Paging Bonwick
Discussion in 'UK Motorcycles' started by Hog, Oct 27, 2003.
  1. Hog
    Andy, can you recommend a type (and/or brand) of drills suited to drilling
    very hard materials? this is smaller stuff in the 1-10mm range.
    I was making up a new brake calliper pin from the nicely hardened shank of
    an old screwdriver. Both my Snap-on and Tin coated drill sets refused to
    co-operate in the making of the cotter pin hole. I'm pretty sure the former
    set are Cobalt to boot.
    Hog, Oct 27, 2003
  2. Hog
    Confucius he say, " Next time you do this, you Round-Eye dog, drill
    hole _before_ hardening shank".
    Or soften it by heating it up and letting the colours run off the end
    of the shank and leaving it to cool, drill hole and re-harden by
    heating until it's purple and quenching in oil. Probably.
    If it's that hard, I'd file a couple of wee flats - or even a groove -
    and use an R clip.
    Pip, Oct 27, 2003
  3. Hog
    It came hardened
    If I'd had some silver steel bar the right OD I'd have gone down this route.
    Damn but I need a nice little lathe.
    Is what I did but with brakes, hmm, I'd rather be sure so got a new original
    in the end.
    Hog, Oct 27, 2003
  4. Hog
    Hog wibbled like a little girl....
    Surely it would be cheaper and easier to source a used pin from a breakers or buy a new one?
    When I snapped a caliper pin off in the ZZR's rear brake I managed to
    get the stub out using heat. I was still left without a pin. So off I
    trundled up the garden to rob one from the CB250RS, which was lying
    dormant at the time with a blown motor. After a few minutes of chopping
    both ends down, I had one identical to the other side, complete with
    cotter pin hole in the right place. Cost was bugger all.
    Luckily there were 2 spare brake calipers in the boxes of spares I
    bought for the Honda, from which I nicked a caliper pin when I was
    putting it back on the road.
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3.
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    www.mjkleathers.com
    Lozzo, Oct 27, 2003
  5. Hog
    Aye but this was a late evening and I wanted to finish the damn thing.
    Diabolical though the front brake pins are on the ZZR400 at least you can
    split the calliper and twist/get at the buggers though one required drilling
    out of the blank end as the pin had all but rusted through. WTF you do with
    the rear calliper if the pin refuses to budge I don't know. Ridiculous (and
    unnecessary) design flaw. Fortunately it was not quite so badly corroded and
    heat/release agent has prevailed. It would have to be some creative Dremmel
    action I think.
    Hog, Oct 27, 2003
  6. Hog
    On the D model 1100 the caliper splits, so access is easy. On the C
    model it's a single piston sliding job and the pads are held in place in
    grooves in the caliper body and by one of the slider pins. They are
    simple to work on.
    Lozzo
    www.mjkleathers.com
    Lozzo, Oct 27, 2003
  7. Hog
    One pad had a guide running on the sliding pin and both had top holes with
    this single central pin.
    Hog, Oct 27, 2003
  8. Hog
    Platypus Guest
    Yeah, I do that too.
    Platypus - Faster Than Champ
    VN800 Drifter, R80RT
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Oct 27, 2003
  9. Hog
    Simian Guest
    Hog :
    IANB, but I've always sworn by Tungsten Carbide bits - they go through
    aluminium like it was warm butter, and hardened steel like it was...
    cold butter.
    Probably cheaper to buy a new calliper pin tho.
    Simian, Oct 28, 2003
  10. Hog
    Thanks, I've done that of course but it's a materials problem that's come up
    a few times. Know of a good online source?
    Hog, Oct 31, 2003
  11. Hog
    Simian Guest
    Andy Bonwick :
    **** me, that's exactly what I said.
    Who would've thought, eh?
    Simian, Oct 31, 2003
