Paging Lozzo
Discussion in 'UK Motorcycles' started by Eddie, Apr 23, 2007.
  1. Eddie
    Eddie Guest
    When you rebuilt those calipers, did you replace the O-rings between the
    caliper halves?
    I'm guessing you probably did, but if not I'll put new ones in to see if
    it cures the air leak.
    Eddie, Apr 23, 2007
  2. Eddie
    Eddie says...
    I did. They had a complete new set of seals all round - cost me a small
    fucking fortune they did.
    Might be worth a go.
    Lozzo
    Suzuki GSX-R750L trackbike (Shite with added shite bits)
    Yamaha SR250 Delusion (It's "Special")
    I ride way too fast to worry about cholestorol.
    Lozzo, Apr 23, 2007
  3. Eddie
    Eddie Guest
    I thought you had, but I wanted to make sure.
    I'll bet.
    I'll try new O-rings, nipples and copper washers. I can't think of any
    other possibilities.
    Eddie, Apr 23, 2007
  4. Eddie
    The master cylinder?
    Hog, Apr 24, 2007
  5. Eddie
    Eddie Guest
    Hah!
    Been there, done that, no difference whatsoever.
    Eddie, Apr 24, 2007
  6. Eddie
    Thing about this concept of air being drawn in is that's it's difficult to
    imagine fluid under pressure not coming out. Some kind of diffusion perhaps,
    I dunno, had the same problem though. New seals, new lines, new fluid, it
    still kept getting spongy. I sold the fucker.
    Gas diffusion through micro cracks in the caliper material or somesuch
    perhaps. I've worked with the situation where hot sodium ions could progress
    through micro cracks in weld areas but nothing moved through from the steam
    side.
    Hog, Apr 24, 2007
  7. Eddie
    Jeremy Guest
    My favourite major industrial disaster waiting to happen....
    Jeremy, Apr 24, 2007
  8. Eddie
    Eddie Guest
    I'm guessing that when there's pressure against the seals (e.g. braking,
    or with the lever tied back to the bar overnight), they deform
    sufficiently to prevent fluid escaping.
    When there's no significant pressure, the gaps are small enough the
    surface tension (maybe) keeps the fluid in place, but allows the fluid
    to absorb air from the atmosphere... perhaps.
    When I try bleeding the right-hand caliper, I get a line of very small
    bubbles, however much fluid I pass through the system; I assume it's
    getting drawn in wherever the leak is, but I can't think of a way of
    determining where that point is.
    I'm fairly confident that it's something in the calipers, as the rest of
    the system was fine with my original calipers.
    It's much more likely to be a dodgy O-ring or nipple, I'd have thought.
    Eddie, Apr 24, 2007
  9. Eddie
    Umm in France only, not in the UK
    Hog, Apr 24, 2007
  10. Eddie
    Jeremy Guest
    Great. I live in France.
  11. Eddie
    Whereabouts?
    Oh, and it'd be really useful if you could change your posting name
    ever-so-slightly.
    _______
    Ace, Apr 24, 2007
  12. Eddie
    Jérémy Guest
    Above Onnion, which is above St Jeoire, which is on the way to Samoens.
    You must have been out of the room when we discussed this before. There is
    no possible risk of me being confused with any Jeremy who knows anything
    about bikes. Or computers. Or wildlife[1].
    Oh alright, I've done it once today already ... just this one post, mind.
    [1] This reminds me - Jeremy, I don't think you told us what became of the
    deer.
    Jérémy, Apr 24, 2007
  13. Eddie
    Well well. I drive past your door a few times each ski season - just
    the once this year, as it happens, due to injury. At busy periods I
    always prefer to use the Vallée Verte rather than the motorway.
    Sure, but it's nice to be able to see from the posting name whether
    it's likely to be something worth reading...
    _______
    Ace, Apr 24, 2007
  14. Eddie
    Jérémy Guest
    I thought you'd know the area. Maybe we should meet up next season.
    My commute. Well, that or the surrounding lanes.
  15. Eddie
    Eddie Guest
    message
    "Red rubbery stuff"? That narrows it down. Some kind of brake caliper
    grease, I guess, rather than instant gasket...
    My brake caliper grease isn't red and certainly isn't rubbery; it's more
    like normal grease, but kind of translucent white in colour. I'm not
    sure that it would help, but I suppose I could give it a try.
    The calipers are no longer wearing the nipples that Lozzo supplied;
    there is no trace of anything red or rubbery.
    Eddie, Apr 24, 2007
  16. Eddie
    Nidge says...
    I do remember giving the one sachet I had away. It came with a set of
    genuine Yamaha seals I got. I've no idea if it's sold seperately.
    Lozzo
    Lozzo, Apr 24, 2007
  17. Eddie
    In any case, if it's the nipple threads that're suspect, a drop or
    three of Threadlock will sort it out, as well as making sure the
    nipples a)don't come loose and b) are easy to slacken off next time.
    _______
    Ace, Apr 25, 2007
  18. Eddie
    Eddie Guest
    That's what the pipe tape's for, surely?
    Eddie, Apr 25, 2007
