Paging Fat Frenchies
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Jan 20, 2010.
  1. Imperial Airways used to weigh passengers in the late 1920s when payload
    was only a few tonnes.
    Naturally, some ladies (and probably few pie-eating gents too) didn't
    like this, so IA had a brainwave and hired bods from the rag trade who
    were able to look at a person and guess their size/weight with
    remarkable accuracy.
    True story.
    The Older Gentleman, Jan 21, 2010
  2. "Semites"?
  3. Wicked Uncle Nigel
    Colin Irvine Guest
    All Air France is doing is saying it might insist that people so wide
    that they might get stuck in narrow economy seats should go business
    class or first class instead, where the seats are wider. Common sense
    I'd have thought.
    Colin Irvine, Jan 21, 2010
  4. Wicked Uncle Nigel
    Domenec Guest
    Those 20 seaters are often used for taking basketball teams (11
    players, a few coaches, doctor an PR man). I wonder how the weight may
    affect, provided that a 190cm bloke is considered small these days,
    and not only are they taller, but have massively more muscle.
    Domenec, Jan 21, 2010
  5. They are often put near to an exit but not next to it as those people
    have to be able to open the door in an emergency.
    As to get in the way, people just climb over the seats and those who
    don't move fast enough
    It they get noisy and run around the aircraft especially at night they
    have to get off *NOW*. Even if the aircraft is at 32,000 feet.
    Mick Whittingham, Jan 21, 2010
  6. Even ordinary people (not just septics) are noticeably heavier generally
    than they were when the average weight was calculated.
    They figure the average weight of a bag is 11kg or so too IIRC, which on
    many flights is not the case.
    I know that some airlines operating small turboprops weigh each bag, and
    the aircraft is trimmed to some extent by distributing them on a bag by
    bag basis forward or aft in the hold.
    Passengers on such flights can often pay extra to book their seat
    online, only to find that the pilots will instruct them to be moved to
    keep the aircraft in trim.
    There is a fairly big safety factor on top of the average weight of a
    passenger built into the airframe and the seating, and aircraft carry
    more than enough extra fuel to deal with the increased weight.
    Anyway. Athletes can always eat each other if they get stuck.
    Douglas Payne, Jan 21, 2010
  7. Wicked Uncle Nigel
    'Hog Guest
    Fnar
    *perfect*
    'Hog, Jan 21, 2010
  8. Wicked Uncle Nigel
    'Hog Guest
    I said that and it is.
    I'd rather all seats were a bit more spacious and comfortable though.
    'Hog, Jan 21, 2010
  9. Wicked Uncle Nigel
    'Hog Guest
    You mean as in Loz breaking their jaw and both arms as he exits?
    'Hog, Jan 21, 2010
  10. When we were being briefed before going South, a chap from the
    USAF gave a talk directed at those flying in early to McMurdo from ChiChi
    in Hercs: "Now, your weight allowance is 240 lb, you and your luggage."
    At which a rather large tradesman stood up and said, "My name's Tiny and I
    have a problem -- I'm 240 lb all by myself!"
    Dr Ivan D. Reid, Jan 21, 2010
  11. One flight from GVA last year we had some enormous Boeing 7x7 that
    must have been at least 3x the capacity of the normal dinky Airbus. BA
    sat us all down the outside seats for take-off but let us move around once
    we were airborne.
  12. Wicked Uncle Nigel
    Beav Guest
    Are they blue eyed and blonde haired? If so, count me in.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 21, 2010
  13. Wicked Uncle Nigel
    davethedave Guest
    It's not about weight. It's about take off weight. You can't just chuck
    extra fuel in as this will add to the take off weight.
    More fuel will be used trying to get to altitude in a heavy plane.
    If the destination is a long way away there may not be enough fuel to
    reach it after the climb.
    Unfortunately adding more fuel won't help this situation because it
    will make the plane heavier causing it to use more fuel.
    If you go over the take off weight you don't take off.
    http://www.airdisaster.com/photos/das10/photo.shtml
    This is decidedly not a good thing.
    Fuelling, loading and passenger weight has to be calculated as a whole
    with regards to the destination.
    Also we have to take into account the correct amount of seasoning for
    a baskey ball player.
    davethedave, Jan 21, 2010
  14. Wicked Uncle Nigel
    Krusty, Jan 21, 2010
  15. Wicked Uncle Nigel
    crn Guest
    Indeed.
    You need enough runway to accelerate to takeoff decision speed, decide
    to reject the takeoff, and stop.
    If the aircraft is overweight the wings will not have enough lift at
    the incorrectly calculated rotate speed to fly. This can cause a tail
    strike. Worse, the nose-up attitude will now cause more drag so
    the aircraft will not accelerate as well thus needing even more runway.
    By the time the commander realises the error there is a serious risk
    that there will not be enough runway to safely stop.
    If the weight and speeds had been correct in the first place there
    may well have been enough runway to rotate at the correct higher speed
    and still have the option to stop safely.
    crn, Jan 21, 2010
  16. In a crash, fatter people than the aircraft is designed for decrease the
    likelyhood of the aircraft staying in one piece and protecting its
    occupants.
    There must be a weight factor built into the MTOW of aircraft as not
    many airlines weigh every passenger. I can't remember what the figures
    are, but they assume the average male is something like 70kg and the
    average female is 65kg. A swift google suggests this may have changed,
    at least in the states.
    Taking off without enough fuel to get to where you want to go is frowned
    upon, so the pilot factors in enough fuel to get there, to tootle on
    hold for a while if he can't get in and then fly somewhere else if it
    still looks iffy. They then add more fuel for taxying and mucking about
    so there is usually a fair bit more than they actually need.
    Yes, sorry, perhaps I am mixing things up. I don't fly 'em, I just
    chuck things in and out of them, and my understanding of why I sometimes
    get asked to chuck things off that I've just chucked on because of a
    weight issue isn't complete.
    I'm pretty sure many aircraft in fact do exceed their MTOW by a bit and
    do take off, but they don't all crash because the designers kind of knew
    this would happen and jiggled the limits accordingly.
    Perhaps the ban on fat french people in economy suggests these limits
    are being reached.
    "The aircraft overran runway 35 while landing..." (c;
    Nom nom nom.
  17. Wicked Uncle Nigel
    Beav Guest
    So are we to believe that planes only carry "just" enough fuel to get to
    where they're going?
    And there's me thinking that they had to carry enough to get to an alternate
    airport if the original can't be used for some reason AND that they have to
    have enough (still) to hang around in the stack until they're cleared to
    land.
    Anyway, they could always turn the "RES" tap.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 22, 2010
  18. The Older Gentleman, Jan 22, 2010
  19. Cool. Al fresco flying.
  20. Wicked Uncle Nigel
    Beav Guest
    240lbs? That's a fucking skinny septic.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 22, 2010
