Paging hi-fi/electronics chaps
Discussion in 'UK Motorcycles' started by Champ, Apr 24, 2009.
  1. Champ
    zymurgy Guest
    Sigh, no, but there are PSU's in audio amps, with big smoothing
    electrolytics. I wouldn't want one of those discharged through me
    either ...
    Paul.
    zymurgy, Apr 25, 2009
    #41
  2. Champ
    Nige Guest
    One bloke i worked with got thrown meters & I mean meters in the air from a
    really rather large capacitor used in some switchgear once.
    Nige,
    Honda VTR1000 SOLD!
    BMW K1200S
    Range Rover Vogue
    Aprilia RSV Mille
    Nige, Apr 25, 2009
    #42
  3. Champ
    Eiron Guest
    The power rail in Champ's amp is probably about 30V.
    You wouldn't even feel it through your fingers.
    You would have to put your tongue on +30V and your knob on -30V to get a
    shock worth reporting.
    Eiron, Apr 25, 2009
    #43
  4. Champ
    zymurgy Guest
    Ok. i'll throw caution to the wind next time.
    Maybe i've spent too much time poking around the back of old telly's
    which gives you a natural caution.
    Paul.
    #44
  5. Champ
    says...
    "Everybody should have a little Greek in them."
    #If a picture paints a thousand words ....
    Pip, Apr 25, 2009
    #45
  6. Champ
    You really don't want to be fucking around with LOPTs or discharging
    old TV CRTs, believe me. My dad's a TV engineer and I learnt the hard
    way when I was about 8 yo.
    Lozzo
    Versys 650 Tourer
    Fireblade 929 (For sale)
    CBR600F-W trackbike
    SR250 SpazzTrakka,
    SR250 wivva topbox
    TS250C
    RD400F, somewhere
    I see a bright new future, where chickens can cross the road with no
    fear of having their motives questioned
    Lozzo, Apr 25, 2009
    #46
  7. Champ
    geoff Guest
    In message
    Determined, eh ?
    .... how many volts ?
    You could have a 100,000 uF capacitor at 24volts in a hi-fi which
    wouldn't even tickle
    A puny little 1uF 250 v capacitor would wake you up
    geoff, Apr 26, 2009
    #47
  8. Champ
    I have my own version of percussive maintenance: several years ago I
    bought an old Xeta-1 home cinema amp for use simply as an audio amp. A
    few months later it developed an intermittent o the RH speaker. I
    found that lifting the amp up and banging it down hard once or twice
    usually fixes it for another few months.
    The fault is (I think) a dry joint on a ribbon cable header. The
    trouble is it's edge-on behind the front panel and would require
    either a long (and preferebly bent) soldering iron tip or major
    disassembly from access. The cable itself, oddly (from past
    experience) seems fine.
    Pip Luscher, Apr 28, 2009
    #48
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip Luscher
    I've probably told this tale before, but a mate of mine used to work on
    a particular radar set in t'army that had an intermittent problem with a
    sticking relay. Hitting the case just *there* would unstick the relay
    and everyone could get back to the serious business of killing
    foreigners.
    A new officer arrived and disapproved strongly of his squaddies hitting
    government property. He insisted on a proper solution to the problem.
    My mate installed a large, clearly labelled, "RESET" button which, when
    pressed, would restore normal operation. It had a little plastic flip-up
    cover, and everything. Officer was happy, normal operation was restored.
    Hitting the button energised a large solenoid that would whack the case
    just *there*...
    go and talk to the Catholics.
    Wicked Uncle Nigel, Apr 28, 2009
    #49
  10. Champ
    Heh, brilliant!
    Pip Luscher, Apr 29, 2009
    #50
  11. Champ
    Excellent. Inventive solutions for a better world.
    Ace, Apr 29, 2009
    #51
