Paging Dr Cane - the pc surgeon.
Discussion in 'UK Motorcycles' started by Lozzo, Mar 21, 2007.
  1. Lozzo
    Cane says...
    I get this every time on my current pc. It's always done that and the pc
    I had before always did that too, and I had that one from new.
    Nope, 2 bongs and a beep
    Nope
    Lozzo
    Suzuki Bandit 600S (Green with added shit bits)
    Yamaha SR250 Delusion (It's "Special")
    Homefucking is killing prostitution.
    Lozzo, Mar 22, 2007
  2. Lozzo
    Cane says...
    Thank you, Dr Cane. Now, I have this hairy wart on my todger...
    Lozzo
    Lozzo, Mar 22, 2007
  3. Lozzo
    Pip?
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative."
    platypus, Mar 22, 2007
  4. Lozzo
    Cane Guest
    That *is* your todger.
    Cane, Mar 22, 2007
  5. Lozzo
    Cane says...
    Sorted, cheers.
    Lozzo
    Lozzo, Mar 22, 2007
  6. Lozzo
    Cane Guest
    Dust Under Hard drive or Disc Unhelpful?
    Either way, good call.
    Cane, Mar 22, 2007
  7. Lozzo
    Cane Guest
    Bugger. I spent minutes searching for something to cut and paste.
    Cane, Mar 22, 2007
  8. Lozzo
    frag Guest
    Lozzo banged the rocks together and they said :
    Disconnect floppy.
    Disconnect all BUT ONE CD ROMs/RAMs & DVD ROMs/RAMs
    Unplug all cards from motherboard apart from a graphics card (if the
    mobo has built in graphics, use them and remove any plugged in gfx card)
    Go into BIOS and perform a reset (load BIOS power on Defaults).
    Still in BIOS change the boot order to CD/DVD and then HDD, disable all
    other devices.
    Bung Windows CD into drive and reboot machine.
    If that still doesn't boot somethings broke, nick parts from Pips PC to
    replace yours until it works :)
    frag, Mar 22, 2007
  9. Lozzo
    Now that is fucking spooky. I was discussing this with Loz as he left
    the building - just at the time you were typing this, and my advice to
    him was exactly what you've written, almost word for word.
    If he does, I'll shag more than his ear.
    Pip, Mar 22, 2007
  10. Lozzo
    Paul - xxx Guest
    I have an Asus A7A266 (Socket A) mobo and looking through the manual the
    beep codes listed don't apply to what you're getting.
    ie 1 short beep is No error during POST,
    Long beeps in endless loop is no DRAM installed or detected,
    One long beep followed by three short beeps is Video Card not found or
    VC memory bad,
    and High frequency beeps when system is working is CPU overheated.
    So the book doesn't tell you anymore than you know, that something's
    fecked.
    So I'd look at the Chassis intrusion lead/jumper to see if this is on or
    off, a scanned pic of which I've just uploaded to Gmail drive, Paulxxx
    folder.
    If you want any more info from the manual, post back to newsgroup and
    I'll scan other pages, providing my CPU holds out ... eldest son tried
    overclocking it a week ago and it's now decidedly flaky at best ..
    Hope it helps.
    Paul - xxx, Mar 22, 2007
  11. Lozzo
    frag Guest
    Pip banged the rocks together and they said :
    Great minds and all that.
    I thought Loz shagged your ear, not the other way around?
    God, nightmares are made of this stuff!
    frag, Mar 22, 2007
  12. Lozzo
    "Fools seldom differ"
    Time I got my own back. As it were.
    Think yours are bad? Imagine Lozzo's.
    Pip, Mar 22, 2007
  13. Lozzo
    Paul - xxx says...
    Thanks Paul, it does help. I'll try and download from the Gmail drive.
    Lozzo
    Lozzo, Mar 22, 2007
