Paging: kitchen DIY types
Discussion in 'UK Motorcycles' started by Switters, Jan 30, 2010.
  1. Switters
    Switters Guest
    I'm looking for something the will go under the unit plinths to seal it
    against the wooden floor, preventing dust and the like from getting
    under the units.
    I found some stuff:-
    http://www.kitchen-storage.co.uk/product2_912-1-71-1820_Plinth-Sealing-Strips,-18-19-mm-Panels.htm
    but I'm not keen on the prospect of a plastic strip running the whole
    length of the units, spoiling the wood on wood action (fnarr). The
    floor's not 100% level so there are varying gaps against the plinth of
    1-3mm.
    What about some of those soft foam seals that are sometimes put around
    doors to keep drafts out? They look quite thick, although I suppose
    they're very squishy in order to fit on the inside of a door jam.
  2. They are squishy, but if the kitchen is already installed, they'll be a
    twat to get underneath the units. They'll also look a bit gash imho.
    I guess you could use some quarter round edging, stained the right
    colour to match the floor and/or units. Might also look gash, but cheap
    enough to try out first.
    doetnietcomputeren, Jan 30, 2010
  3. Switters
    mark Guest
    If you can find a strip that matches the colour of the plinth it might
    not be so noticeable. Depends on how different the floor colour is....
    Scribe the plinths?
    mark, Jan 30, 2010
  4. Switters
    Vass Guest
    Magnet used[1] to do a wood coloured version that did was only 3mm high on
    the visible side.
    [1] about 8 years ago when I installed a kitchen
    Vass, Jan 30, 2010
  5. Switters
    Fr Jack Guest
    A thin bead of silicone sealer.
    Fr Jack, Jan 30, 2010
  6. Switters
    Switters Guest
    The plinth actually clips onto the legs of the units, so they're
    easy(ish) to remove. So whilst that's a good idea otherwise, I wouldn't
    want to use it in this case.
  7. Switters
    Switters Guest
    B&Q do a dark brown version, but it's too dark.
  8. Switters
    Switters Guest
    I can remove the plinth OK, so could easily add such a thing, but yeah,
    I think you're right on the looking gash point though.
  9. Switters
    Ben Guest
    I ran a really tiny bead of silicon sealant around the base of the
    plinths. You can't see it unless you're up close, but it keeps out
    water from floor cleaning and dust.
    Ben, Jan 30, 2010
  10. Switters
    Colin Irvine Guest
    What about floor-sealers like these.
    http://www.gapseal.co.uk/
    http://www.stopg-p.co.uk/
    Colin Irvine, Jan 30, 2010
  11. Switters
    Switters Guest
  12. Switters
    Beav Guest
    Something like felt (baize/whatever the **** it's called) like wots used on
    a Snooker table or under chair legs of kitchen/bar stools, or even clear
    silicone in a tube. Squirt it in, then "finger" the edge to give a clear and
    tidy seal.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 30, 2010
  13. Switters
    Catman Guest
    The silicone won't stop the plinth from being removeable easily.
    www.cuore-sportivo.co.uk
    Catman, Jan 30, 2010
    steve robinson, Jan 30, 2010
  15. Switters
    Dan L Guest
    My kitchen unit plinths have that kind of seal on them, but they are a
    brownish colour so one doesnt really notice them
    Dan L, Jan 30, 2010
  16. Switters
    Vass Guest
    and a clear version £ 4 per length
    Vass, Jan 30, 2010
  17. Switters
    Switters Guest
    Ah, I did see some brown ones too. Cheers.
    Switters, Jan 31, 2010
