Paging Lozzo....
Discussion in 'UK Motorcycles' started by Spete, Oct 26, 2006.
  1. Spete
    Spete Guest
    .....or anyone else that can shine a light.
    Just this morning as I'd taken my bike and wanted to take off, the bike
    started to run very rough. It felt a bit like a couple of weeks ago when I
    (nearly) ran out of fumes. It had been fine since.
    Bike sounds rough and shudders more noticably than a normal V-twin. Bit like
    a Harley on idle it is now, if it keep running at all. I have to keep it at
    at least 1500 rpm to keep it going. I can't even outrun cars now.
    Any ideas?
    Spete, Oct 26, 2006
  2. Spete
    Ken Guest
    Check all the usual things first, but if its not an injected bike, sounds
    like you may well have carb problems.
    k
    Ken, Oct 26, 2006
  3. Spete wrote
    Shit in the carbs.
    steve auvache, Oct 26, 2006
  4. Spete
    TOG Guest
    Carb icing? Does it get better when it's warmed up?
    What bike, anyway?
    TOG, Oct 26, 2006
  5. Spete
    Spete Guest
    <TOG@toil>; <>; <>
    wrote in message
    Carb icing would very much surprise me as it's about 20 degrees here. It's a
    1998 VTR1000 Firestorm (in black)
    Spete, Oct 26, 2006
  6. Spete
    Piss in the tank.
    ogden, Oct 26, 2006
  7. Spete
    Spete Guest
    Done both, didn't work. It ran even more piss-shite...
    Spete, Oct 26, 2006
  8. Spete
    TOG Guest
    Ah, right. Didn't know where you were :)
    OK, carbed, not injected. You haven't had the fuel tank off? Kinked a
    fuel line? If you nearly ran out of petrol, it might also have sucked
    crap from the bottom of the tank into the fuel filter, so I'd check
    this.
    I really doubt it's a carb problem - in my experience carbs don't
    suddenly decide not to work unless someone's fiddled with them. They
    could have sucked in crap, but there should be filters to stop this.
    TOG, Oct 26, 2006
  9. Spete
    Spete Guest
    <TOG@toil>; <>; <>
    wrote in message
    Right, I suspect it may be a problem with a sparkplug. I've also noticed a
    distinct petrol smell. Crap may be a factor, but I would have suspected
    problems earlier. The lack of fuel happened a few weeks ago. Brought it to
    the garage now. See what they say. Thanks for the pointers though.
    Spete, Oct 26, 2006
  10. Spete
    TOG Guest
    If it's not firing properly on one pot, that would certainly explain a
    petrol smell. Hm. Duff plug, maybe coil? Keep us posted.
    TOG, Oct 26, 2006
  11. Spete
    Spete Guest
    <TOG@toil>; <>; <>
    wrote in message
    Sparkplugs changed, bike's had a once-over, choke mended. Optimate still
    doesn't like my battery though. Starts off on orange light, when I return
    the next morning it's red. Bike starts though.
    Spete, Oct 30, 2006
  12. Sparkplugs, lube, less than an hour labour - what did that lot come to
    then? €70ish?
    DoetNietComputeren, Oct 30, 2006
  13. Spete
    A grand, surely.
    ogden, Oct 30, 2006
  14. Spete
    Spete Guest
    then? ?70ish?
    Twice that, approx...
    Spete, Oct 30, 2006
