Paging Lozzo and them wot knows carbs...
Discussion in 'UK Motorcycles' started by Nigel Eaton, Nov 2, 2003.
  1. Nigel Eaton
    Nigel Eaton Guest
    I popped in to SpeedySpic Engineering this afternoon, because I was
    struggling with the carbs on the 'Wing. They're supposed (according to
    the BoL) to pull 21mm of vacuum +/- 2.5, and they weren't even close.
    After some pissing about, the consensus was that there was probably a
    split diaphragm. A good theory, but with one essential flaw...
    These carbs don't have diaphragms[1]. They've got these cute little
    pistons that go up and down instead.
    Now, there's a *lot* of shit kicking around inside there, so that may
    not be helping, but the pistons move quite freely.
    On the float bowl with the main fuel pipe leading into it there's a
    little rubber diaphragm (about 1" across) which is pushed down by a rod
    which is hit by the throttle arm on opening. Some kind of crude
    accelerator pump? The BoL has no sign of it, of course. That was full of
    crud and the rod had rust on it. I've cleaned that up.
    The gaskets that seal the inlet manifolds to the cylinders look pretty
    shot too. They'll get replaced.
    Before I put all this back together, anyone got any other suggestions as
    to why an even tickover is hard to get, they pull very little vacuum at
    tickover, and the pick up is 'woolly'?
    [1] Which is nice, 'cos "diaphragms" is a **** of a word to type...
  2. Nigel Eaton
    deadmail Guest
    Do the revs take a while to settle again after you blip the throttle?
    If so it *might* be a leak at the intake.
    I hate carbs with a passion. Fucking fiddly things when they go wrong.
    deadmail, Nov 2, 2003
  3. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    What is this "settle" of which you speak? It's a definite possibility,
    especially given the state of the inlet gaskets.
    Yep. Second behind electrical shit in my book.
  4. Nigel Eaton
    deadmail Guest
    You know, drop back to 1k or whatever it's meant to tick over at.
    Hmm, electrical isn't as bad as carbs afaic.
  5. Nigel Eaton
    Nigel Eaton Guest
    typed
    Heh. Yeah, I knew that. I was kind of trying to subtly make clear that
    an even tickover is not currently on the menu. ;^)
  6. Nigel Eaton
    Sean Guest
    Nigel Eaton let forth with a mighty belch and uttered :
    <snip lots>
    Do these carbs have oil dampers a la SU carbs?, if they have, and they are
    dry of oil, it may affect it. The dampers are really to stop the piston
    rising too fast when you crack open the throttle. The prescence of what
    appears to be a crude accelerator pump may mean they haven't. Another
    funtion of them is to smooth out fluctuations at idle or low throttle
    openings. On multi-SU carbed engines, you can tell when one carb is low on
    oil as you can't balance the buggers[1]
    Probably utterly wrong, but easy enough to check.
    [1]Yes, I learned the joys of SU on Minis.
    Sean, Nov 2, 2003
  7. Nigel Eaton
    Salad Dodger Guest
    For your delectation...
    http://www.newcovenant.com/features/motors/GLtuning.html
    | ___ Salad Dodger
    |/ \ GL1500SEV/CBR1100XXX/KH500A8/TS250C/exTS185C
    _/_____\_ ..61132../..13991.../..3157./.19406/.fecked.
    |_\_____/_| IMC#4 TPPFATUICG#7 YTC#4 DIAABTCOD#9 PM#5
    (>|_|_|<) BOTAFOT #70 two#11 Ignoramus #0001
    |__|_|__| BOTAFOF #09 IbW#0 & KotIbW# OSOS#07
    \ |^| / WG* BotTOS #6 GP#4 ANORAK#17 FTB#14
    \|^|/ 2003 RBR landmarks:99 points:2100 miles:8000
    Salad Dodger, Nov 2, 2003
  8. Nigel Eaton
    Mark Olson Guest
    The description of the metal piston carbs leads me to assume they are
    similar to what's on my '81 CM400T and was on my ex '81 CB900C. There is
    another possible vacuum related rubber bit on these carbs, called the
    air cutoff valve, it's behind a little round plate on the side of each
    carb, secured with three screws. I'm not quite sure how they work but
    if those diaphragms are perished, I am sure the carbs won't work as
    designed.
