Paging: Hog/Lozzo
Discussion in 'UK Motorcycles' started by Jeweller, Jul 5, 2009.
  1. Jeweller
    Jeweller Guest
    That old barge of mine needs its clutch repairing/restoring.
    It's done about 50K and I gather this is normal maintainance.
    Recently I have noticed a certain delay between right hand
    activity and road speed, so I'm making assumptions about the
    clutch.
    Is this a task for an inexperienced mechanic?
    R100RT
    Aprilia Pegaso 650 IE "The Flying Mythos"
    Formerly: James Captain, A10, C15, B25, Dnepr M16 solo,
    R80/7, R100RT (green!)
    www.davidhowardjeweller.co.uk
  2. Jeweller
    I put a new clutch into a /7 about 10 years ago. If you have tools and a
    shed, it's not too bad.
    platypus, Jul 5, 2009
  3. Easy, but you really need to arrange a sensible working height for it,
    makes it soooo much easier to work on.
    Grimly Curmudgeon, Jul 5, 2009
  4. Jeweller
    Hog's the man to ask, I never work on BMWs
    Lozzo, Jul 5, 2009
  5. Jeweller
    Jeweller Guest
    That bit I do know.
    R100RT
  6. Jeweller
    Start with the clutch cable, is it ok. If they get really gunged up and
    stiff then it could be to blame. Check the adjustment at the arm on the
    rear of the gearbox and at the bars too obviously.
    Failing that.
    rear wheel out.
    final drive box off.
    disconnect drive shaft UJ (12 point ring spanner)
    swinging arm out
    gearbox out after removing carbs and airbox
    You need something to get the clutch plate centred to refit the gearbox
    (there is a tool but a right size mandrel does)
    check the thrust bearing on the clutch actuating arm at the rear of the
    gearbox. they wear and break up. replace it if in doubt
    if the gearbox input seal is leaking or if the box seems stiff, that
    rebuild is a job for someone who knows, the shaft endfloats are shimmed
    if the crank output shaft seal is leaking it can be replaced in situ
    with the correct drift
    Hog, Jul 6, 2009
  7. Jeweller
    those monkeys can come in quite handy.
    darsy, Jul 6, 2009
  8. Jeweller
    Jeweller Guest
    That's a comrehensive list. The cable set-up is good.
    I see many operations there that I could screw up.
    I'll get it to a man who knows, Roy Gardner near Preston,
    knows his stuff and charges accordingly.
    Thank you.
    R100RT
    Jeweller, Jul 6, 2009
  9. Jeweller
    It's a simple enough job but what do you do when something more
    complicated is discovered and you have a dismantled bike on the bench.
    Hog, Jul 6, 2009
  10. Jeweller
    Jeweller Guest
    That's just the scenario I want to avoid.
    What bench?
    R100RT
  11. Take the complicated bit out and throw it in the car boot.
    Grimly Curmudgeon, Jul 7, 2009
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Second one's a given, no?
    go and talk to the Catholics.
    Wicked Uncle Nigel, Jul 12, 2009
