paging for FOAK or Cane and Simian
Discussion in 'UK Motorcycles' started by darsy, Jun 1, 2006.
  1. darsy
    when hiring a van nicely big enough for three bikes for a roundtrip
    from Her Majesty's South Easth to Cadwell, do you pick a LWB hi-top
    transit for 120quid and fanny around with a plank, or choose the 200
    quid option to get a tail-lift luton van?
    It's the laziness -v- tightness debate.
    darsy, Jun 1, 2006
  2. darsy
    dwb Guest
    Tail lift. Between you and Cane you can afford it.
    Simian.... well... he can hold the drinks or something.
    dwb, Jun 1, 2006
  3. darsy
    of course I can afford it - it's more a case of whether it's worth it.
    We're going to do Cadwell sober this time - imagine!
    Actually, paging Sweller - this could be the decider - would you be
    around on the morning of Saturday 17th to take delivery of a manky old
    R65LS?
    darsy, Jun 1, 2006
  4. darsy
    TOG Guest
    Tail lift, not least because one of you is bound to bin a bike so badly
    that it will be physically impossible to push it up a plank.
    TOG, Jun 1, 2006
  5. darsy
    Morning will be a problem, I'm working until 16.00 ish.
    sweller, Jun 1, 2006
  6. darsy
    Vass Guest
    some high tops now have a very low floor level
    Vass, Jun 1, 2006
  7. In uk.rec.motorcycles, darsy belched forth and ejected the following:
    Tail lift.
    Whinging Courier, Jun 1, 2006
  8. In uk.rec.motorcycles, darsy belched forth and ejected the following:
    Of course it's worth it.
    Just how do you think you're going to get a bike up a plank at an
    approximate angle of 45 degrees? You'll need a long fucking plank if you
    want a shallower angle and then you've got to make sure the bike stays
    on the fucking thing on the way up.
  9. darsy
    With three or four bikes to do it'll be worth it. Don't forget you'll
    have to source a plank. I know they're only £8 new from SGB but you've
    got to get over to the scaffold place etc etc.
  10. darsy
    darsy said...
    Tail-lift, without a shadow of a doubt. They make life just so much
    easier, unless you have a proper ramp.
    Lozzo, Jun 1, 2006
  11. darsy
    arse. If I have to hang on to the van until Monday, it's another 100
    quid.
    Some other time.
    darsy, Jun 1, 2006
  12. darsy
    [email protected], ,
    heh.
    darsy, Jun 1, 2006
  13. Which, with Darsy's towering heights, might be a problem.
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Jun 1, 2006
  14. darsy
    OK.
    darsy, Jun 1, 2006
  15. darsy
    I think you're right.
    We used a plank the last time and it was a pain in the tits.
    darsy, Jun 1, 2006
  16. Once you drop one off the plank the 200quid seems a bargain.
    Grimly Curmudgeon, Jun 1, 2006
  17. They have some trucks making deliveries on the CERN site that
    somehow jack the whole cargo box off the frame down to ground level (maybe
    tilted rather than level). Don't think I've ever seen that before.
    Brunel University. [email protected][brunel.ac.uk|cern.ch] Room 40-1-B12, CERN
    Dr Ivan D. Reid, Jun 1, 2006
