Paging FOAK: Women
Discussion in 'UK Motorcycles' started by BGN, Jul 21, 2006.
  1. BGN
    Nor did I.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jul 24, 2006
  2. BGN
    antonye Guest
    There's a tagline for Cane if ever I read one.
    antonye, Jul 24, 2006
  3. BGN
    Beav Guest
    They'll go pink in the sun if they're cheap anodised.
    It has now it seems. Anyway, I've booked me food.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 27, 2006
  4. BGN
    Beav Guest
    If the frame is bare, (nothing attached t it, rather than stripped to bare
    metal is what I mean) it's cheaper to get it powder coated, and powder is
    more resistant to frame type knocks, so that's the way I go when I do full
    bikes. All the other bits (battery box, side stand, centre stand, bracketry.
    etc) I usually arrange to have done at the same time at around the hundred
    quid mark for everything.
    As for the rest (tank, seat unit (three pieces), fairings, front 'guard,
    frame fillets (them bits just below the tank) the frame accents if you want
    those doing (just above the footpegs) and the hugger if you've got one?
    Around 650 to the man in the street, 500 to you and a mint job you WON'T be
    ashaed to call your own.
    If it's not desperate and you want to talk about it, I'll be a EoSM, but I'm
    fucking off across to Bert Weedon on Monday for a fortnight, so it won't be
    easy contacting me after Sunday night.
    I've just rang my brother who's going to take a few pics of the B6, so when
    he does, I can flirt 'em across to you if you want. Just say the word.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 27, 2006
  5. BGN
    Hmm full R100RS bodywork in black with silver pinstriping. I think the
    transfers get laquered in. The inside of the fairings just get satin
    black. Same or more?
    Hog, Jul 28, 2006
  6. BGN
    Beav Guest
    Are the pins stripes "real" painted pins stripes, or sticker type?
    I'd do the inner surfaces as the factory would. Gloss if they're originally
    gloss, matte if not. The reason they're usually matte is purely from an
    emissions POV. No lacquer means no VOC's released, but I think it looks
    crap.
    Same or more?
    Pretty much the same. The jobs aren't done on a square foot basis so much as
    a "number of panels" basis (to a point anyway) as it doesn't take much
    difference in time to prep up a small fairing and a bigger one.
    I got the pics of the brother, so I can send them if you want. If I had
    somewhere to post them, I would, but I've not and I don't know where to
    start doing it anyway.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 28, 2006
  7. BGN
    Hand painted I believe
    Thanks for the info.
    Can you recommend a small airbrush/compressor combo up to touching in
    scrapes, helmets painting etc? maybe you think the aircan type are
    sufficient?
    Hog, Jul 29, 2006
  8. BGN
    Beav Guest
    Quality ones usually are, but mass produced jobs.... well I've never seen a
    hand painted pin stripe on anything less than a Bentley or Roller and even
    Roller will stick a sticker on after an accident repair iof they think they
    can get away with it.
    Actually, the aircan pressure isn't good at. Expensive and unreliable as the
    pressure drops from the off and they don't last close to long enough to get
    a job done. A good combo can be got from (of all places) Machine Mart.
    As for airbrushes, either single or dual action airbrushes (dual is best of
    course) will work, but you have more control with a dual and far less chance
    of spatter. Essential for fine detail work. My Olympus brush will paint a
    line .1mm wide, but that sort of detail isn't usually necessary. I also have
    an uber cheap brush I got brand new for 25 quid which is a copy of the
    slightly bigger Olympus which is excellent for 90% of airbrush jobs, so you
    don't have to spend a fortune.
    http://www.machine-mart-offers.co.uk/ for the airbrush, and
    http://www.machine-mart-offers.co.uk/ for one of their ultra quiet
    compressors.
    I've got a studio 'pressor like the one above and I paid over 500 quid fit
    nearly 20 years ago, so the price *may* look a bit high, but they're
    definitely better VFM than they were and they defy any attempt to kill 'em.
    You can even use them in close proximity to others without disturbing them
    too much, and if you use water based acrylic paints, you won't poison 'em
    either.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 30, 2006
  9. BGN
    Can you explain Dual Action in this context please? It only describes a
    certain genre of handgun to me.
    Hog, Jul 30, 2006
  10. BGN
    Beav Guest
    Single action 'brushes have an air valve which you simply press. This dops
    the pressure over the paint pickup tube and sucks up the paint. That's it.
    Point and press. The amount of paint ejected is "controlled" by the position
    the internal needle is set at. It's adjustable, but not on the fly. You have
    to stop spraying, change the needle position, then re-start and it's a
    fucking ball-ache.
    Dual action 'brushes have a "press and pull back" knob. Press for air, and
    air comes out the front of the gun, but **** all else. As you pull back the
    lever/knobby thing, the internal needle is pulled away from the aircap and
    paint is metered out. Big pullback = more paint, and vice-versa. MUCH better
    and a dual action is less likely to spatter because you can open the
    needle/aircap to it's fullest and flush with a dribble of thinners without
    upsetting and pre-set needle position.
    Cleanliness is everything with airbrushing and keeping an internal mix gun
    clean (single action) is a fucking nightmare.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 30, 2006
