Paging Pip
Discussion in 'UK Motorcycles' started by Gyp, Dec 27, 2008.
  1. Gyp
    Catman Guest
    I suspect you could justify, even being married. You just couldn't get
    away with it :)
    www.cuore-sportivo.co.uk
    Catman, Dec 27, 2008
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    Presumably you'll want to check for regular changes of snake-oil as
    well?
    Wicked Uncle Nigel, Dec 27, 2008
  3. Gyp
    Alan Crowder Guest
    Probably, best i move it back in then.
    Thanks
    Alan
    Alan Crowder, Dec 28, 2008
  4. Gyp
    Gyp Guest
    You're just doing this to confuse me, aren't you?
    Gyp, Dec 28, 2008
  5. Gyp
    MD Guest
    Eeeek, that's a dreadful concept to mention now (that it's too late, I
    mean) :-(
    Is this a CD player AND an amp that's been FSCK'd recently?
    If so, maybe there is more to this than just 'age'?
    MD, Dec 28, 2008
  6. Gyp
    Gyp Guest
    Sort of, yes and no. But more no than yes. By which I mean that the
    amp/sub thing is electrical but the CD problem is mechanical and fairly
    long standing [1]
    **** off. It's nothing to do with my age.
    [1] It's not loaded right for a couple of years but has responded to
    reseating the disk and/or repeated attempts. It was only when it stopped
    loading altogether than I did something about it.
    Gyp, Dec 28, 2008
  7. Gyp
    Gyp Guest
    <snip>
    Forgot to add...
    Do you think I could use the guts of item 350143144610 to replace the
    amp in the sub..? :)
    Gyp, Dec 28, 2008
  8. Gyp
    MD Guest
    fairly long standing [1]
    Fairy snuff now you put it like that.
    Oooh errrr, touchy about a certain subject are we?
    Except the shipping charges will bankrupt you? ;-)
    MD, Dec 28, 2008
  9. Gyp
    Timo at Work Guest
    Cyrus CDwhateveryoucanafford.
    Yes, they're an odd form factor but IMHO they do sound very good, plus
    they do have decent after-sales service. I've got one and got my mum
    another one which wanted a new laser. Cyrus sorted that out very
    quickly and for a lot less than I thought, plus they were extremely
    helpful on the phone. I'd like to support a business like that, even
    if I don't want to purchase any new kit off them.
    Timo at Work, Dec 28, 2008
  10. Gyp
    Gyp Guest
    In principle yes, however I've been put off the Cyrus by a mate of mine
    that's got them. Everso slightly too full in the bass and sharp in the
    treble.
    Of course I could solve the problem by downgrading the amp and speakers...
    Gyp, Dec 28, 2008
  11. Gyp
    Catman Guest
    What he said, in every respect. Although the 8s are a bit unreliable.
    OTOH it is a *very* much more clinical sound that the Marantz KI's IME.
    Catman, Dec 28, 2008
  12. Gyp
    Catman Guest
    *HUH*!?
    What's that being run through?
    That's nothing like I would describe them.
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Catman
    Ooh nooooo. It's got a top-note of cherry with side suggestions of
    barbecued pork. Except for the lower reaches, where it smells of
    elderberries.
    ****'s sake, you hi-fi wankers are worse than the coffee lot.
    Wicked Uncle Nigel, Dec 28, 2008
  14. Gyp
    Catman Guest
    **** off, you ignorant ****. <insert smiley here>
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Catman
    Wotchoo on abaht?
    I'm a musician me!
    <fx: returns to whacking bits of plastic with drumsticks>
  16. Gyp
    Gyp Guest
    Some enormous gothic Musicalal Fidelity thingy and some Ruarks
    Gyp, Dec 28, 2008
  17. Gyp
    Gyp Guest
    The one Cyrus I've tried was less clinical than my 10, so as I'm hoping
    for clarity and linearity then perhaps I'll give the newer Cyrus kit a spin.
    Gyp, Dec 28, 2008
  18. Gyp
    Catman Guest
    /me proffers high end USB cable.....
    Catman, Dec 29, 2008
  19. Gyp
    Catman Guest
    Some 'better' matching should cure that, then.
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Catman
    Is it de-oxygenated?
    Wicked Uncle Nigel, Dec 29, 2008
