Paging Catman and anyone else that knows about Ad-Aware
Discussion in 'UK Motorcycles' started by Donegal Paul, Sep 6, 2003.
  1. Donegal Paul
    Donegal Paul Guest
    Seeing as you know lots about this, Ive just installed and run it, fucking
    hell its shown up loads of stuff!! In fact 433 items!!
    The question is now, what do I do? Im a bit worried cos there's registry
    entries in there too, all relating to the hijacking software as it calls it.
    If I quarantine all items will this be ok or am I likely to **** things up
    even more?
  2. Donegal Paul
    Donegal Paul Guest
    "Dan White" said to "Donegal Paul"
    Thanks Dan, I guess Im just at that point were you think nothing else can go
    wrong and then it invariably does :-/
  3. Donegal Paul
    Dan White Guest
    Bin the fucking lot. That's what it's there for.
    Dan White, Sep 6, 2003
  4. Donegal Paul
    Bill Guest
    bin them. It gives you the option to save a backup of what's binned, then
    in the unlikely event it has cocked up, all is not lost.
    Bill
    Bill, Sep 6, 2003
  5. Donegal Paul
    Dan White Guest
    Oh don't get me wrong... things could still go wrong ;-)
    You had some spyware on your system from the sounds of it... which will
    happen if you install grokster etc...
    Just keep running adaware regularly, and keep getting the update files for
    it.
  6. Donegal Paul
    catman Guest
    Back them up, then bin them all. Worst case you'll get boot errors
    saying that such and such a command could not execute. If that
    happens, re-run adaware, restore everything, then remove them one at a
    time till you find the culprit. Then un-install the fucker. That's
    the only porblem that I've had with adaware, it can breka 'installed'
    porgrams that you never meant to install. eg gator e-wallet
    Alfa 116 Giulietta 3.0l. Really, Sprint 1.7
    Ducati Monster 600 Metallic
    www.cuore-sportivo.co.uk
    catman, Sep 6, 2003
