Paging Dodger
Discussion in 'UK Motorcycles' started by platypus, Jan 4, 2007.
  1. platypus
    You need a sub:
  2. platypus
    I believe that Mr Dodger may find a kindred spirit here:
    Wingin' on speed, sort of thing.
    Pip, Jan 4, 2007
  3. platypus
    Arse! Dropped an "A", apparently.
    Here:
    Pip, Jan 4, 2007
  4. platypus
    Looks like he recently hit a grouse. Is is just me, or did he nearly peel
    off into a layby at around 50 secs?
    Anyway, this one here:
    is pretty spectacular - scary lean angles, committed braking deep into the
    corners, the lot, basically. Enjoy.
  5. platypus
    Beav Guest
    The wife just woke me up. It didn't look particularly spectacular to me and
    I was waiting for some scary lean angle footage, but none ever appeared.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 4, 2007
  6. platypus
    Mark Guest
    Did you post the wrong link?
    Mark
    Mark, Jan 4, 2007
  7. platypus
    Donald Guest
    Haven't heard "Big Country" for years.
    I'm not expecting to grow flowers in the desert
    But I can live and breathe and see the sun in wintertime.
    And in a big country, dreams stay with you
    Like a lover's voice, fires the mountainside.
    Stay alive.
    Donald, Jan 4, 2007
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    It's not that, he's bought a GoldWing and had his lean-angle sensor
    recalibrated.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Wicked Uncle Nigel, Jan 4, 2007
  9. platypus
    Wicked Uncle Nigel says...
    From maximum 180 deg to max 10 deg.
    Lozzo, Jan 4, 2007
  10. Isn't he just?
    I am probably being very unfair but the rider did appear to be in
    possession of WUN's teddy bear. Given that there bikes in front showing
    the line of route and many corners were fairly open I'm struggling to
    quite why so many brake applications were needed. SD certainly hussles
    his Wing round corners without such a display of red.
    Paul Corfield, Jan 4, 2007
  11. platypus
    I had the TB thought too, but I was too polite to mention it. I'm
    sure you're right about SD, although I wonder if he corners sometimes
    like I used to on my RF - 'cos there's a lot of red light on the back,
    it is a bit obvious when the rider has a touch on the brakes, so many
    times I'd knock it down a hard one and pray to the (less than
    consistent) God of Engine Braking on a closed throttle, then wrestle
    the bastard round the corner with sweat prickling in all sorts of
    uncomfortable places. Then repeat on the next corner, and the next ...
    Pip, Jan 4, 2007
  12. platypus
    SD Guest
    Laser-etched screen art. G'wan, you know you want to.
    I reckon you're about right.
    Heheheh. Shameful, especially on a GL18.
    | ___ Salad Dodger
    |_\_____/_| ..87918../..23274.../..31893.
    SD, Jan 4, 2007
  13. platypus
    SD Guest
    Aww <blush>
    Several bulbs may have blown.
    | ___ Salad Dodger
    SD, Jan 4, 2007
  14. platypus
    SD Guest
    There's more than a whiff of familiarity to that. Often no need to
    knock down, unless I'd got all adventurous and changed up into "OD".
    Many cross-country trundles have been conducted entirely in third, or
    fourth, gear.
    Main reason is there's no point in trailing the brake into a corner on
    a 15. Cos they're shite. The brakes on a 18 are brilliant, but then,
    so is the chassis.
    I reckon there's one spot on that vid where he *needed* to brake.
    | ___ Salad Dodger
    SD, Jan 4, 2007
  15. platypus
    I get more lean than that on the outfit.
