Paging Lozzo
Discussion in 'UK Motorcycles' started by AW, Jan 8, 2008.
  1. AW
    AW Guest
    Advice, please! I've got to reupholster teh drivers seat on my
    Morris. I've got the recovering kit, new foam and so on. Any tips or
    hints on fitting it?
    AW, Jan 8, 2008
  2. AW
    AW says...
    Trim your fingernails. Don't push the D clips on fully until you're sure
    you have the cover lined up because the little tangs cut the vinyl. If
    you get stuck give me a shout and I'll guide you through it, but they
    arimple enough to do.
    Are the covers glued down or do they just sit on the foams?
    Lozzo, Jan 8, 2008
  3. AW
    Mark Olson Guest
    Hire Loz.
    Mark Olson, Jan 8, 2008
  4. For your sake or the material?
    steve auvache, Jan 8, 2008
  5. AW
    steve auvache says...
    The material, it marks and gets scuffed easily when being pulled over by
    sharp nails.
    There's also a rule I was taught: If it's so tight that you have to dig
    your nails in to grip it, then something's wrong - take it off and start
    again.
    Lozzo, Jan 8, 2008
  6. AW
    AW Guest
    Heh. If he were local to me, I would
    AW, Jan 8, 2008
  7. AW
    AW Guest
    Separate, just sit on the foam. There's a sort of horsehair pad for
    the squab.
    AW, Jan 8, 2008
  8. AW
    AW says...
    By Squab, you mean the bit you sit on, not the backrest?
    Lozzo, Jan 8, 2008
  9. AW
    AW Guest
    Lozzo  wrote:
    Hmm. I meant the back rest but it says 'squab' on the packet!
    AW, Jan 8, 2008
  10. AW
    AW says...
    That's ok then, everyone usually gets the squab and cushion mixed up.
    You got it right.
    Lozzo, Jan 8, 2008
  11. AW
    AW Guest
    Phew.
    AW, Jan 8, 2008
