Paging FOAK; speed cameras...
Discussion in 'UK Motorcycles' started by deadmail, Sep 1, 2007.
  1. deadmail
    deadmail Guest
    OK, so there's a rear facing Gatso speed camera on a local dual
    carriageway. It's been there for 8 or more years. It is on the east
    bound lane, on the verge.
    This evening I was going west-bound in my car and naturally I was
    observing the speed limit... ish; about 75 indicated in a 50 (so
    something like 65-70 true speed I suppose).
    So, I was rather galled when the fucking camera flashed me (twice.)
    It's never done this before. It's clearly me that triggered it 'cos
    there was no one in the east bound lane and I was the fastest thing in
    the west bound lane.
    So... have the fuckers upgraded the Gatso cameras to photo across dual
    carriageways now, or is it one of those things[1][2]
    [1] I've heard you can trigger them in the opposite direction and have
    tried many times on a bike but never succeeded.
    [2] I shall be rather upset if my clean license is stained by points...
  2. deadmail
    There's an older model GATSO in Brighton that goes off in the facing
    direction. Apparently if they run out of film the older ones go off on
    oncoming traffic - apparently.
    Either way I've set that one off a fair number of times and never heard
    anything so if I were you I wouldn't be bothered about it.
    sweller, Sep 1, 2007
  3. you can trigger them in the opposite direction , favourite trick of my
    future son in law and his cronies in monkspath
    looks like you may be a little upset
    steve robinson, Sep 1, 2007
  4. deadmail
    AOL, only the one on the A40 at Huntley
    wessie at tesco dot net
    BMW R1150GS
    "Wessie is a lovely man with many wonderful qualities" TM Blaney
    wessie, Sep 1, 2007
  5. deadmail
    Ballistic Guest
    had a sudden rush of blood to the head and
    wrote in
    There's one near Chiswick That does that. I've set it off loads of
    times (both car and bike)and never had a problem.
    Ballistic, Sep 1, 2007
  6. deadmail
    deadmail Guest
    Thanks, but I think I'll have a few more drinks and consider necklacing
    the fucker later on this evening 'just to be on the safe side'. I'd
    consider it my charitable act for this year.
  7. deadmail
    Beav Guest
    Are there distance measuring lines on you side of the road? If not, I
    wouldn't worry.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 1, 2007
  8. deadmail
    Tosspot Guest
    I've always fancied paintballing them. It just appeals to me to cruise
    down the road popping of paint pellets at the lenses.
    Juvenile I'm sure you'll agree, but somehow satisfying.
    Tosspot, Sep 2, 2007
  9. deadmail
    Dave H. Guest
    burnt wrote...
    I've often wondered if a big clay doughnut, maybe a foot across, with a pile
    of thermite[1] in the middle would have an interesting (and also very
    charitable) effect if one were to slap it on top of a Gatso and light it
    up... The fingery-picture ones would be more of a task, though, as they fire
    the pics off to a central (and secret) location as they take 'em :eek:(
    Dave H.
    (The engineer formerly known as Homeless)
    "Rules are for the obedience of fools, and the guidance of wise men" -
    Douglas Bader
    [1] which gets rather warm, to melting-steel-and-anything-in-its-way
    temperatures, and drips molten iron into any available cavity..
    Dave H., Sep 2, 2007
  10. deadmail
    deadmail Guest
    Oh my dizzy aunt.
    deadmail, Sep 2, 2007
  11. deadmail
    deadmail Guest
    Yes, but these have been there for eight + years and it's never flashed
    me before.
    I think I'll go with the "don't worry about it" strategy.
  12. deadmail
    DR Guest
    A small cone of plastic explosive on the top, makes a small hole in
    the case and minces the contents. IIRC that's how some disgruntled
    French guy did it.
    DR, Sep 2, 2007
  13. deadmail
    Beav Guest
    With that kind of heat, I don't suppose it matters. Stick a can on top and
    not much on the inside would survive for long.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 2, 2007
  14. deadmail
    Beav Guest
    Either way, there's not much you can do until (unless) you get a NIP. Report
    back on 2 weeks with a yeah or nay on the NIP and this thread could go on
    forever:)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 2, 2007
  15. deadmail
    Tosspot Guest
    Where do you get the magnesium ribbon? And would a good old fashion
    sparkler suffice?
  16. deadmail
    <cough>
    You want to be very very careful thinking like this.
    Get caught using thermite on a Gatso and you will probably score 3 to 6
    years hard time.
    Much much safer and more obvious to passing motorists to spray them
    liberally with expanding foam.
    The one in Botley used to get this treatment, or so I heard.
    If you were to be stupid enough a steel beer can would make an excellent
    receptical and the long powder fuse found in many a firework would
    ignite it, using a long taper of course.
    You can mix a little thermite with other stuff for interesting results.
    For instance the contents of a FOAD firework and 100 mesh copper powder
    make a huge flash and *many* cubic yards of dense smoke. The sort of
    thing you might toss through the door of somewhere which had given some
    scoolboys a hard time. Perhaps.
    The **** chased us from near Glasgow Green all the way to the Gorbals,
    where his bravery gave up ;o)
    Hog, Sep 3, 2007
