Paging M25 Traffic police
Discussion in 'UK Motorcycles' started by Whinging Courier, Jun 25, 2006.
  1. Those variable speed limits..
    When there are no limits, I.e NSL, are the cameras active and if they
    are, what speed do you need to be doing to trigger them?
    Oh yeah, and do they cover all three lanes?
    Cheers.
  2. Whinging Courier
    Tim Guest
    Yes and it varies. Normally seen triggered at 90.
    Yes.
    Tim, Jun 25, 2006
  3. In uk.rec.motorcycles, Tim belched forth and ejected the following:
    Cheers.
  4. Whinging Courier
    YTC#1 Guest
    Way back in the annals of UKRM I beleive JP tipped us to the fact you need
    to go over the ton to trigegr when the varaible speed limit is not set.
    I have successfully negotaied them at an indicated 95, so 90 seems ok.
    YTC#1, Jun 25, 2006
  5. Whinging Courier
    Kiran Guest
    I'm not sure that's right, actually. Only because I read the other day that
    the inventors of the Gatso have developed a new camera which does have the
    ability to cover lots of lanes at the same time.
    Kiran, Jun 25, 2006
  6. Whinging Courier
    ginge Guest
    The current set-up is they have 1 camera above each lane...
    ginge, Jun 25, 2006
  7. Whinging Courier
    Tim Guest
    Both to some extent. I saw a cage get done at 85-ish on one occasion and
    yet done coughmumbleeek-mph myself at other times. There doesn't seem to
    be any rule of thumb for it.
    Tim, Jun 25, 2006
  8. Whinging Courier
    Tim Guest
    [/QUOTE]
    There is a camera per lane installed and there is some overlap.
    Tim, Jun 25, 2006
  9. Whinging Courier
    HVB Guest
    I think it would be more correct to say that there is the possibility
    of having one camera per lane.
    For a start, most of the gantry camera positions are empty, most of
    the time. They do move them around. Occasionally there are two
    cameras on one gantry, covering different lanes (usually the outer
    ones), but normally if there are any cameras at all, there's just one
    per gantry.
    All IME, YMMV. Other disclaimers may apply.
    HVB
    HVB, Jun 25, 2006
  10. Whinging Courier
    Andrew998 Guest
    He did indeed but subsequently posted that they had been reduced to
    something like 94mph.
    As has been said elsewhere, most of the boxes are empty but there is no
    consistency as to which lane has a camera. I have yet to see any on the new
    gantires where they have widened the motorway by the airport.
    There is only one gantry per junction that has cameras fitted although one
    or two have 2 cameras on that gantry. Don't assume they are in lane 4
    because there are some in lane 2 or 3. They are on the same gantry both
    sides so if you can see a flashgun in the gantry you are approaching (facing
    the other way) you will know there is one on your side too.
    Finally, the roadworks up near J18 have SPECS cameras that average speed
    between 2 points although these are front facing.
    Andrew998, Jun 26, 2006
  11. Whinging Courier
    YTC#1 Guest
    Good job my clock is 7% out :)
    a) Easy to spot
    b) Who cares when on bike ?
    YTC#1, Jun 26, 2006
