Paging suit wearers
Discussion in 'UK Motorcycles' started by Doki, Jan 16, 2008.
  1. Doki
    Doki Guest
    Those people who advertise in the papers offering to measure you up in
    England and have some bloke in Hong Kong run you up a suit for 20p. Are they
    any good?
    I'm likely be getting a proper English tailor made suit done too, but it'd
    be handy to have a spare. OTOH if the HK ones are particularly decent, I'm
    not likely to wear a suit more than 14 days a year, so I might be able to
    pocket the cash different.
    And WTF sort of suit do I want? It'll be for work - meeting clients and the
    like.
    Doki, Jan 16, 2008
  2. Doki
    Eiron Guest
    Double breasted, two rows of buttons, no vents.
    Turn-ups on the trousers.
    A plain gray with the gayest Paisley pattern lining.
    Eiron, Jan 16, 2008
  3. Doki
    Doki Guest
    Are you on crack mate?
    Doki, Jan 16, 2008
  4. Doki
    Eiron Guest
    OK, the gaily coloured lining is optional.
    Eiron, Jan 16, 2008
  5. Doki
    Jeez, I'm with Blaney on matters sartorial.
    Whatever next, eh?
    CT, Jan 17, 2008
  6. Doki
    single breasted, single vented, 4 button cuffs[1]. In dark grey/
    charcoal. Or very dark blue with white pin-stripe or mid-brown with
    white pinstripe. Avoid prince-of-wales check unless you want everyone
    to think you're some manner of ****.
    [1] and for proper kudos, make sure the cuff buttons actually work[2]
    [2] but never unbutton them.
    darsy, Jan 17, 2008
  7. Doki
    Why do suits have buttons on the cuff when no-one ever undoes them? I
    assume it's some kind of a hangover from when sleeves where slimmer and
    you couldn't get your hands through, but surely they could be done away
    with now.
    But that sounds ghastly!
    Quite true.
    <fx:thinks>
    Oh. I had a P-of-W check suit once...
    CT, Jan 17, 2008
  8. Doki
    you're right, and it's largely a style thing. I do have one suit with
    opening buttons on the cuff (this is called a "doctor's cuff" for
    fairly obvious reasons). I don't think any of my suit (or other
    tailored) jackets have no buttons, but there is a variation between 3
    and 4 buttons (less than this is gauche)
    I have such a suit on right now. Perhaps "mid-brown" isn't quite
    right, it's approximately the colour of plain chocolate, with a very
    fine bias-stitched pin-stripe.This suit is actually double-vented,
    British style, despite having Italian style tapering, but in general I
    prefer a single vent. Unvented suit jackets are for pimps, and only a
    clown would consider a triple-vented jacket.
    darsy, Jan 17, 2008
  9. Doki
    I wouldn't know the difference between British and Italian style anyway.
    And I don't think I've ever chosen or rejected a suit based on the
    number of vents.
    Harsh - it was a long time ago.
    CT, Jan 17, 2008
  10. Doki
    Whilst you may not know which is actually which, you probably would
    notice the difference.
    It's worth noting that generally stuff sold in the UK as
    "Italian" (and I'm looking sternly in the direction of M&S here) isn't
    actually Italian styled at all.
    me neither, I just prefer the way single-vented jackets hang, and are
    less prone to creasing up at the back. But if I like everything else
    about the suit, I won't dismiss it because it's double-vented.
    darsy, Jan 17, 2008
  11. Doki
    indeed not. The only fella around here who wears one is Sir.D. the
    chairman, and he's about 108, with a belly like a hippo, and he needs
    double-breasted in order to be able to button it.
    darsy, Jan 17, 2008
  12. Doki
    You're probably right. Just a guess, but I suspect that my build
    wouldn't suit[1] Italian style, anyway.
    Oh.
    [1] Pun intended.
    CT, Jan 17, 2008
  13. Doki
    Pete Fisher Guest
    In communiqué
    One of the great joys of semi-retirement is not ever having to wear a
    suit again except for wedding, christenings and funerals (no chance of
    an MBE or an invitation to a Royal garden party).
    <scans contents of wardrobe>
    I really should get round to sending all of them except one to Oxfam.
    Single breasted, single vented, 3 or 4 button cuffs, dark grey or dark
    blue with white pin stripe. With the exception of my court suit. The
    same, but double breasted. Gives an air of gravitas when under cross
    examination by some **** of a barrister. For best effect, set off with a
    pair of half moon reading glasses, for staring over.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 17, 2008
  14. Doki
    dog Guest
    i think you could have stopped after "why do suits".
    ridiculously impractical clothing.
    dog, Jan 17, 2008
  15. Doki
    unless you're wide across the shoulders and slim at the waist, you're
    probably right.
    darsy, Jan 17, 2008
  16. Doki
    I dunno, it might go nicely with a wing collar and some spats.
    ogden, Jan 17, 2008
  17. Doki
    I actually like wearing a suit to work, but I wouldn't wear one
    outside of work.
    I've only ever been in court once - I don't make a habit of it.
    darsy, Jan 17, 2008
  18. Doki
    Yes, I've fairly wide shoulders...
    ....awww...bugger.
    CT, Jan 17, 2008
  19. Doki
    for me the answer is "I work in a fairly conservative financial
    services company where all of the business users I interact with wear
    suits". Also, wearing a suit means there's a lot less of a choice to
    have to be made in the morning regarding what to wear.
    actually, unless you want to - for the sake of an example - ride a
    motorcycle, suits are perfectly practical - a decent suit jacket has
    lots of handy pockets to put your mobiles, keys, small change,
    travelcard, wallet etc.
    darsy, Jan 17, 2008
  20. Doki
    actually, I have on a black shirt and walnut gusset-sided chelsea
    boots.
    darsy, Jan 17, 2008