    I'd also make sure the inlet rubbers that go between the carbs and the
    cylinder head are up to snuff. Some Hondas of that era use inlet
    rubbers with a metal flange toward the cylinder head that used an O-ring
    to seal against the cylinder head. That O-ring can harden up over
    time due to heat, and should probably be replaced if you have that type.
    The carbs are somewhat reminiscient of the SUs I had on my MGBs, but
    they do *not* have an oil damper.
    Mark Olson, Nov 2, 2003
  9. Nigel Eaton
    Nigel Eaton Guest
  10. Nigel Eaton
    Ben Blaney Guest
    I always have trouble with "netwrok". "Enjoyment" is a cracker, though.
    Ben Blaney, Nov 2, 2003
  11. Nigel Eaton
    deadmail Guest
    I *thought* you might but the questionmark made me wonder... Feeling
    remarkably lacking in humour tonight.
    Bought a load of kit from a computer fair to build a new PC (nothing
    flash, athalon XP2200). Got it all home, put motherboard, processor and
    memory into case (bought from same shop) connected a monitor... and...
    nothing just some beeps.
    Took it back... "sorry we can't look at it today". "Well I'd like a
    refund then". Spent the next 30 minutes pulling it apart and
    substituting bits. Eventually they concluded it was the processor that
    was fucked. They didn't have one of these so leant me a Duron 1400 for
    two weeks (bought from a computer fair) and said they'd swap the
    processors in two weeks; and put this in writing on a receipt. Fair
    enough.
    So then went home and built it up. Much cocking about later and the
    audio/lan won't work. Drivers don't appear to be present for Windows
    98. A little websurfing and.... it transpires that the motherboard
    Nvidia chipset bits don't have drivers for Windows 98 only 2000 or
    later.
    *sigh* that's a copy of XP I'll need to order then.
  12. Blocked pilot jets or incorrect pilot jet settings.
    The Older Gentleman, Nov 3, 2003
  13. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Nigel Eaton
    Bad form, ya-da ya-da...
    A call to David Silver reveals that they're (probably) carbs from an
    early 1100. I'm hoping this isn't going to turn into a major problem...
    Anyway, carb rebuild kits and new gaskets on their way.
    Nigel Eaton, Nov 3, 2003
  14. Nigel Eaton
    I have a man(1) sitting next to me who Knows These Things. He says he
    knows a man who knows early Wings - and their carb problems. Bottom
    line - the crbs are fucked. The internal passageways and ports are
    furred up and you cannot get at them to clean them out.
    New carbs is the only way out of this, mate. Do it now, do not
    hesitate as they are in pretty short supply and getting shorter.
    Argh.
    1. Col. Tupperware of this parish - 'e knows 'is 'ondas.
    Pip, Nov 3, 2003
  15. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    Oh arse. And further arse. With a side helping of arse.
    Well, the kits are on order. I might as well at least try...
    Hah don' lahk heem no more.
  16. No
  17. Har well fark yu and the hoss you rod in on Gringo.
    I was thinking, that maybe the only way to clean 'em out would be to
    try an ultrasonic bath. There was one up on ebay the other day for
    about 70 of your earth sponduliks.
    My expert, (yes he really is an expert) on older Wings told me about
    this problem when I asked him for some advice on a bad running wing.
    HE say it is well known amongst the Wing fraternity that GL1000 and
    GL1100 carbs will furr up when they haven't been used for a while and
    it writes them off.
    ColonelTupperware, Nov 3, 2003
  18. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, ColonelTupperware
    <> typed
    (Of 'Wing carbs)
    Ooh! A chance to spend money. Thank you.
    That's a bugger. As I said I'll have to at least try. Matey said that he
    had been starting the thing fairly regularly, so maybe there's hope.
    Thanks for the advice.
  19. An incorrect float height and or has been compensated for by over
    adjusting the low speed air screw would give this effect (if it has an
    air screw). Check the float heights with a vernier gauge.
    Mick Whittingham, Nov 3, 2003
  20. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Mick Whittingham
    I shall do that.
    I have just spilt beer all over the V5 for the GoldWing.
    That seems curiously appropriate, somehow.
    Nigel Eaton, Nov 4, 2003
