably have a better chance than I have.
  12. Yup, I did wonder why Mr Murray put me on the later one.
    I'm also staying at the Swingate Inn (Dover) on Thursday night, so with
    TOG's approval will happily swap my later crossing for an earlier one with
    someone who has a longer trip to make that morning. Please arrange through
    TOG though so we don't **** his planning up.
  13. Brownz \(Mobile\)
    This is UKRM. People will miss the 1st ferry. Someone might crash in the
    1.5 miles from the hotel to Eastern Docks.
    Oh, and depending on hangover etc, P&O have earleir ferries than 1055. They
    will probably be very happy to have some of the bikes on the 0915 or 1005.
    Lunch in Ypres, maybe?
  14. Good call. We'll sort something on the day, allowing for hangovers etc
  15. Brownz \(Mobile\)
    What would you call an Ewok/Sonatran hybrid?
  16. Brownz \(Mobile\)
    All this first ferry/second ferry shit is just indicative. Shit wiil
    happen, bikes will be binned, people will be late. FFS on the Elefant we
    had a DNF, bits falling off, bikes falling over, concussion, a Golden
    Catherine Wheel incident and several instances of navigational inexactitude,
    and that was with only seven starters.
  17. Brownz \(Mobile\)
    My way, obviously.
    Fucking shiraz.
    Name the Ewok/Sontaran hybrid, folks
  18. Brownz \(Mobile\)
    ts Guest
    When I last changed the air filter, I managed without having to
    disconnect the fuel lines. With the knee-pads off, I just lifted the
    rear of the fuel tank directly upwards (off the frame monted rubber
    grommets), the slid it backwards (to release it from the bushes behind
    the steering head), and then slid/rotated the tank to the left, where I
    let it rest against the fairing (with some cloth between the two to
    avoid scratching the tank). Then, with a bit of wiggling it was possible
    to replace the air filter without any further major disassembly. Which I
    was very pleased with.
    ts, Feb 25, 2008
  19. Brownz \(Mobile\)
    "Nigel". Although TBF I think of him more as an Ewok/Sid the Sloth hybrid.
  20. Brownz \(Mobile\)
    Lady Nina Guest
    Did not fix?
    Vibrating off.
    It rocked.
    Lady Nina, Feb 25, 2008
