I have a problem booting up my new to me pc. I've tried three hard drives in it but every time I try to boot it up it goes so far then tells me to remove disk or media from the drives. There are no disks or anything in any of the drives. Please Doc, what shall I do? -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
Got any flash drives (SD cards, etc.) or USB devices plugged in? Try unplugging them and booting. How for does it get before it tells you to remove whatever from the drives?
BGN says... It has usb devices plugged in, but they are easily removed obviously. When I start up it recognises the drives etc, but that's as far as it'll go. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
So it's not getting past the POST (Power-On Self Test) I assume there are no obvious errors returned? Does the computer 'bleep' at you (and if it does how many long/short bleeps are there as they mean something) If I were you I'd unplug all of the USB devices (including USB mice, hubs, etc.) and see if that helps. If not then ask Cane What's the model of your motherboard and/or BIOS?
BGN says... It beeps once just like a fully functioning puter, scrolls through the black and white lsistings bit until so far then it gives the message "remove disks or media from drives" all usb devices are unplugged. Asus A7S266-VM motherboard, not a clue about the BIOS. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
Question mode = really dumb you do have an OS on those discs? Try booting from CD -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 TS 156 TS S2 Suzuki Bandit 600 #Triumph Speed Triple: Black with extra black bits (I live in hope) www.cuore-sportivo.co.uk
Catman says... On one of them for definite, still no go. That's the next step. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
Christofire says... It's empty, but I'll disconnect it anyway. Just about to have another try, XP disc at the ready just in case. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
Lozzo says... Bad form etc.. and that didn't work -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
Lozzo says... ....and that didn't work either. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
Bear says... "I shagga the one ear..." -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
Bear says... "that wassa the Flook" -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
BGN says... When I first fire it up I get two short and very soft muffled bongs followed by a short beep. I've tried unplugging each dvd drive and then both, tried unplugging the floppy drive and it's the same. The only external connections are for monitor and hard wired mouse and keyboard. There are no usb connections made and no network card connected. There is an SCSI card in one of the pci slots and I'm wondering if I should remove that altogether as I'm not likely to use any SCSI devices. Apart from that all there is is an unused network card, dvd rw, dvd drive and a floppy drive. It's been left pretty basic until I get the thing running on XP and then I'll start swopping bits from my old one into this case. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
If it's an Award BIOS I think 1 + 2 = Video adaptor error (or is that 2+1?) Anyway, what you're describing don't sound like bleep codes. Have you tried unplugged ALL of the drives and seeing if it still gives the same error? Remove the SCSI card. Destroy!!!
One short beep-There is a problem with the memory refresh circuits on the motherboard. Five short beeps-The CPU is indicating an error. Eight short beeps-The video card (also called graphics card or video adapter) is missing, is not responding to the BIOS POST, or has faulty memory. One long and three short beeps-The monitor or video RAM has failed. If you confirm these devices are functioning properly, check other parts of the video system.
Did you go in to the BIOS settings and specifically set the boot sequence to CD before HDD? Possibly disable floppy drive seek if there is an option for that. -- +-------------------------------------------------------------+ | Pete Fisher at Home: | | Voxan Roadster Gilera Nordwest Yamaha WR250Z | | Gilera GFR Moto Morini 2C/375 | +-------------------------------------------------------------+
Pete Fisher says... I didn't, but I will. Thanks. -- Lozzo Triumph Daytona 955i SE (Black with added black bits) Suzuki Bandit 600S (Green with added shit bits) Yamaha SR250 Delusion (It's "Special") Homefucking is killing prostitution.
