Paging Loz
Discussion in 'UK Motorcycles' started by Whinging Courier, Mar 29, 2007.
  1. Whinging Courier, Mar 29, 2007
  2. Whinging Courier
    Whinging Courier says...
    You're back on the drugs again, aren't you?
    Lozzo
    Suzuki Bandit 600S (Green with added shit bits)
    Yamaha SR250 Delusion (It's "Special")
    Homefucking is killing prostitution.
    Lozzo, Mar 29, 2007
  3. Whinging Courier
    Dan L Guest
    Dan L, Mar 29, 2007
  4. Whinging Courier
    Dan L says...
    Because they are used on the road between trials sections.
    Lozzo
    Lozzo, Mar 29, 2007
  5. Whinging Courier
    Dan L Guest
    Lozzo coughed up:
    <thicko mode on>
    Should it not also have a number plate then?
    Dan L
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 29, 2007
  6. Eh? When I saw you the other day you were talking about making that SR
    into a Speedway bike..
    Whinging Courier, Mar 30, 2007
  7. If you believe what you read then all bikes will have plates at some
    time in the future.
  8. Whinging Courier
    Dan L says...
    Technically, yes.
    Lozzo
    Lozzo, Mar 30, 2007
  9. Whinging Courier
    But, er, that's a trials bike...
    ogden
    sv650 (slow)
    cg125 (dead)
    zx7r (in bits)
    Last few 7R bits: http://search.ebay.co.uk/_W0QQsassZdr.daifQQhtZ-1
    ogden, Mar 30, 2007
  10. Whinging Courier
    ogden says...
    It wasn't a speedway bike I was thinking of either. Methinks WC is under
    the impression that anything with knobblies is a multi-purpose
    trail/trials/motocross/speedway/flat-tracker/adventure bike.
    Lozzo
    Lozzo, Mar 30, 2007
  11. <Grin>
    I did wonder about the size of the seat on the SR and wanted to ask but
    didn't about whether you were going to keep the brakes on it or not.
  12. Whinging Courier
    The seat will be modified to suit the style of the whole thing. I've
    laready had it apart to see what's possible and made my mind up about
    what's getting done.
    Those brakes are staying, unless I can find the right DT fork
    lowers/wheel hub to use with the stanchions that are fitted. Then I can
    fit a TZR250 disc with an R1 bluespot caliper.
    Lozzo
    Lozzo, Mar 30, 2007
